Projects Very best top!
Discussion in 'Traditional Hot Rods' started by Willywash, Jun 9, 2020.
  1. Willywash
    Willywash
    Can anyone recommend the very best filler for top of 31 A coupe ? I would like to buy one that a novice could tack down and fit correctly. Am I asking too much or is there one manufactured that is superior other others?
  2. sloppy jalopies
    sloppy jalopies
    I used a dodge club cab roof... I did not want ribs... sat flat … tacked it down using a screwdriver...
    Vic Walter likes this.
  3. Jalopy Joker
    Jalopy Joker
  4. When i built my 30 coupe, i used a section from a 61 bubble top.
  5. oldschool59
    oldschool59
    Walden Speed Shop !
  6. sloppy jalopies
    sloppy jalopies
    if new to this, be very careful when you want to separate the skin from the inner structure...
    if you use a chisel or putty knife the tool you use will score through the skin [shows]…
    to do it again I would get something that "ate" the adhesive... then separate them... HIH.
  7. stanlow69
    stanlow69
    As I read it. I got the impression he wanted a vinyl type top. But I interpret things different than most people.
    clem likes this.
  8. clem
    clem
    You are not alone, I also understood that he wanted a soft top. Let’s wait and see what he says....
    stanlow69 likes this.
  9. sloppy jalopies
    sloppy jalopies
    sorry, tunnel vison... I read tacked and figured it meant tack welded...
    but a cloth top also gets tacked on...
  10. clem
    clem
