Technical 1939-46 CHEVY TRUCK IDENTIFICATION THREAD
Discussion in 'The Hokey Ass Message Board' started by cshades, Jun 11, 2020.
  1. cshades
    cshades
    from wi
    I saw a thread on ford trucks and thought it might be useful to some of you guys for a similar thread.
    I thought we would start with the 1/2 ton pickup.
    the 1939-46 chevy truck has a lot of parts at first glance look the same but in fact are not. i am a big fan of the 1939-40 truck which to a lot of guys is the same truck but actually has quite a few things that are not easily interchangeable. i think probably the best place to start is the cab differences. i am sure i dont know all of them and please feel free to add any i missed or have incorrect.
    The 39 dash was a thin flat plain panel that used 37-39 gauges. the windshield crank stuck straight out of the dash. the rear window is in a piece of rubber that is sandwiched by an outside ring that bolts from the inside. the p***enger door has the external lock in the handle. The firewall is straight up and down with the strengthening beads running vertically. i also found this last weekend there is no drail holes at the bottom of the windshield opening.
    The 40 cab is similar with the exception of the dash is thicker , more rounded, and used a new designed cluster that had all of the gauges in one package instead of separate like the 39. The windshield crank is more vertical and comes out of the top of the dash instead of the front. the rear window mounts the same and the doors, door handle/locks are the same. as is the firewall. They did add the windshield drain holes to both sides in this year.
    The 41 cab started to change a few things. like the firewall, it was stepped out 1 1/2 inches for a bit more leg room. the firewall strengthening beads are in a criss cross pattern now. The cowl vent linkage and handle are really different than 39-40 the vent also operates a lot smoother. the door lock is still on the p***enger side but moved to the door sheet metal like the car. i believe the lock cylinder is the same car to truck. the rear window bolts in the same, dash is the same as are the gauges.
    The 42 ( i think) they changed the rear window to a rubber pinch weld design. all other things are the same. There maybe other changes but i have only looked at (1) 1942 truck and not really close.
    the 46 i am not aware of any other changes in the cab from 42.
    Next i will go into the front sheet metal which is always a fun topic on these trucks.
    29EHV8, tb33anda3rd and Gasser 57 like this.
  2. cshades
    cshades
    from wi
    pics are worth a thousand words so i thought i would add a few pics of the differences in the firewalls that i was talking about in my last post. the purple truck is a 40 and the other is a 46
  3. Mac's kid
    Mac's kid
    10:30 at night and I just went out to check my cowl with a flashlight. Thanks
  4. cshades
    cshades
    from wi
    I am glad it helped you. i am going to get some pics together shortly on the differences of the front ends especially the difference between a 1939 and a 1940. i see the radiator support/ grille shells advertised all the time as the same and they are not.
  5. cshades
    cshades
    from wi
    i am going to start the front sheet metal discussion with the difference 1939 to the 1940. the first pic is a 1939 radiator support, the upper trim bar only goes back about half way to the hood. the piece in between the trim and the hood is part of the rad support and not removable without cutting it off.
    the second pic is a 1940 radiator support, the trim bar wraps all the around to the hood on both sides and is removable. i see a lot of 40 fronts described as fitting 39 & 40 which is not true. the complete ***embly is interchangeable but the individual parts are not. I.E. a 1939 upper trim bar does not bolt to a 1940 radiator support.
    the front of the radiator support is also a little bit different shape so just adding a piece between the trim and the hood doesnt make a 40 support into a 39.
    The problem with the 39 supports and upper bars are they are a bit fragile and easy to break the upper mounting tabs off. the upper trim bar has no support in the center and most have been broken in two and welded back together. the grilles are close to same with the difference being the 39 has 17 bars and the 40 has 16 bars. you can use a 39 grille in a 40 by removing the top bar. the v bar from the cowl to the radiator is the same between 39-40. the the brace above the radiator that the v bar attaches to is the same 39-40 other than the 40 has a strength bead rolled into it.
    The headlight buckets are physically interchangeable but the 39 has reflectors and bulbs and gm went to sealed beams in 1940. the front fenders and hoods are the same on a 39-40 but the parking lights were moved from inside the headlights on a 39 to a fender mounted park light on the 40 which i believe is the same light fixture as the car. the easiest way to tell if a front fender you are looking at is a 39 or 40 is by the mounting holes for the parking light or lack of holes. The inner fender is also interchangeable from 39 to 40. the hood handles are the same from 1939-46, but the hoods are not. also the cowl differences from 39-40 to 41-46 the front sheetmetal from a 39-40 isnt a direct bolt on to a 41-46 cab because of the hood latch system.
      159.9 KB
      154.4 KB
  6. 302GMC
    302GMC
    from Idaho
    Those hood handles are used on many of the '30s GM cars as well. I was always able to grab a chromed pair from a Chev Master or Pontiac.
    The '41 truck parking lights were factory equipment on '40 Pontiac, and most, if not all were partially chromed.
    29EHV8 likes this.
  7. jimdeere
    jimdeere
    Thanks for the info: have been looking for a 1940 1 ton or larger for a while. My grandfather had one on the farm.
  8. MO54Frank
    MO54Frank
  9. 5WINDOWJOHN
    5WINDOWJOHN
    from SO CAL
    More info please, running boards, rear fenders, bumpers info please
  10. 5WINDOWJOHN
    5WINDOWJOHN
    from SO CAL
    Is there a difference between 39 and 40 rear fenders and beds?
