Technical 32 Ford Coupe Heat & A/c
Discussion in 'The Hokey Ass Message Board' started by JimMartley, Jun 14, 2020.
  1. JimMartley
    JimMartley
    I am new to this place and took delivery of my first drivable Hot Rod, a fibergl*** body 32 Ford 3 window coupe with a 3" chop. I was wondering if anybody has any suggestions as to what to use for A/C and heat in this car. I can't seem to find a "search" function on here so I apologize if there actually IS one...
  2. X38
    X38
    Top of the page ;)[​IMG]
  3. greybeard360
    greybeard360
    Right at the top of the page... The little banner with the magnifying gl*** on it.
  4. TrailerTrashToo
    TrailerTrashToo
    Search function is the magnifying gl*** symbol at the top of this page.
    Go here and look around a while
    https://www.vintageair.com/
    They are more likely to have a condenser that fits well in front of your radiator.
    The evaporator will depend on how much space is available behind and/or under your dash. There is not a lot of space available in a 1932.
  5. woodiewagon46
    woodiewagon46
    from New York
    I know one of the companies is called Vintage Air, sorry I don't have more info.
  6. JimMartley
    JimMartley
    Thanks for all your answers!!! :)
  7. pprather
    pprather
    I have the Vintage Air Gen II Mini heat/air in my deuce. It does a good job for a cabin of that size.
    Phil
    olscrounger likes this.
  8. Gman0046
    Gman0046
    The only company to use in my estimation is Vintage Air. They have been in business over three decades. Made in the USA with excellent technical support.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I installed a Vintage Air heat & air unit in my sedan last year. HRP
    mgtstumpy and olscrounger like this.
  10. Almostdone
    Almostdone
    I agree with others thus far... Vintage Air. I’m putting a Gen II mini in my Model A right now. It fits, parts are top notch, there is room for the condenser and drier/receiver in front of the radiator.
  11. rjordan
    rjordan
    I'm putting Vintage Air in my 31. We have been installing their units for years and they work. The one in my 56 is better than my truck a/c.
  12. Super Streak
    Super Streak
    from Florida
    I've got a Vintage air/heat unit in my '30 model A coupe. It's tight under there but it fits.
  13. '49 Ford Coupe
    '49 Ford Coupe
    Not so fast on the Vintage Air. If I recall, all of their systems are "blow through", meaning that the fan intake is right there three feet from your ears. Old Air Products is in Fort Worth, and their base design is a "draw through", meaning the fan is on the leaving side of the evaporator coil. This allows MUCH more evenly distributed air velocity through the evaporator, making it much quieter and giving a tad more capacity in a smaller package. So, if you don't mind a noisy and larger unit, spring for the Vintage Air. I didn't and I would get an OAP again. Controls, etc. are very similar. Do your homework before shelling out your cash. I'll be glad to answer any other questions...
    When mine was delivered, I was slightly concerned that it looked so small, but after installing and getting everything running and finishing my '49 Ford Coupe, it has no trouble cooling at 100 degrees outside. ...
    https://www.oldairproducts.com/
  14. oldsman41
    oldsman41
    Vintage air easy and small
  15. JimMartley
    JimMartley
    WOW!!! Thanks for the tip on "Old Air Products". I think I found a unit that is small enough to mount on my Firewall and NOT look too bad, The Hurricane IP-2100. I can't get over how much smaller this unit is than anything I have been looking at from Vintage Air. My car already has the compressor and Condenser that was installed by a previous owner and an "under Dash unit was supplied with the car but it looks like it has seen better days and is in ROUGH shape, not to mention it is UGLY!!
    '49 Ford Coupe likes this.
  16. JimMartley
    JimMartley
    Which unit did you install? I am ***uming it was a "firewall mount. Any chance you have pictures of the unit in your car?
  17. '49 Ford Coupe
    '49 Ford Coupe
    Study the configurations very closely, build a cardboard replica as accurately as possible to determine line locations and discharge air configuration..do you have a fresh air supply?? I used a marine bilge fan...Here is a link to one of the galleries on my website. Scroll down for a few pictures of the installation..
    https://49fordcoupe.smugmug.com/Finishing-up-Details/
    TrailerTrashToo likes this.
  18. OLDSMAN
    OLDSMAN
    Your best bet is to go with vintage air, IMHO they have the best units out there. The mini is big enough for your Duce. Their tech support is fantastic, you just can’t go wrong with them.
  19. HOTRODPRIMER
    HOTRODPRIMER
    It's the Vintage Air gen II heat & air unit, It's compact enough that I can still use the original cowl vent.
    That's all I got. HRP
  20. Gman0046
    Gman0046
    I bought the largest Vintage Air unit that would fit under the dash of my 60 Pontiac Bubbletop as its like trying to cool a green house with all that gl*** it has. I built a custom panel that extends the lower dash and houses the controls, vents and engine gauges. This unit works extremely well cooling that big car and it makes no noise what so ever. I can't even see it or hear it running. The cold air coming out the vents tell me the A/C is running not any noise. I've probably installed at least 10 or 12 other VA units over the years and NEVER had any noise, fitment or cooling issues. If the units I buy are not "sure fit" I buy the largest unit that will fit in the space allowed. I like it cold. If I were a betting man, I'd venture to say VA has well over a 95% share of the aftermarket air conditioning market. If VA units were noisey, defective, inefficient or had design deficiencies I'm sure this wouldn't be the case and another company would be the air conditioning King Of The Hill. VA has been manufacturing USA made A/C units for going on four decades. There technical support is outstanding. If you want to save yourself a lot of grief stay away from Southern Air Products they are junk. I once ran across a car with an Old Air unit and thought it was quality piece and have nothing bad to say 2a1ZQIP4SEeKb+SQT6I0jg.jpg about them.
    David Gersic likes this.
  21. JimMartley
    JimMartley
    Is the Vent/control Panel in this picture an off the shelf product of Vintage Air?
  22. X38
    X38
    Vintage air have a website:
    1932 Ford Gen II Under Dash Control Panel w/ Louver
    Part #: 492008
    Price: $60.00
    JimMartley likes this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir, I ordered it & the heat/air unit from Summit. HRP
  24. David Gersic
    David Gersic
    from DeKalb, IL
    I have a Southern Air unit. It’s ok, but if I were buying, I’d buy Vintage Air.
    How does that go again? “Ask the man that owns one.” Something like that.
  25. southcross2631
    southcross2631
    I installed a southern air unit in a 57 Fairlane and it would not keep the car cool in florida summers .
