Technical Got her to start but won’t idle
Discussion in 'The Hokey Ass Message Board' started by Christie, Jun 6, 2020.
  1. motorplex88
    motorplex88
    Since a new fuel tank is to be installed and your have cleared the line from the tank to the fuel pump, I would refrain from putting a filter between the tank and pump. Mechanical fuel pumps will "push" fuel to the carb better than "pull" fuel from the long run to tank. I have seen instances that the engine will idle and operate ok at low speeds but starve for fuel under a load or at hiway speeds. With all the crud gone from your system I don't see the need for a filter before the pump and will increase fuel flow to the pump.
  2. Ebbsspeed
    Ebbsspeed
    I'd still run a filter. Millions of vehicles had them installed between the tank and fuel pump with nary an issue. What starts out as a clean fuel system doesn't always stay that way, and a filter on the suction side of the pump can keep any debris from going where it doesn't belong.
    Christie and Barrelnose pickup like this.
  3. motorplex88
    motorplex88
    You are correct. There is a good many old vehicles running an inline filter right after the tank. Merly saying that it is possible for them to impead fuel flow. I always liked the screw on jars on the fuel pump with replaceable filter. Easier than crawling under the car also. It's a personal choice.
    Christie likes this.
  4. 6sally6
    6sally6
    If 'yours is like mine'......the gas tank is higher than the fuel pump so therefore like most liquids.......gas-runs-down-hill!
    It will run out of the fuel line if its not attached to the fuel pump. IF it runs out it must have a clear line! I would do the KISS approach and install a fuel filter between the fuel pump and carb.
    6sally6
  5. I mentioned the filter before the fuel pump only because of the possibility of **** in the line and the tank. **** could get into the pump and ****** the diaphragm and checks leading to more trouble.
    With a new tank and clean, flushed line, all should be good and a filter between the pump and carb should do. Just my 2cents.
    Truck64 and Christie like this.
  6. Christie
    Christie
    This is the longest week ever. Lol [emoji23] the tank should be here tomorrow *fingers crossed* and I’ll be driving by Saturday [emoji7] and I’ll be sure to take the advice about the brakes! Thank you bunches!
  7. 41rodderz
    41rodderz
    from Oregon
    Didn’t want to spoil the party before but make sure your sending unit is all spiffy like. Look over pick up tube for any build up and any rust at top area. I have a pin hole before that added to the fun . Glad you will be driving soon .:)
  8. Christie
    Christie
    I got a new one awhile back , so I’m hoping it will register on the gauge correctly.
  9. Christie
    Christie
    https://m.youtube.com/watch?feature=youtu.be&v=aKiRdDlnuNU
    https://m.youtube.com/watch?feature=youtu.be&v=cU4Ds81pE68
    She’s running!!!! I can’t thank you all enough for all your patience, kind words, knowledge and motivation to get her going again!!!
    I learned so much!! I however have one issue that wasn’t there previously. The generator light is staying on. Not sure why it would do this?? . That light would only come on when the car would die out, and now it’s staying on nonstop.
  10. Christie
    Christie
  11. rusty valley
    rusty valley
    go girl !!!
  12. Truck64
    Truck64
    from Ioway
    The GEN light will illuminate to tell you that there is a problem in the charging system. It is only supposed to light when first starting the engine - along with the OIL light - to prove that the bulbs aren't burned out. That would never do. It might sometimes flicker dimly at low RPM.
    If it lights up otherwise, it means there is a problem. It could be as something as simple as the generator carbon brushes are stuck in the holders. But whatever the cause, that light is letting you know the battery is not being charged. It will last quite a while, so long as high current items like the headlights aren't used, but we're talking hours or maybe days, not weeks, and then the battery will be stone dead. Do you have a battery charger? Nod your head "yes"...
    Watch especially for a GEN light that stays lit with the engine off - even key removed, meaning all the time.
    Normally the voltage regulator cutout disconnects the battery when generator voltage output falls below charging voltage, or whenever engine is shut off. If the voltage cutout relay sticks, the battery voltage will backfeed into the generator windings and let all the magic smoke out. Disconnect the negative battery terminal right away if this situation ever occurs.
    Christie and loudbang like this.
  13. Black Panther
    Black Panther
    from SoCal
    Your generator probably lost its magnetism during the time your car sat..by moving a couple wires around you can "re polarize" your generator and i bet it'll start charging again. Each old manufacturer had their own little process so check into that. Im sure someone will chime in here. Same exact thing happened with me and a 61 Olds I had.
  14. loudbang
    Fan belt tight?
    Christie, DIYGUY and lostmind like this.
  15. fresh hops
    fresh hops
    Do you have access to a multimeter? Most of the test will involve using one to measure actual values.
  16. bobss396
    bobss396
    Give the polarization thing a go, really simple and you can look it up online easily. If the generator and regulator are old and of unknown age, best bet is to replace both. Good to know of a local auto-electric shop, they can rebuild yours and have it back to you in a few days. New regulators may or may not be in the parts stores, but you can have one in a few days online too.
  17. F-ONE
    F-ONE
    from Alabama
    Both the generator and regulator are simple, easily repairable or at least easily serviceable machines.
    Here are some simple things you can do...
    Check the wiring. High resistance in the wire will make the regulator think the battery is fully charged. Thus it will not charge.
    Check all wiring connections. Get a little piece of fine sand paper and clean each and every connector, nut and washer.
    Check to make sure the wire is in good order. Sometimes these wires have been “ farmer repaired” with the wrong gauge wire and poorly done connections.
