Technical Multi Carb Setups -Let's see 'em!
Discussion in 'The Hokey Ass Message Board' started by pkhammer, Apr 11, 2020.
  1. LM14
    LM14
    from Iowa
    First 6 pictures are the 1963 8V Galaxie intake for my '62 F100 short bed big window unibody 390.
    Next 6 pictures are the SBF intake and air cleaner I picked up last week. Thinking of putting it on my '32 5 window. Depends on finding a suitable set of carbs.
    The last picture is the carbs I'm looking for Holley 2881 and 2882. If I can find a decent set of these carbs it's going on the '32.
    SPark
    intake top.jpg 2020-8q.jpg 2020-8r.jpg 2020-8u.jpg 2020-8v.jpg 2020-8w.jpg 6v-3.jpg 6v-1.jpg 6v-2.jpg 6v-4.jpg 6v-5.jpg 6v-6.jpg 6v-7.jpg
    Dyno Dave, WC145, BigRRR and 13 others like this.
  2. Joe Troilo
    Joe Troilo
    This is my first attempt at multiple carbs in the last 20 years. Wanted something retro and reliable. Decided on the Holley tri-power set up. After several jet changes it runs like a champ.
    Dyno Dave, rod1, Lil'Alb and 10 others like this.
  3. loudbang
    NICE!!! I like how most of the parts have similar "Lines"
    Deuces likes this.
  4. Sonofabob
    Sonofabob
    I would love to see a side shot of the whole car!
    Sent from my SM-G975U using The H.A.M.B. mobile app
  5. Joe Troilo
    Joe Troilo
    Thanks for the nice words. More shots coming up. Car still has some original paint.
    Dyno Dave, Lil'Alb, Deuces and 5 others like this.
  6. Movinman
    Movinman
    I can’t remember the last car I had with a SBC in it, but I seem to keep collecting these. D76F54A9-2F2D-4F70-8798-41D4A863CE47.jpeg
    Dyno Dave, WC145, Deuces and 7 others like this.
  7. Axle34
    Axle34
    from Michigan
    Dyno Dave, WC145, Tim and 14 others like this.
  8. Stllrng.
    Stllrng.
    Dyno Dave, Lil'Alb, Deuces and 3 others like this.
  9. Dreddybear
    Dreddybear
    4 94s on a Edelbrock intake. Back when they were still pretty and now. To be honest I put the carbs together, threw it on and it ran pretty good so I left them as is for like the last 7 years. I’m about to tear it apart to clean it all back up and I might go with strombergs.
    Dyno Dave, WC145, BigRRR and 16 others like this.
  10. 65pacecar
    65pacecar
    from KY, AZ
    HarryT, Dyno Dave, WC145 and 19 others like this.
  11. 65pacecar
    65pacecar
    from KY, AZ
    Dyno Dave, WC145, olscrounger and 8 others like this.
  12. 65pacecar
    65pacecar
    from KY, AZ
  13. Jacksmith
    Jacksmith
    from Aridzona
    '63 327 in a '39 Ford Coupe. Been there since the late '60's... I just cleaned & IMG_0339.JPG IMG_0341.JPG dressed it up a little using a Speedway 3-deuce kit and some O.T.B. Gear aluminum parts. Starts instantly, runs like a top.
  14. GordonC
    GordonC
    Any of you guys have any tips or ticks for making up the fuel lines for a 3 deuce flathead set up. I have everything done on mine but that and have been hesitant to start into that with out getting some tips first. Don't know if I should run 3 individual lines, one to each carb, or one line with all three connected to each other? Some nice looking stuff here by the way!
    loudbang and 65pacecar like this.
  15. Jacksmith
    Jacksmith
    from Aridzona
    I.M.O., As long as you stay away from heat sources and be sure you have no leaks, it's like an art-form... Pick out how you want it to look and go for it. I recommend a regulator to be sure your pump doesn't over power the float/needle valve. I also used fuel injection compatible "rubber" lines on mine 'cause it's a bit more rigid and less likely to sag. Let's see your set up when you get it done!
    Deuces, enloe, loudbang and 2 others like this.
  16. GordonC
    GordonC
    I currently have a single 94 on the engine but plumbed it with the 3 2's in mind. I have an inline regulator in place as well as a fuel block on the firewall with a pressure gauge so I can set it for what I need. I'll post up my set up once I get it in place. Thanks!
  17. Jalopy Joker
    Jalopy Joker
  18. Jet96
    Jet96
    from WY
    78B91DFE-FB8E-4C38-A7BF-97A693617852.jpeg Weiand Drag Star 8x2 on my 480" MEL...
    41 GMC K-18, Dyno Dave, WC145 and 8 others like this.
  19. Mike VV
    Mike VV
    from SoCal
    I finally got mine done enough for pictures.
    A Corvette / Renegade manifold, heavily modified to be able to bolt onto a Studebaker, V-8, with the aid of a pair of adapters.
    A pair of 390cfm Holleys. The main parts of the linkage will actually be mounted to the rocker cover.
    The 3/4 view is the front of the manifold. Note the word...Renegade...used to be just above the "MADE IN USA". The hole in the back was part of the EGR system. That block/location used to go all the way to the top of the manifold.
    The Lexan top has two purposes. One, so I can hopefully see the fuel flow to further modify the interior of the plenum, and two...for the just for the hell of it.
    I have aluminum plates if this one melts, or if I go to a single four.
    Mike
    Dyno Dave, Tim, enloe and 8 others like this.
  20. 65pacecar
    65pacecar
    from KY, AZ
  21. 65pacecar
    65pacecar
    from KY, AZ
  22. saltflats
    saltflats
    from Missouri
    Is that a crossfire lower?
  23. Mike VV
    Mike VV
    from SoCal
    Yes.
    The aftermarket (Renegade) version.
    I was torn between the Renegade and the Offenhauser crossram. I went this way because the Renegade has a smaller plenum and nicely formed port opening edges. Although, some of the casting is pretty poor in the design. It wasn't too big a deal to see the problems and reshape the port openings, it did take some time though.
    I'm looking forward to giving it a try. Unfortunately...it'll be a while.
    Mike
    saltflats likes this.
  24. Dyno Dave
    Dyno Dave
    41 GMC K-18, WC145, 6inarow and 8 others like this.
  25. Jalopy Joker
    Jalopy Joker
  26. swade41
    swade41
    from Buffalo,NY
    Not mine but cool enough to share
    Dyno Dave, WC145, Lil'Alb and 7 others like this.
  27. Kiwi 4d
    Kiwi 4d
    Never ever thought i would see a hissing bag of snakes under the hood of a Very nice 61 Buick. 28E655FD-6AA6-413E-8D2E-2CF5DF445770.jpeg
    Dyno Dave, Lil'Alb, enloe and 5 others like this.
  28. fredb
    fredb
  29. fastcar1953
    fastcar1953
  30. Jalopy Joker
    Jalopy Joker
