Technical Car won't shut off with battery cut off switch
Discussion in 'Traditional Hot Rods' started by 55onefifty, Jun 15, 2020.
  1. 55onefifty
    55onefifty
    I put a battery cut off switch on my car when I built it 5 years ago. I would like to race the car at the local Friday night street car drag races but the track will not let me race the car because the switch will not shut the car off. I took the Alt power wire out of the harness and ran a new power wire from the cut off switch to the Alt and also put a diode in the Alt feed wire that goes to the switch. The car (1956 chevy) has a Ron Frances wire kit and a 3 wire 10SI Alt with a built in voltage regulator.
    Any one have any ideas as what I did wrong or what I can do to fix this. If I unplug the Alt and then hit the cut off switch the car dies.
    Thanks in advance for any help someone wants to offer.
  2. 55onefifty
    55onefifty
    The battery is in the trunk and that is why I have to have the cut off switch in case there is a problem the track crew can shut the car off.
    jimmy six, Damon777 and Boden like this.
  4. jimmy six
    jimmy six
    You need a 2 position switch that breaks the battery and the alternator feed. Looks like the switch you have with 2 smaller studs. Problem is most guys run the feed wire from the alternator to the plus wire from battery that you have on your starter solenoid. Now it needs to go back to the switch you mounted outside the trunk.
  5. Truck64
    Truck64
    from Ioway
    Usually people can't get their stuff to start.
    Picky picky picky!
  6. 41rodderz
    41rodderz
    from Oregon
    :p
  7. Hotrodmyk
    Hotrodmyk
  8. tb33anda3rd
    tb33anda3rd
    unplug the alternator when you get to the track.
  9. 1971BB427
    1971BB427
    from Oregon
    Put a relay on the alternator 12v. wire and power the relay from the battery switch. This way when the switch is turned off, the contacts on the relay also open, killing the alternator from supplying power to the car.
    Jibs, deathrowdave, Blues4U and 3 others like this.
  10. sloppy jalopies
    sloppy jalopies
    I ground the alt's ground wire through shut off switch, shut off switch on the battery's ground cable...
    HotRod33 and 67L36Driver like this.
  11. Killing power to the alternator should not kill the engine you need to kill the power going to the distributor. I was taught on older cars to start it and take the positive off the battery and if it stays running the alternator is working. So are you wanting to isolate the battery or have a kill switch. may be I missed some thing here. good luck with that.
    Peter Nowak likes this.
  12. 1971BB427
    1971BB427
    from Oregon
    It's a Chevy. They don't have a ground wire on the alternator. They ground through the alternator frame.
  13. 1971BB427
    1971BB427
    from Oregon
    NHRA wants both. They require a battery switch if the battery is in the trunk, and that switch must be readily accessible, and needs to isolate the battery, and kill the engine.
    Baron likes this.
  14. RmK57
    RmK57
    I just ran another 8 gauge cable to the alternator from the cut off switch.
    First time I went through tech they checked it. They asked to run the engine at a high idle and then he hits the kill switch.
  15. just asking why can't you put the disconnect on the ground? so when it's turned off their is no ground and that kills every thing.
  16. Gus68
    Gus68
    from Minnesota
    For what it's worth. If you have an electric fan and it's running when you kill it, it will back feed like a small alternator.
    Baron, rod1, egads and 2 others like this.
  17. ct1932ford
    ct1932ford
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    Excellent idea !
    Truckdoctor Andy likes this.
  19. fabricator john
    fabricator john
    from venice fl.
    they make a kill switch that the charge wire runs through just for this purpose look at em at summit or jegs they have two big posts for battery and two lil ones for the alt hot lead , common on drag cars ,,work like a champ nhra says ya gotta do it that way ,,
    fabricator john
    miss you dad
  20. sdroadster
    sdroadster
    Do Not put the switch disconnect on the ground side of the battery. If you forget, and attempt to start the car with the switch off, the system will attempt to achieve ground through your MSD Box or other accessories. All of these items will smoke when 30 amps is drawn through them.
    rod1, HemiDeuce and Hamtown Al like this.
  21. Blues4U
    Blues4U
    from So Cal
    That won't kill the engine
  22. squirrel
    I put the battery under the hood, no need for a cutoff switch. But that might be too simple of a solution for you.
  23. Blues4U
    Blues4U
    from So Cal
    None of those you posted will kill the engine. They may prevent it from starting, but once running they will continue to run. You need to disconnect the positive source from the alternator if you want to kill the engine.
  24. the first will cut power to the coil, the second just cuts off power from the battery, and you are correct on that one. The last one cuts power off to the fuse panel, coil and alt
    if this is for a 3 wire alt, would this switch wiring work, I can see the issue now for a one wire?
    if power is cut from the battery and the coil, can the car still run wired like this diagram?
    I think your correct on the 3rd one. read the entire thread the diagram came from, the same comment you made came up.
  25. Bandit Billy
    Bandit Billy
    Use this. I have one on all 3 of my cars. I run the battery out to the fuse panel on one side. Alternator into to the battery on the other. It kills everything instantly.
  26. like this
    currently wiring a truck so Im looking up info.
  27. Mimilan
    Mimilan
    You don't need a fancy 4 post cut off [a simple on-off 2 post will do]
    The Charge wire is looping to the ignition keeping it running. A common problem!
    You need to run the charge wire from the Alt all the way back to the battery [or the battery side of the cut-off switch.]
    For safety add a fusible link to this wire [close to the battery]
    If you're constantly working around the Alt [and risk shorting screwdrivers etc] add a decent blocking diode into the charge wire
    It will charge but won't discharge
    Also by doing it this way, If the battery is cut-off at rpm it will absorb current until the engine stops [preventing damage to the regulator etc]
  28. Blues4U
    Blues4U
    from So Cal
    The first one is incomplete, I can't tell what it's doing, and I'm no stranger to electrical schematics and diagrams. And the 3rd one doesn't fully load on my computer, I'm left looking at some ****tered symbols, but it looks to me like the alternator is still connected into the mail electrical feed circuit, supplying voltage to the fuse panels.
  29. Blues4U
    Blues4U
    from So Cal
    There you go.
    here is a better pic, the OP was questioned that the alt would keep it running. I can see it on a one wire but wonder on a 3 wire alt.This simple diagram looks like a one wire, so its shouldn't work, Im gonna delete it
    Blues4U likes this.
