Projects Youngsters first hot Rod build
Discussion in 'Traditional Hot Rods' started by Axel de Groot, Sep 15, 2019.
  1. Axel de Groot
    Axel de Groot
    from Sweden
    Im sorry but i have No idea who Stig Brohlen is??
    j hansen and chryslerfan55 like this.
  2. Axel de Groot
    Axel de Groot
    from Sweden
    Thanks for following![emoji2]
    They sure are great! If you go by them, tell them i more than pleased with the service[emoji1303]
    Stogy, catdad49 and chryslerfan55 like this.
  3. wheeldog57
    wheeldog57
    Stogy and Axel de Groot like this.
  4. Axel de Groot
    Axel de Groot
    from Sweden
    A little paint on the ch***ie makes everything look more ”done”. No fancy pancy powder coat or such, i went to the local hardware store and asked for a ”black coulour not to shiny and not to matte”, and bought and new paint brush!
    Waiting on my headers so i can build the exhaust system. Then after that the body will probably be lifted back on. Then its time to fit the f-1 box and link up my 32 pedals.
    I Cant wait to get this thing on the road!! Hopefully i get to do some driving this season[emoji2][emoji482][emoji1009]
  5. AndyMarquez
    AndyMarquez
    from Sweden
    Ser grymt ut!
    Skickat från min iPhone med H.A.M.B.
    benke and Axel de Groot like this.
  6. Axel de Groot
    Axel de Groot
    from Sweden
    Vad gött att höra lite svenska här också!
    Vart i vårt avlånga land bor du?[emoji16]
  7. 48fordnut
    48fordnut
    Looking good .keep up the good work.
    chryslerfan55 and Axel de Groot like this.
  8. Axel de Groot
    Axel de Groot
    from Sweden
    I mentioned this little thing a couple posts back didnt i? An old cut down generator with a v8 60hp fan attached to it!
    I believe the original 59ab fan setup would be to tight and an electrical fan isn’t an option...
    Well now the fan setup is painted and mounted with a fan belt and all!
    Cheers everyone!
  9. AndyMarquez
    AndyMarquez
    from Sweden
    Gött som fan [emoji2] bor i Brålanda. Ligger vid Vänersborg typ. Vart bor du själv?
  10. Axel de Groot
    Axel de Groot
    from Sweden
    Där på västkusten finns ju ett par roddar[emoji1303] själv bor jag på andra sidan landet, lite utanför Oskarshamn på Sveriges östkust[emoji16]
    chryslerfan55 and winduptoy like this.
  11. Axel de Groot
    Axel de Groot
    from Sweden
    The sun was shining here today so i thought i had to take her out of the garage to have a better look att my creation!
    Also found the missing pieces to the puzzle, a 32 clutch arm that will link upp with my 32 pedals! And a 37 pitman arm that after some minor grinding to the splines will fit to my f-1 box[emoji16]
    Speaking of sunshine, man do i wanna get this thing Rolling soon!![emoji1009]
    Stay safe everyone.
  12. winduptoy
    winduptoy
    Looking good there Mr Axle...it is turning out real nice. You've been thinking about this for awhile by the looks of it.
    Sent from my XT1585 using The H.A.M.B. mobile app
    chryslerfan55 and kidcampbell71 like this.
  13. winduptoy
    winduptoy
    Så jag tror att du presterar på en nivå bortom dina år. Men det verkar som om du har varit med bilar hela livet. Håll upp takten så kommer du att vara på väg på nolltid.
    chryslerfan55 and j hansen like this.
  14. 4barrel
    4barrel
    Looking Awesome Axel! Same age when I first built my traditional roadster and did a build thread on here. Keep motivated and full steam ahead! Fun times to be had for sure!
  15. AndyMarquez
    AndyMarquez
    from Sweden
    Ja roddar och Volvo är typ samma sak här [emoji23] okej okej, hur är beståndet på er sida?
    Drar igång med mitt bygge i höst. Ska bli gött.
  16. Hotrodray
    Hotrodray
    from Sweden
    I remember the Deuce coupe of Stig from an old swedish car mag... So i googled his name.. Still lives in the Stockholm area!
  17. Deuce Daddy Don
    Deuce Daddy Don
  18. Brian Lundgren
    Brian Lundgren
    Awesome build thread! That fan setup is very cool!
  19. Axel de Groot
    Axel de Groot
    from Sweden
    Finns en del roddar på denna sida också![emoji1303] gött, vad blir det för bygge?[emoji16]
    Är Forden på din bild din?
  20. Axel de Groot
    Axel de Groot
    from Sweden
    Thank you! I got the tip on the fan setup from an old hot Rod Guy here in sweden[emoji1303]
  21. Axel de Groot
    Axel de Groot
    from Sweden
    Thanks man! Im going to check out your roadster thread right away[emoji1303]
  22. Axel de Groot
    Axel de Groot
    from Sweden
    Thanks!
    Your swedish is great!! Cars has been involved in all my life. Started with Harley motorcycels when i got to ride with my dad on his 50’ panhead when i was little kid. At the time my mom and dad each had a Harley and a 39’ Ford deluxe and some years before that a black 1950 plymouth with flames on! So cars and bikes has been with me from the start[emoji16]
    Im dreaming of an old Harley to, so perhaps that is my next build, but it Will have to wait a. Couple years [emoji1303]
    chryslerfan55, winduptoy and OFT like this.
  23. AndyMarquez
    AndyMarquez
    from Sweden
    Fint det [emoji1303] blir en prewar -29 roadster av8 är planen. Japp, det är våran också. Behöver ha nåt med mer än 2 platser också [emoji23]
  24. Axel de Groot
    Axel de Groot
    from Sweden
    Härligt! Ser fram emot att se den[emoji1303]
    Grymt snygg måste jag säga[emoji16]
  25. AndyMarquez
    AndyMarquez
    from Sweden
    Ja, jag med [emoji23] din med när den blir klar [emoji1303] tack för det [emoji2]
  26. Axel de Groot
    Axel de Groot
    from Sweden
    Body is back on!! Summer is here, time to put in next gear and get this thing on the road[emoji16][emoji16]
    Some tinkering with the pedals left and the f1-box has to adapted to fit. Some wiring and other small things left but we are closing in!
    2bubbas, brEad, OFT and 8 others like this.
  27. winduptoy
    winduptoy
    Isn't it nice to get one moving under its own power so you get room for the next project.. looking real good.
  28. roseville carl
    roseville carl
    kool...........
    Axel de Groot likes this.
  29. 33Doll
    33Doll
    Nice!
    Cool little Hot Rod!
    Nice piece of property there too!
    Is that in Sweden? Or are you a Swed living is the US somewhere?
  30. Axel de Groot
    Axel de Groot
    from Sweden
    Thank you![emoji16]
    You are right, it is in Sweden, southeast of Sweden. The property is an old barn wich my dad rebuilt in to a garage many years ago!
