Technical I give up... what are these for?
Discussion in 'The Hokey Ass Message Board' started by AGELE55, Jun 8, 2020.
  1. AGELE55
    AGELE55
    So,the 39 Poncho has these "dragon tails" on the rear springs. I see them on a lot of the old fat fenders. After much deep thought & contemplation, I've decided that I have zero clue what purpose they serve.
  2. Budget36
    Budget36
    "I made it because I could"
    Kinda comes to mind...
  3. lothiandon1940
    lothiandon1940
    When you hear them s****ing pavement, you have too much moonshine in the trunk.:eek:
    kiwijeff, AGELE55, mgtstumpy and 11 others like this.
  4. lothiandon1940
    lothiandon1940
    I know this is going to sound even more bizarre than my moonshine thought above. If you dropped the rear tire pressure to 10psi and tossed 4 sacks of fertilizer and 4 sacks of corn in the trunk, you could use that ole Pontiac as a tractor and plow the furrows to plant the corn. I told you it was going to sound bizarre, but not every poor family owned a tractor or a mule back in the day.
    kiwijeff, vtx1800, AGELE55 and 9 others like this.
  5. The37Kid
    The37Kid
    Googled 1939 Pontiac rear bumper brackets and got this photo. Bob
  6. 6inarow
    6inarow
    **** I bet you are sorry you asked. I have this funny feeling the boys are just getting going with answers. Sorry dude!! But there should be some funny ones!
  7. ct1932ford
    ct1932ford
    Looks like the same car!:confused:
  8. tb33anda3rd
    tb33anda3rd
    I think the more weight you put in it the HIGHER the brackets would move.
    could it be some kind of devise to keep the bumper at ride height?
    lothiandon1940 likes this.
  9. tb33anda3rd
    tb33anda3rd
    part of a sway bar type thing?
  10. sloppy jalopies
    sloppy jalopies
    something to push start it with as a race car ?
    Lil32 likes this.
  11. 36 poncho
    36 poncho
    from ny
    jack location for stock roadside jack
  12. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    My guess would be, brackets for a receiver hitch that just didn't get finished.
  13. Country Joe
    Country Joe
    I see the brackets but, can't see what they do.
  14. swade41
    swade41
    from Buffalo,NY
    James Bond boomerangs for decapitation of tailgating roadster drivers
    kiwijeff, AGELE55, 6inarow and 2 others like this.
  15. arkiehotrods
    arkiehotrods
    Here is a picture of a woody with those brackets, as well as two photos of a restored sedan which has them as well
    1769328659_woodie1.thumb.jpg.ebdb49dc940d26acad8967614a1ef95f.jpg 9003091-1939-pontiac-silver-streak-std.jpg 9003090-1939-pontiac-silver-streak-std.jpg
    kiwijeff, AGELE55 and lothiandon1940 like this.
  16. The37Kid
    The37Kid
  17. 6sally6
    6sally6
    Used to chain down the car on the delivery truck/car hauler?! End of discussion!
    6sally6
  18. gene-koning
    gene-koning
    This one makes sense to me. If the rear bumper was mounted off other brackets, maybe these brackets are some kind of overload that could limit how much the spring could flatten out under a load. Gene
    Bird man and seb fontana like this.
  19. deathrowdave
    deathrowdave
    from NKy
    There was a bar type lift that moved the ch***is down the ***embly line , these were supposed to be removed as part of dealer prep after a sale of the car and returned by the parts dept to the factory
  20. Ebbsspeed
    Ebbsspeed
    Wheelie bar brackets.
    HuskerNation, Tim, kiwijeff and 4 others like this.
  21. arkiehotrods
    arkiehotrods
    kiwijeff and AGELE55 like this.
  22. squirrel
    that does not sound very likely. Replacing the shackle to remove an ***embly aid, just doesn't sound reasonable. And why would it still be on the clear demo car?
    I wonder if anyone has an owner's or factory shop manual for the car? Might be a clue in there somewhere.
    HuskerNation and AGELE55 like this.
  23. Was there a Pontiac part number for the pretty girls in the trunk?
  24. blowby
    blowby
    from Nicasio Ca
    Bottom out s****ers.
  25. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    To protect the gas tank in case you get hit hard in the rear? Maybe the Pinto should have had them:p
  26. Paul
    Paul
    Editor
    When the spring is fully compressed the shackle pivots raising the tail, for no good reason at all
    AGELE55 likes this.
  27. TCTND
    TCTND
    If you jacked the car up on one of those it would lift the wheel so you wouldn't need to lift it nearly as much to change a tire as jacking on the frame.
    51pontiac, Texas57, 49ratfink and 4 others like this.
  28. hemihotrod66
    hemihotrod66
    Where you jack the car from....
    Texas57, 49ratfink and AGELE55 like this.
  29. big duece
    big duece
    from kansas
    Clean the mud off your boots...
  30. Paul
    Paul
    Editor
    Hang your trouble light from
