Technical Steering wheel adapter
Discussion in 'The Hokey Ass Message Board' started by Wesley Laster, Jun 11, 2020.
  1. Wesley Laster
    Wesley Laster
    So i have a after market tilt column with the gm spline shaft .. i needed / wanted to run my 53 Merc steering wheel that I have .... I started out thinking I'd cut out the center of the streeing wheel and fabricatic a new 3 bolt center ... which i did ... however, I found a ford steering shaft in my scrap pile ... figures!!
    So i removed the upper shaft , turned it down to fit in the ford shaft , installed a pin , and welded it all up ... it came out pretty nice for not having a metal lathe .... here are the pictures I took along the way ..
    Right or wrong , this is how I over came the problem.. 20200606_100835.jpg 20200606_100849.jpg 20200606_130655.jpg 20200606_134303.jpg 20200606_134303.jpg 20200608_081317.jpg
  2. Wesley Laster
    Wesley Laster
    This allowed me to run the steering wheel with no modifications... however, like I said , I had already cut out the center in preparation for the new center I had made .... so now ill show you some pictures of that , and the correct adapter to fit this steering column ( cuase there is a few gm ones out there) 20200605_170313.jpg 20200605_203612.jpg 20200605_193206.jpg 20200605_193257.jpg 20200605_234415.jpg 20200605_235232.jpg 20200605_235242.jpg 20200603_133819.jpg
    gnichols and swade41 like this.
  3. I'm impressed. Drill press/hand file/lathe.
    Wesley Laster likes this.
  4. X-cpe
    X-cpe
    You could take some side load off of the drill press spindle by building a box and cutting it in half through the bottom. Bore a hole, the diameter of the shaft below the bearing/collar, through the split. Clamp or screw the box together around the shaft and clamp it to the drill press table.
    I love using what you got to get what you need threads.
    2OLD2FAST, Wesley Laster and swade41 like this.
  5. Wesley Laster
    Wesley Laster
    It works for small little projects... my 9x20 took a poop and I haven't replaced it yet ....lol...
  6. Wesley Laster
    Wesley Laster
    Thats a good idea...!! I'll have to look into that
  7. Good job there !
