Projects 1939 Packard Custom
Discussion in 'Traditional Customs' started by CadMad, Apr 15, 2020.
  1. patsurf
    patsurf
    i'm NOT!!-love these step by step shows!--pat (who says take your time..)
    CadMad, chryslerfan55 and VANDENPLAS like this.
  2. chriseakin
    chriseakin
    Is there or will there be any support bearing for the steering column?
  3. CadMad
    CadMad
    Yes. Work in progress. Went to my bearing supplier and there is nothing off the shelf so I need to pull apart and gut a couple of other spare modern columns and turn the shaft to suit.
  4. nochop
    nochop
    from norcal
    Isn’t that Jack Hoff, Mike Hu*ts cousin?
  5. CadMad
    CadMad
    It’s hard to believe that each morning I arrive at work I’m awaited by a such beautiful sight. It’s come together almost easily. That said it is only when you go back to the early germination of ideas you understand the enormity.
    The hulk I dragged home less than a year ago is a far cry from what sits here now.
    All along the way I’ve had input from many sources. Each line, each shape is carefully thought out and ideas debated.
    Rik Hoving , E603EA65-62BE-4DD1-9420-01260AC12B65.jpeg 5C19A307-690F-4A82-AAD7-D3DCC6E47282.jpeg 36BAEF51-3D04-4951-832B-E63152941AF9.jpeg DE66926D-AC7A-4A07-8B1C-31B420CA8052.jpeg E6EF982E-C48F-4335-B85F-0EC018EC2C51.jpeg as usual, has generously ***isted every step of the way.
    What you don’t see is the many exchanges between us.
    My messages back and forth with Rik is 500 plus exchanges.
    So here are a few Photoshop’s that we mulled over just yesterday, ideas and technical issues.
    I’d also like to thank James D and Wolf for taking me out of my comfort zone early on and taking it to another level. Those ideas have found there way onto the car.
    It has been a collaboration, is what I’m getting at.
  6. Peanut 1959
    Peanut 1959
    I'm having a hard time seeing the differences in most of the last photos. Can you describe the main variations?
  7. Weedburner 40
    Weedburner 40
    I really like it with the detail line through the cowl and door. I also think I like it best with it going all the way to the fender. That is going to be gorgeous.
    lurker mick and lothiandon1940 like this.
  8. CadMad
    CadMad
    Gday Peanut, All door variations. Swage , no swage, thick swage, thin swage, curved sill, flatter sill....
    chryslerfan55 and Peanut 1959 like this.
  9. CadMad
    CadMad
    Personally, I like the middle one best.
    brEad likes this.
  10. gsnort
    gsnort
    Then, go for it. Fabulous work. You are to be congratulated.
  11. Dos Cincos
    Dos Cincos
    Fourth picture. Body line all the way to the fender and flat bottom on door.
  12. Squablow
    Squablow
    I am loving this. I was prepared to hate the top because it was modern-sourced but it really works on this application with the shapes of the car, matches up really nice.
    It's a great feat in itself to fix a car as rough as that one was, it's a much bigger feat to make it look like something that could cost a million dollars. Looking forward to watching it come together even further.
  13. CadMad
    CadMad
    I hear you Squablow. I was anticipating flack as well. The rear window will be removed and I’m tossing up a Mail slot. Or a fancy double kidney shaped Bugatti inspired rear window.
    chryslerfan55 and Squablow like this.
  14. lucas doolin
    lucas doolin
    Metalworking mastery and design wizardry. Breathtakingly beautiful. Thank you for sharing your vision and ability. An inspiration for us all.
    lothiandon1940 likes this.
  15. CadMad
    CadMad
    Next debate is Lincoln door ****on position. Nb Rik tweeked door just a little more and to my mind is close to perfection. FBB715FF-0FF8-4453-9827-5EBF07F3CE54.jpeg 0B97FE98-C11F-4B46-BAA7-167F021E4485.jpeg
  16. Stovebolt
    Stovebolt
    what an inspiring creation. That car is the perfect luxo-rod.
  17. Peanut 1959
    Peanut 1959
    Would it be crazy to use this version, but create a larger diameter recess around the ****on to make it more intentional...almost like a medallion? Seems like it would be a nice detail. tapatalk_1591917664705.jpeg
    mgtstumpy, 40two and chryslerfan55 like this.
  18. manyolcars
    manyolcars
    Gorgeous! Beautiful! Awesome! Go Man Go!
  19. This is turning out great! The lines are elegant and flowing. Door ****on looks better at the front.
  20. fegsta
    fegsta
    This is super fantastic!!! I like the 4th pic it runs with the fenders.
    Sent from my KOB-L09 using The H.A.M.B. mobile app
    chryslerfan55 and CadMad like this.
  21. Super Streak
    Super Streak
    from Florida
    Absolutely stunning!
  22. Weedburner 40
    Weedburner 40
    I agree, door ****on needs to be at the front, the detail line needs to run all the way through to the rear fender and the straighter door bottom looks best. Recessing the ****on would really set things off too.
  23. 1-SHOT
    1-SHOT
    from Denton
    This is the one I like the best. But its your party B52C13A3-79E1-4599-B0A5-6D90DC0A03D7.jpeg
    Reminds me of a 1939 Horch Cabriolet 1FA55866-656C-4E9A-8DCB-B5581343290F.jpeg
  24. Stan Back
    Stan Back
    Front? Back?
    I'd think it should depend which way the door opens.
    brEad and DIYGUY like this.
  25. 1-SHOT
    1-SHOT
    from Denton
    Fabber McGee and chryslerfan55 like this.
  26. 1-SHOT
    1-SHOT
    from Denton
    Here is a side view of the 39 Horch You dont see any of these.my neighbor brought one back from Germany when he came from the Army in 55. It was OD Green E0634829-8756-4B5C-929D-61A009D4540F.jpeg
  27. Darin Younce
    Darin Younce
    Holy hammers batman, that is about the purtyist thang I seen since my first look at a ******* mag.
    CadMad and chryslerfan55 like this.
  28. CadMad
    CadMad
    My boss in Perth has a 38 Horsch roadster. I guess I must have soaked it in. When I had a look under the car I could see where bomb plates had been welded in and then removed.
    mgtstumpy, DanGunit69, hfh and 2 others like this.
  29. 1-SHOT
    1-SHOT
    from Denton
    They also Had DeDeon rear suspension an had a unusual looking head surface. The one Mike had still had the plates under it, a real piece of history, he doors opened from the front like a 33 Ford. I always thought they looked fast sitting still. Frank
    hfh, kidcampbell71 and chryslerfan55 like this.
  30. alchemy
    alchemy
    Put the ****on right in the middle of the door, in the bead. Just like your WWII photoshop.
    chryslerfan55 and brEad like this.
