Hot Rods Running off the rails
Discussion in 'The Hokey Ass Message Board' started by Bubzy, Jun 11, 2020.
  1. Bubzy
    Bubzy
    from Detroit
    I think I've mixed and matched my way out of power. Here's what I have:
    Stock bottom Gen 1 SBC 355
    Flat top pistons
    Dart Iron Eagle 215 2.02/1.60 heads 64cc
    .041 head gaskets
    Comp Cam xe268h cam
    Hydraulic lifters
    Comp Cam 1.6 roller tip rockers
    Dual plane intake with duel 600 cfm vac secondary
    HEI with MSD 6al
    Not sure on compression ratio or hp
    I feel like this is not the best setup. Like it's not the best match of parts. Is this the best cam/head match? Any advice will be taken seriously. Thanks
  2. Rex_A_Lott
    Rex_A_Lott
    You need to know what you want to do with the car, you can't have it all.
  3. Budget36
    Budget36
    Deck will tell you about CR.
    Funny thing, saw your ***le of the post.
    Got a Talking Heads flash back....Buring Down the House....
    Oh well:)
    Ports seem a bit larage (***ume you mean 215 CC) more suited to higher RPM range IMO, for your cam..., max CR would be in the high 9's, maybe low 10's but depends on where the pistons are at in the hole. Could be like my buddy's engine, flat top 4 valve reliefs....050 in the holes...not good...we working on it.
    Regardless, with cam choice you have, I think you have too much head.
  4. Bubzy
    Bubzy
    from Detroit
    Thanks for the response. Looking for 425+ hp and getting all components to work with each other
  5. squirrel
    The components all have to work with the rest of the car. A HP number tells us nothing about what you want to do with the car. Go racing? Putt down main street? Drive to work every day? Drive to the drive in on Friday night? Go on a three thousand mile trip? or what?
    You can get a sticker and have 425 hp pretty cheap, you know :)
    raven, GordonC, firstinsteele and 3 others like this.
  6. Texas Webb
    Texas Webb
    Can't have too much head:)
    mkubacak, Budget36 and Bandit Billy like this.
  7. Bubzy
    Bubzy
    from Detroit
    Cruiser with limited strip time. Like to get tossed back in the seat cruising too. Running motor through turbo 400 with shift kit to a Ford 8.8 3.73 gear. I'll check piston depth.
  8. squirrel
    I'd put a bigger cam in it, perhaps 230ish duration at .050, and make sure it has 2500 or so stall.
    Won't make 425 hp, but you'll have fun with it.
  9. lippy
    lippy
    from Ks
    I'm with Jim, cam is pretty small. Lippy
  10. Budget36
    Budget36
    Before I polished it off, mine said Turbo Jet 390 HO
    Good times!
  11. BadgeZ28
    BadgeZ28
    from Oregon
    Heads are not a good match for your combo. A set with 180-195 cc would be better. Cam is small as well. Some of the cam manufactures offer advice on cam selection based on the combo and car details. You might also look at the specs of the Edelbrock top end kits which are developed to work well together.
  12. jaracer
    jaracer
    3.73 gears with and automatic sounds like a pretty low gear with a THM 400. I put a set of 3.89 gears in a 65 Galaxie and it would be in high gear almost before you got through an intersection. For a street cruiser I wouldn't go lower than 3.50. You will have plenty of go when you jump on it.
  13. Bubzy
    Bubzy
    from Detroit
    So what am I actually losing with my setup? Comp Cams recommended the xe284h cam with the dart 215cc heads. Would the gain be worth the change. Thanks guys
  14. Budget36
    Budget36
    Depends what your actual CR is, you've chosen a fairly large intake port head. Generally this leads to more cam and CR than you may have.
    I ***ume the heads are off still? If so, see where the pistons are at vs the deck. Dial indicater on a mag base through HF will take 40 bucks or so out of your wallet, but give you an idea of things.
  15. Bubzy
    Bubzy
    from Detroit
    Figure compression about 9.8:1
  16. Bubzy
    Bubzy
    from Detroit
  17. squirrel
    how much of your money are we allowed to spend?
  18. Bubzy
    Bubzy
    from Detroit
    Trying to make things work with parts I have or with as little additional money as possible. Not being cheap, I just dumped a lot of money into body and paint. I called Comp Cams and the recommended going with the xe284h cam for the heads and converter I have. Cam is 240/246 duration @ . 050, ls 110*, 540/546 lift with my 1.6 rockers. It will take operating range from 1500-5500 to 2300-6500. I think this will be a less expensive way to go over buying new heads. But I want to do it right even if it costs more. Will all this work together? I'm not much of an engine builder as you can tell. Me friend that built the motor p***ed away and I'm kinda scrambling. I really appreciate your input.
  19. squirrel
    That sounds like a reasonable cam to use. Might want to look into valve springs, to make sure what you have, and what you need to work with the cam, and what will fit in the heads with the current valves/retainers/installed height.
    olscrounger likes this.
  20. Bubzy
    Bubzy
    from Detroit
    Thanks. Will this be a better way to go or keeping my current cam and buying budget 195cc heads
  21. squirrel
    Depends how much HP you want. Bigger heads, bigger cam, drivetrain set up to use higher RPM, you'll go quicker. If you want a milder engine, then the cam you have now, possibly with smaller heads, milder gearing, etc would be the way to go.
    Earlier you said something about 425 hp...if you really want 350 tops, then the cam you have now is good.
  22. raven
    raven
    You have to match the velocity of the heads to the cam, rear gear, car weight and how you want to drive. Listen to Squirrel, he’s pretty sharp...
    r
  23. hemihotrod66
    hemihotrod66
    Put a supercharger on it...This compensates for any flow problems.... Will make a bad head and cam better...
    squirrel likes this.
  24. 6sally6
    6sally6
    If it kinda "soggy" on the bottom end..........advance the CAM timing about 4/6 degrees. This shifts the power range down LOWER on the RPM scale. (even if the Comp Cam is advanced when ground) If the block is not zero decked piston to valve interference should not be an issue.
    Another thought......(if you won't get the deck milled) have the heads milled as much as you can(ask your machinist) to get that CR up!! Aluminum heads AND a snotty cam (like yours) just screams for 10.5/11:1 CR!
    THAT would help your low power problem. Compression is power.......simple.
    6sally6
