https://www.macsautoparts.com/ford_...alog_product_gallery/index/image/1/id/439356/ I’m debating whether using one of these or a runtz on each gauge.
I ***ume you converted to 12v but still want to use your original gauges? Use this...……….. https://www.ebay.com/itm/1967-1968-...836827?hash=item288dde215b:g:w5oAAOSw6dteNliX
It is mentioned here in paragraph # 13 https://darksidersrealm.forumotion....lt-positive-ground-to-12-volt-negative-ground You hook it up the same as in the Mustang diagram here ( DO NOT hook up the amp guage if you now have an alternator)
There's a guy in Michigan that takes these junk CVR's and converts them to solid state. No more problems.
