Projects '56 Fairlane Gasser Project
Discussion in 'Traditional Hot Rods' started by The Human Wrench, Dec 15, 2014.
  1. rusty1
    rusty1
    ...very cool build...the first picture you posted hooked me...
    Thor1 and The Human Wrench like this.
  2. GordonC
    GordonC
    Good for you! A lot of cars that ran on the strip back in the day weren't running straight axles so your car will still look great. I don't know where the current trend of its only a "g***er" if it has a straight axle on it came from but you are correct. It is being overdone. Good for you for not following the sheeple!
    The Human Wrench likes this.
  3. fiveoh108
    fiveoh108
    On your rear lower quarter panel replacement, did you have to repair the inner panel too? I am working on the same repair and wanted to know what you did . Thank you!
  4. Dan Todd
    Dan Todd
    What are you or did you do for the rear suspension?
  5. The Human Wrench
    The Human Wrench
    As you may have noticed I've kind of stalled out. I had a partner to start with and we were going to share the cost 50/50 but when he found out I actually was going to spend some money he let me buy him out. So I haven't done much lately. Now to answer the last two questions, since it was going to be a track only car we didn't worry about the rear inner quarter. However, now I think I may change my mind on that. As for the rear suspension, leaf springs, ladder bars and a 9". Also, I have been re thinking the front suspension and may go straight axle there now rather than replace all of the parts needed on the independent front end. Also like most of these 56s the front crossmember is bad and it locates the lower control arms so it would be easier to replace when using a straight axle. Not going to have the nose crazy high though. Don't give up, this aint over yet.
    AHotRod, Thor1, OahuEli and 4 others like this.
  6. OahuEli
    OahuEli
    from Hawaii
    It's good to hear you're still motivated to work on it. The 428 and top loader will make it a blast to drive.
    Old wolf likes this.
  7. fiveoh108
    fiveoh108
    What mounting location toploader tailshaft do you have?
  8. venturesomerite
    venturesomerite
    from CT
    Don't worry, I'm still watching, and not moving any faster so don't get discouraged.
    Thor1 likes this.
  9. NewGuyOldFord
    NewGuyOldFord
    If this wasn't started so long ago I was going to ask you what you did with the new quarter panel s****s that you cut off to radius the wheel wells. I would have been interested in them. Great project.
  10. The Human Wrench
    The Human Wrench
    11264.jpg 11265.jpg 11266.jpg So, a little progress. The frame has been sandblasted and shot with Rust-oleum. Also an Econoline will give up it's straight axle.
    Deuces, JUNK ROD, AHotRod and 6 others like this.
  11. The Human Wrench
    The Human Wrench
    Joe Travers, Deuces, JUNK ROD and 3 others like this.
  12. The Human Wrench
    The Human Wrench
    Before I install the front cross member I thought I better get the sand out of the frame from the sandblaster, not to mention a lot of rodent paraphernalia. It's good to have a big winch truck. A BFH and the air gun and it all came out.
    Deuces, Joe Travers, JUNK ROD and 4 others like this.
  13. The Human Wrench
    The Human Wrench
    Joe Travers, Deuces, JUNK ROD and 6 others like this.
  14. The Human Wrench
    The Human Wrench
  15. car doctor
    car doctor
    Great job on your Ford so far!! Pictures IMG_20200520_154107.jpg IMG_20200520_154050.jpg of my altered wheel base 56 ford g***er. 57 Chevy truck front axle, 57 Pontiac rear, 390 bored and stroked, t-10 4 speed
  16. birdman1
    birdman1
    You could be one brand new for 19.56 a month in 1956!!
  17. The Human Wrench
    The Human Wrench
    The Econoline axle is out. One side would turn the other side was full of mud and locked up. After a couple of hours of jacking with it I was able to get it apart without ruining anything. [​IMG][​IMG][​IMG]
    Deuces, JUNK ROD, loudbang and 2 others like this.
  18. The Human Wrench
    The Human Wrench
    loudbang, Thor1 and car doctor like this.
  19. Jalopy Joker
    Jalopy Joker
    another bit of inspiration from car show 6914 (2018_01_21 21_05_00 UTC).jpg 6912 (2018_01_21 21_05_00 UTC).jpg 6910 (2018_01_21 21_05_00 UTC).jpg 6908 (2018_01_21 21_05_00 UTC).jpg
    Deuces, JUNK ROD, loudbang and 6 others like this.
  20. Inland empire hot rods
    from so cal
    loudbang, Thor1 and The Human Wrench like this.
  21. bobss396
    bobss396
    Nice that you are sticking with it, slow and steady wins the race!
    loudbang and Thor1 like this.
  22. RmK57
    RmK57
    Boss 429 with mid-80's A/R rocker covers.
    Deuces and loudbang like this.
  23. uncleandy 65
    uncleandy 65
  24. Inland empire hot rods
    from so cal
    Cool I didn't look close enough! Love it
    Sent from my LG-LS998 using Tapatalk
    Deuces, loudbang and Thor1 like this.
  25. birdman1
    birdman1
    If I remember right,, the Thunderbird emblems on the fenders meant it has the 312 engine. I had a '56 I put a used police interseptor in after I blew up the 272. It was the cheap 2door hardtop. Stick with overdrive. I put on a factory 2x4 intake, Mallory dual pint distributor, and gl*** packs. Fast car
  26. No, the 292 got the emblems also. The 292 was the 'Thunderbird' motor, the 312 was the 'Thunderbird Special'. Only the 272 got the plain V8 emblems.
  27. AHotRod
    AHotRod
    Go man Go !
  28. 56 ford custom
    56 ford custom
    from Socal
    Inspiration
    Deuces, loudbang and LAROKE like this.
  29. uncleandy 65
    uncleandy 65
  30. The Human Wrench
    The Human Wrench
    Aussiepete., LAROKE, loudbang and 3 others like this.
