Projects My First Hot Rod!
Discussion in 'Traditional Hot Rods' started by Eric16, Jun 24, 2019.
  1. Eric16
    Eric16
    Finally got the motor in! Looks great! Ready to get the rest of the car together!
    Vic Walter, triumph 1, Tim and 2 others like this.
  2. Eric16
    Eric16
    Finally got the car on the ground with the new frame! Right now the car has 4.50 tires up front and 7.00 on the back. I'll be running 6.00 up front and 7.50 out back. Also, I only had 150 lbs on the rear cross member. Between the bigger tire up front, and the body weighing the back down, the car should get a little closer to level. Love the rake, but the cars sat a little more level in the late 40's.
    20200607_165509.jpg 20200607_165419.jpg 20200607_165401.jpg 20200607_165308.jpg
    Vic Walter, swade41, brEad and 6 others like this.
  3. Eric16
    Eric16
    Body is finally on! Lovin the stance!
  4. flyin flattie
    flyin flattie
    from Redmond OR
  5. Eric16
    Eric16
    Picked up a nice set of 35 wires and an absolutely mint set of Lincoln brakes for the Roadster!
  6. Sonofabob
    Sonofabob
    That's a great looking Hotrod!
  7. Eric16
    Eric16
    Got the rear end set up with the Lincoln brakes and back under the car!
  8. Eric16
    Eric16
    Fit the round back spindles to the front Lincoln brakes. Ran into a problem where the backing plates won't fully seat due to clearance issues between the backing plate and the top of the king pin. On a good note, it won't take much to get the tie rod in the perfect spot.
    Vic Walter and loudbang like this.
  9. Eric16
    Eric16
    Installed the F-1 box and front Lincoln brakes. Back on the ground again!
    Vic Walter, swade41, Jeff34 and 5 others like this.
  10. Eric16
    Eric16
    Back on the ground with the Lincoln brakes and wire wheels. 6.00 tires all around, it'll be perfect with 7.50s out back. Lincoln backing plates needed some clearancing, but nothing too crazy. The front brakes require a spacer from Speedway to get the wires to fit.
    Jeff34, Vic Walter, swade41 and 4 others like this.
  11. Eric16
    Eric16
    It's been a while since my last post. Two deployments, two kids, and a lot less free time! I'll sprinkle in what I've been up to for the past 4 years and my plans to finish the roadster up!
    First up, after a long detailed search, I was able to track down the exact kind of intake and heads Bernie Couch ran back at the dry lakes in the late 40's. Small details like this will help with my tribute to a great man and a *****in hot rod.
    Jeff34, jet996, Vic Walter and 3 others like this.
  12. bubba55
    bubba55
    Ya doing Otay there Bubba - keep at it
    I wish to personally say thank you kindly for your service
    Mechman_22 and Speccie like this.
  13. vintagehotrods
    vintagehotrods
    Keep after it, your getting there and having fun doing it! Bernie would have been so proud to see you doing this tribute to him. Your being deployed would have also really been of interest to him. Bernie had a a lot of great stories that he shared with me, and I wish I could have heard more, especially of his time in the war. He was really proud of his time in the Navy, and his ship held regular reunions that he attended.
    He loved his roadster and drove the hell out of it! He was just as fired up about his roadster all these years later. One thing of note, was that he told me was he had switched to a full load of alcohol when he got his roadster up to 134.32 mph.
    A few more of the 300+ pics Bernie gave me.....
    This is why Bernie had to build a new motor in 1949.....
    These are pics of Bernie breaking in his new motor with a run all the way up to Coos Bay, Oregon,
    and one of his many trips to Las Vegas, Nevada!
    Bernie's inpection slips from 1946 and 1947.......
    Some of Bernie's many timing tags over the years.....
    Deutscher, jet996, Vic Walter and 5 others like this.
  14. Eric16
    Eric16
    Thank you so much! Always love seeing pictures from Bernie that I've never seen before. I need to figure out a way to get some digital copies of those!
    I also loved his stories from his time in the Navy. Things were alot different back then!
  15. Eric16
    Eric16
    Picked up some BLC headlights. Love the look of them and it completes the front end of the roadster!
  16. ALLDONE
    ALLDONE
    did you put the wheel shims on top of the spacer????
  17. ALLDONE
    ALLDONE
    what drums are theres on the front??? and is that a wheel shim, if so does it fit tight on the lugs????
    Vic Walter likes this.
  18. RICH B
    RICH B
    What you are seeing is the flange of the hub, not a spacer.
    On '46-'48 Ford drums, the drum is actually mounted on the inside of the hub's flange.
  19. ALLDONE
    ALLDONE
    so what did you do to be able to run the 35 ford wires????
  20. ALLDONE
    ALLDONE
    so if you can't bolt 35 wires to 40's drums... what was done???
  21. RICH B
    RICH B
    You can use '35 wires with both styles of '40's brake drums; just have to support the center.
    Long time ago, we cut a piece of black pipe (can't remember the size) 1/4" thick and tack welded it to the drum.
    Now-a-days easy to just buy the support rings from Speedway.
    '46-'48 outside flange hubs many times have balance weights welded to the edge of the drum; they need to be knocked off to use '35 wires as the wheel center will hit them and twist them up if tightened down against them.
  22. ALLDONE
    ALLDONE
    thanks for the reply,... I bought speedways.. the lug hole are way too big and I think the plates should be more hub centered so that when you put the wheel on they aligned with the center and not hang down so far... also didn't like how the outer edge doesn't contact the drum making the only contact the very center of the wheel... I seen a post where they welded the plates to the wheel, I even contact glued them on, but still wasn't happy with the results...so I removed them... just a guess but,... my bet is it's a hundred to one that don't use them and don't even know they exist
  23. RICH B
    RICH B
    And that is exactly the reason too check closely for cracking around the lug holes when buying '35 wires; especially if it looks they had been used on a hot rod in the past.
  24. alchemy
    alchemy
    Forcefull, just use the Speedway supports. They are so near the center of the rotation that any non-concentric imbalance will be undetectable. And, they do support everything that needs to be supported. Trust us. We've done this before.
    Or, don't trust us, and we hope you can find some replacement wire wheels in a thousand miles to replaced the ones you cracked.
  25. hotrodlane
    hotrodlane
    Awesome roadster.
