Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Stueeee
    Stueeee
    from Kent, UK
    Looks like American Austin to me. The Bantams I have seen have semi elliptic rear springs. The ch***is in the photo is missing its cross members, but does have spring mounting bolt holes for quarter elliptic rear springs that look very similar to those on my UK built Avatar Austin Seven. The upswept rear part of the ch***is is the same shape as the 1934 and up UK built ch***is, but on the UK car it is a rivetted on extension rather than part of the ch***is rail "proper" as in the photo.
    motoklas, Ned Ludd and banjeaux bob like this.
  2. banjeaux bob
    banjeaux bob
    from alaska
    Thanks STUEEE!
  3. banjeaux bob
    banjeaux bob
    from alaska
    102691593_10216257898095717_4916530868389607623_n.jpg 102810382_10216257898775734_6744605887714698972_n.jpg 102386053_10216257898695732_8100270539885022112_n.jpg 102784111_10216257898375724_3264557712715007503_n.jpg Jean-pascal's ,Paris,latest acquisition.
    Hamtown Al, rooman, Ned Ludd and 3 others like this.
  4. Rolfzoller
    Rolfzoller
  5. noboD
    noboD
    Outstanding!!
  6. The37Kid
    The37Kid
    Looks like the kids left their Type 52 Bugatti meet to check it out. Bob
    motoklas, Rolfzoller and banjeaux bob like this.
  7. fredvv44
    fredvv44
    Great, reminds me of the VonDutch Wing.
  8. The37Kid
    The37Kid
    ^^^^ That VonDutch car is about 30 minutes away from me. Apart for restoration, hope it gets together again. Bob
    Hamtown Al likes this.
  9. banjeaux bob
    banjeaux bob
    from alaska
    I did a thread on that car awhile ago Bob. Anthony has gotten running well again.Not a nut and bolt restoration...just a solid reconditioning.They used a razor blade to remove the many layers of paint down to the black.
    1952B3b23, Hamtown Al and The37Kid like this.
  10. The37Kid
    The37Kid
    That is good news, amazing what you can do with a razor blade, takes some patients to develop the feel for it. Stripped a Rolls Royce years ago swapping out for sharp blades is the key. Bob
    banjeaux bob likes this.
  11. fredvv44
    fredvv44
    I have 16 pix of that car if you would like to see more.
  12. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^^^^^^^^^ MORE INFO NEEDED! That is a really nice kids car, never seen one that size. Bob
  13. The37Kid
    The37Kid
    It looks to have all the right stuff as a real car except for the wire wheels, almost thought there was photoshop work done. Bob
  14. '52 F-3
    '52 F-3
    from Central PA
    Almost have my almost cyclecar running...:eek:
    motoklas, Ned Ludd, tarcoleo and 2 others like this.
  15. noboD
    noboD
    Bob, any idea of what motorvates it?
  16. banjeaux bob
    banjeaux bob
    from alaska
    103570085_10224224816114752_7593646599645223496_o.jpg Stefan H. pic. ...
    Rolfzoller, 1952B3b23, Kume and 4 others like this.
  17. banjeaux bob
    banjeaux bob
    from alaska
  18. fredvv44
    fredvv44
    Love those Amilcar's.
  19. banjeaux bob
    banjeaux bob
    from alaska
  20. fredvv44
    fredvv44
    Love Austin 7 Specials.
  21. banjeaux bob
    banjeaux bob
    from alaska
  22. banjeaux bob
    banjeaux bob
    from alaska
    Fred, be on the watch for those self appointed moderators who will claim Sevens aren't cyclecars.Me, I could care less.
    64 DODGE 440 likes this.
  23. goldmountain
    goldmountain
    Does anyone out there know how to do an Austin 7 dropped axle?
    Sent from my SM-T350 using The H.A.M.B. mobile app
  24. Stueeee
    Stueeee
    from Kent, UK
    Most of them were done by whoever the local blacksmith happened to be back in the day. One of them in South London (Townsends) had a flame cut jig which fitted in a big press. The axle beam was heated to cherry red and went in between the two parts of the press jig. Probably not much help to you if you are based in the US but this company still do dropped A7 front axles.
    http://www.vintageaustinservices.co.uk/
    The37Kid and banjeaux bob like this.
  25. Rolfzoller
    Rolfzoller
  26. Rolfzoller
    Rolfzoller
  27. Stueeee
    Stueeee
    from Kent, UK
    Great photos. Austin Seven "Ulster" sports models appear to ubiquitous in modern day UK compe***ion events.
    The Austin factory are generally reckoned to have made about 175 of this model, of which about half were the supercharged version - there aren't any definitive numbers because most of the build records held at Austin's factory were destroyed during WW2 bombing raids.
    By comparison, the White haired bloke -Rod- in the photo below told me he has now made 200 of these "rivet perfect" Ulster bodyshells. This one was being loaded into my truck earlier this week, the bonnet (hood) and spare wheel cover are loaded inside the body.
    I'll be installing this on top of a period modified ch***is along with a supercharged pressure lube motor, close ratio gearbox and such. It takes Rod two weeks to make one of these bodies. No power tools used; all the seams are (perfectly) gas welded.
    Outback, motoklas, Ned Ludd and 5 others like this.
  28. The37Kid
    The37Kid
    DSCF8996.JPG Rolfzoller, Is there a market for old issues of the Bulletin? I have enough to fill a Flat Rate box.
    Bob
  29. banjeaux bob
    banjeaux bob
    from alaska
    Fabulous STUEE!
  30. Rolfzoller
    Rolfzoller
    Hello Bob, there is actually not a real market for old issues. I only know that some very old issues are interesting for collectors. The best is you ask the Librarian of the VSCC ,library@vscc.co.uk
    motoklas and The37Kid like this.
