Technical Do Solid Lifter Cams go flat?
Discussion in 'The Hokey Ass Message Board' started by Elcohaulic, Jun 18, 2020.
  1. Elcohaulic
    Elcohaulic
    In 45+years of messing with cars, I have never heard of or saw an engine with solid flat lifters go bad. I've been mainly into Chevys, Pontiacs or Oldsmobiles..
    I wanted to know if anybody ever saw or heard of one going bad?
    With all this trouble of cams going bad in the recent years maybe this is the answer..
    Thank you,
    Jeff
  2. N2hotrods
    N2hotrods
    Solid lifter cams go flat. You just don’t see as many of them used as the hydraulic flat tappit.
  3. Elcohaulic
    Elcohaulic
    I don't doubt it but I have never saw or heard of one going bad.. Jeff
  4. Ebbsspeed
    Ebbsspeed
    They do go flat, but since there is probably 1 solid flat tappet cam for every 50 hydraulics it's not a surprise people never hear of them going flat. Proper valve clearance adjustment is real important on a solid lifter cam, and if it's too loose the valvetrain is hammered hard. Lobes are ground with a gradual takeup ramp that cushions the impact of the lobe to lifter interface during the early part of the lift. This gradual ramp takes up the valve clearance before the aggressive lift part of the lobe is reached. If the valves are set too loose the lifters are hammered against this aggressive lift section of the lobe, causing extreme point loading which may exceed the capabilities of the oil to prevent metal-to-metal contact. This being the case, the cam will go flat in short order.
  5. cpraceman
    cpraceman
    from walls, ms
    Just be sure to use the proper break in oil with an additive and proper RPM and time.
    You should have no issues.
  6. LAROKE
    LAROKE
    Hasn't happened to me yet, but at least two of my friends have lost cams in their Jimmy 302's due to a bad diaphragm in the mechanical fuel pump spraying fuel on the adjacent cam lobes, washing the lube away.
  7. buffaloracer
    buffaloracer
    from kansas
    They can but I think that most people that run them pay more attention to detail .
    Pete
  8. Any camshaft can flatten a lobe or two. Roller cams are the least likely and flat tappet cams are the worse . Solids or hydraulics are the same in the flattening dept.
  9. In my world, the B and C ***mins use flat tappet solid cams and large face mushroom tappets, and I’ve replaced a few over the years due to flat lobes. I’ve also replaced a bunch of roller cams that have gone flat. Usually in the case of flat roller cams, the axle bearings on the roller fail and then the tappet or follower takes out the cam.
  10. Blues4U
    Blues4U
    from So Cal
    Yeah, it almost seems like you exchange 1 failure point for another with roller cams.
  11. sunbeam
    sunbeam
    I had a 62 ford 375 hp 390 that had a cam go flat on a exhaust lobe.
  12. Ericnova72
    Ericnova72
    from Michigan
    There is no difference between the cam cores for flat tappet solid lifter and flat tappet hydraulic lifter. Only difference is the cam grind profile itself, solid cam grinds have a lash take-up ramp.
    So both are just as likely to go flat or survive, it has noting to do with what guts are in the lifter.
    most problems come down to the majority of the hydraulic cam purchasers are looking for the easy way out or least amount of effort, and don't do their homework as far as prep and the break-in process.
    Get into some of the modern aggressive circle track solid cam profiles and they often will be showing wear at the end of a season and need replacing, despite the best maintenance schedule and upkeep, simply because of the spring pressures they need to run are right at the maximum a flat tappet can handle.
  13. Atwater Mike
    Atwater Mike
    I had friends/***ociates with 406" Ford FEs. More than 3 developed flat cams,
    I joked that with the noisy valve train those monsters had, the only way you'd detect a flat cam would be the performance falling off...
    Mine was a 427 side oiler, in my '54 Ford Coupe. I adjusted valves regularly, for fear I might be next!
    loudbang and mad mikey like this.
  14. mad mikey
    mad mikey
    In a word YES, the can wipe out.
  15. Stan Back
    Stan Back
  16. Pete1
    Pete1
    from Wa.
    Giggle, Chortle, GUFFAW!! That is the best description I have heard in the 67 years I have been in the cam business..
    THANKS.
  17. roseville carl
    roseville carl
    now thas funny right there.......................
    stillrunners and loudbang like this.
  18. Elcohaulic
    Elcohaulic
    LOL!! Good one..
    I see more rollers go bad than anything else..
  19. bschwoeble
    bschwoeble
    Solid lifter cams are meant for those who like to tinker or who grew up adjusting valve lash. People today just want to set it and forget it. It would be interesting to know how many people can use a feeler gauge to set valve lash, especially on an engine that is running.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Im guessing not many !
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    " additional money" yea , approximately $550 additional money , in dome households , that buys a lot of groceries !! Oh , that's just for cam & lifters
    Elcohaulic likes this.
  22. sunbeam
    sunbeam
    Unless you are at extreme limits solid cams do not require frequent lash adjustments. It was some time in 1958 that Ford cars even had hydraulics.
  23. LAROKE
    LAROKE
    I do both my inline sixes but not while it's running. I get it up to operating temperature, put #1 cylinder at TDC and adjust half the valves, put #6 cylinder at TDC and adjust the rest.
    It will be similar when I rebuild the 322 Nailhead as I have an Isky E3 solid lifter cam and FACTORY EXPORT RACING rocker arms adjustable for that build.
    lothiandon1940 likes this.
  24. seb fontana
    seb fontana
    from ct
    Hey I check my hydraulics, every twenty years or so.:rolleyes:
    Baumi and ekimneirbo like this.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Obviously , you and I don't share a value system ...
  26. 56don
    56don
    And all Y-blocks had mechanical cams. I grew up adjusting the valves on my first car with a y-block. Not that hard. I did it more often than needed because I liked playing with it.
  27. sunbeam
    sunbeam
    On low oil rocker shaft motors I almost always set running on oil throwing rocker stud Chevys not so much.
  28. Joe H
    Joe H
    I had one that wore out, all the lobes were down on lift, but it was pretty even wear. It had over 2000 p***es at the drag strip, about 15 years worth. I was to poor to change cams over the years. 455 Pontiac with Wolverine Blue Racer cam.
  29. bschwoeble
    bschwoeble
    Almost fifty years ago, a kid would come by the garage with his "59" Biscayne "348" car. He asked how to adjust valves and not get an oil bath. I mentioned a couple ways. He said he found that when he drains the oil and starts the engine, he can adjust the valves and not get a bath. I laughed, thinking he was kidding. He wasn't.
    Blues4U likes this.
  30. blowby
    blowby
    from Nicasio Ca
    Wonder if there is any difference in lubrication between a lobe and lifter that are in constant contact and pressure vs. having, at least having the potential for, some clearance.