  11. cshades
    cshades
    from wi
    yes there is. the bed is narrower on a '39 by 3 inches than a '40-'46. the rear fenders on a '39 are 1 1/2 wider to make up for the difference. the skirt between the frame and the running boards are also different because of the box. the rear fenders on a '39 are probably one of the hardest fenders find in any condition. i have one set that i am trying to fix for my current '39 project.
    tb33anda3rd and bchctybob like this.
  12. bchctybob
    bchctybob
    I’ve always liked those taillights and wondered why more people don’t use them on customs. They’ve gotta be getting hard to find now. Nice job......
  13. cshades
    cshades
    from wi
    i actually bought the remains of the quarter panels and lights at a swap meet and didnt know what they were from or what i was going to do with them. i decided i wanted a custom box for this truck and they fit what i was going for. i have lucked out and found enough lights to make a nice complete set of 4. most of the time the guys i have bought them from didnt know what they were for. it also helps that the reverse lights are the same housings as the tail lights.
    bchctybob and 5WINDOWJOHN like this.
  14. rusty1
    rusty1
    ...some of the war year trucks (41-5) used tin door handles, 2 peices of formed tin pressed together...
    5WINDOWJOHN likes this.
  15. 302GMC
    302GMC
    from Idaho
    And painted gauge cluster and dash trim, with a leather skirt around the gas filler in lieu of the rubber used until '41 ...
  16. 5WINDOWJOHN
    5WINDOWJOHN
    from SO CAL
    Going back to the front, is the chin under the grille the same on a 39\40? Also, how about the running boards from 39-46?
    Sent from my F-10XIPS using The H.A.M.B. mobile app
  17. cshades
    cshades
    from wi
    The chin is the same on 39-40 trucks as is the baffle from the chin to the support. i am not sure on the running boards. i think the 39 is different than the 40-46 but i will have to measure them when i get a chance.
  18. cshades
    cshades
    from wi
  19. cshades
    cshades
    from wi
    the running boards are the same from 39-46 according to the measurement i did over the weekend. finally got the 39 back in the shop.
  20. swade41
    swade41
    from Buffalo,NY
    The 41 door lock is still in the handle, it switched to the door in 42, also it seems the majority of 41's only have one wiper but nearly all 46's have two.
  21. cshades
    cshades
    from wi
    i have had some 41s with the lock in the door so i am wondering if it was a running change? the 41 cars had it in the door on both sides
  22. Stoked I found this thread! Its a gooder for info. I have some questions
    Will a '39 / '40 GMC hood fit a 46 cab cowl? Not worried about the latch as it will be kustom. Or can a '39 or '40 grill work on a later hood? Again its a kustom build.
    Where can a guy find parts? Tailgate, grill, tail lights...
    -Shiny
  23. cshades
    cshades
    from wi
    i am glad you like the thread. the 39-40 hood should fit the cowl on a 46. the 46 hood is a bit longer than the 39-40 hood, i dont know if the shape at the front of the 46 hood lines up with the 39-40 grille. tail lights are available new if you want stock type parts. they do repop grilles and tail gates i have not tried them so i have no idea how well they fit but if you are doing something custom that may work for you. other wise i just buy everything i find at the swap meet which these parts are getting to be less and less.
  24. oliver westlund
    oliver westlund
    How about side gl***? One set of doors i have just have gl***, other set has metal around the gl***
    bchctybob likes this.
  25. tb33anda3rd
    tb33anda3rd
    39 has hinge mounted rear view mirror, 40 they were mounted to the door, like the above photo.
    I always thought that the gmc trucks had the metal frame around the side gl*** and chevy did not. not sure because any one changing a window could have just deleted the frame.
    bchctybob and oliver westlund like this.
  26. cshades
    cshades
    from wi
    39-40 doesnt have a frame around the window. the 41-46 do. the size of the gl*** is different. i am not sure why they added the frame other than to protect the gl***. i havent had any problems with no frame except my 40 has a crack in one corner on the bottom that i noticed this summer after a kid ran into the door with a bicycle. if you have a 41-46 truck and want the frameless look all you have to do is order the 39-40 gl***. the mount channel is the same
    oliver westlund and tb33anda3rd like this.
  27. cshades
    cshades
    from wi
    1939-46 all had hinge mounted mirrors on 1/2 tons as far as i know. the bigger trucks either mounted on the hinge with a long arm or on the door. i do not know if the door mounted mirrors were factory or not. another interesting thing about outside mirrors on these trucks is there was a factory right side hinge mount mirror available. i have not seen a lot of these so i dont think they were very common. i did buy a pair of oe mirrors that had been chromed on ebay. had to pay a fair amount to get them but havent seen a pair or a right side available since.
  28. tb33anda3rd
    tb33anda3rd
    my 39 GMC has frames around the gl***, I believe the original doors. GMC were always a little different.
  29. cshades
    cshades
    from wi
    i have not had any gmc stuff as far as i know so you could be correct on that. chevy may have decided it was a good idea after using it on the gmc. i did think of something else on the outside mirrors. the left top hinge is drilled for a small screw to hold the mirror in the correct position on the hinge. the right one was not drilled in 1939-40. i know the 46 hinges are drilled on both sides because i was just searching through my hoard trying to find some really good hinges for the 39 i am doing now. i ended up using a 40 hinge for the right side and drilling the hole for the screw. it was kind of a pain in the rear because there isnt really any room to make a mistake on the hole location in relation to the threaded hole in the mirror bracket.