    Make sure the engine is properly grounded....if not correct and clean connections there.
    Check and clean all connections to the regulator as mentioned above.
    The regulator should ground through the mounting screws. Remove the screws and clean this up as you did all the wiring connections.
    Carbon build up on the regulator contact points can cause this issue. Take off the regulator cap and clean the contact points. Simply pull a little strip of fine sandpaper 400 or so through the contact points.....until the paper pulls clean.
    There’s videos about this on you tube.
    Most of the time a simple clean up of connections, contact points and grounds will fix problems like this on a car that’s been inactive for a while.
  18. Christie
    Christie
    Thank you guys! I will check on the fan belt and try to repolarize [emoji16] and gonna put the battery on the charger too, probably zapped the hell out of it driving it without generator charging bit. You guys are awesome [emoji173]️
  19. lostmind
    lostmind
    F-One has good procedures. Disconnect the battery ground cable first. Very easy to short out a " hot" wire.
    loudbang and Christie like this.
  20. Truck64
    Truck64
    from Ioway
    It's easy to slip over the line into silliness about this kind of stuff but the voltage regulator manufacturers, fwiw, were very insistent (with bold type, cautions and warnings and everything) that is not the way to go about it. The claim is that using sandpaper will ruin the contact faces in short order. It will get things going again by the side of the road.
    They recommend dressing the point faces with small curved jewelers files, and running them in a specific direction and cleaning with Carbon Tet. I found Naptha (Coleman stove and lantern fuel) is a good no-residue subs***ute and dragging a crisp brand new dollar bill soaked in naphtha through the closed points will keep the crud off. ($20 bill for those living in Alaska and California)
    This kind of stuff is why Alternators are popular.
  21. The smile on your face speaks volumes. Your determination and want to learn got your car back up and running, and your problem with the charging system (with the help from above posters) will soon be a thing of the past. Your level of motivation is inspiring. :)
  22. F-ONE
    F-ONE
    from Alabama
    Everything you posted is absolutely correct. The manuals point out that the contact points wipe in a certain direction. Filing across this direction can damage the contact points and shorten point/regulator life.....
    I agree with what you say and I'm glad you explained it in more detail.
    But....
    A good jewler's file may be difficult to find. When you do find one....using it incorrectly can cause a problem as mentioned.
    If this was my problem, this is what I would do if I still had charging problem after checking the wires.
    Personally I feel that abrasive paper technology has improved quite a bit since these regulators were in everyday service. A file may be too aggressive especially for a novice.
    It's my opinion that with some high quality wet dry paper of a very fine grit.....say 600-1500 may be the most conservative route to go in my opinion.
    Reviewing this topic....I would probably use 800-1000 grit very conservatively.
    My goal would be to just remove the carbon and not get into refacing the metal.
    I would follow up with the Naptha/zippo/Coleman fuel with a dollar bill as Truck64 mentioned.
    Below is video....
    I'll admit I cringed when he dressed some of those in a circular motion but all in all I think he pretty conservative with it...(tractor)
    Here's another concering british cars but it applies....
    Simple tests for the generator..British car
    Generator rebuild...(tractor)
    Chrysler master tech Generator/Regulator service 1948 filmstrip grainy but lots of info....
    Christie and Truck64 like this.
  23. Christie
    Christie
    Gotgas, das858, alanp561 and 9 others like this.
  24. fresh hops
    fresh hops
    Don't you love it when plan comes together.
    Go for a drive again and again until you have it completely sorted, don't be to surprised if a new hick up pops up.
    Does it drive and stop straight, how about the last time oil has been changed and the car serviced?
    Cars that have been parked for a while don't always like to go back into service without speaking out a bit.
    Just remember you got it back on the road, enjoy the moment and you will be able to fix it again if needed.
    Glad you are having fun.
    Great work!
  25. 41rodderz
    41rodderz
    from Oregon
    I need a tattoo like Christie has . :):cool:
  26. King ford
    King ford
    from 08302
    Way to go Christie! The satisfaction of fixing her YOURSELF sure is sweet isn't it?!...and we NEED more pics. of your car!....( HAMBers LOVE PICTURES!!!)
    Christie and 427 sleeper like this.
  27. Christie
    Christie
    Well since she’s running now, I’ve switched gears and have been doing other odds and ends stuff to her. She hasn’t had windows in her since I got her 13 years ago so I’ve been putting them in one by one. My brother made me v8 speaker grills, so I cut into my door panels to put those in too. Oh and been putting some of the trim pieces on too. [emoji16] (that’s kicking my *** currently [emoji23][emoji23]) IMG_0133.JPG IMG_9263.JPG IMG_9265.JPG IMG_9777.JPG
  28. Christie
    Christie
    And please don’t judge my panels. ‍♀️[emoji23] I’ve never done upholstery work before, so I know they have tons of flaws. Lol she’s so imperfect, I have a rear window in but am missing the corner window since it’s cracked, lol, so I’m basically putting things that I DO already have onto her, it’s a mishmash situation because of that but oh well. One piece at a time right? lol I love her in all her imperfect glory though [emoji16]
    loudbang, 427 sleeper and 47ragtop like this.
  29. patsurf
    patsurf
    if that's your first attempt-you should already be doing this for a living!!
    Christie, loudbang and 427 sleeper like this.
  30. Christie
    Christie
    Awww![emoji5] that’s so kind! I see soooooo many flaws [emoji20]
