Technical Reverse rotation steering box
Discussion in 'Traditional Hot Rods' started by chip Romano, Jun 22, 2020.
  1. chip Romano
    chip Romano
    Hello H.A.M.B first time user here. I’m building a 1930 A V8 with 32 frame. Has been lowered front and rear. Front has split wishbone. Looking for a pre ‘53 steering box to use. I have an F1 box now. Mounted on frame with shaft coming out side of frame. Want to have the pitman arm point up instead of down. Appreciate any advise.
  2. gimpyshotrods
    gimpyshotrods
    So, you want to increase bump steer?
  3. alchemy
    alchemy
    There are Gemmer-made boxes that look just like F-1 boxes in some old Chris Craft boats of the 50's. The pitman in these points up instead of down, and they mount with a handy pillow block that could be adapted to your frame. Check your local vintage boat junkyard.
    4ever18 likes this.
  4. Mr48chev
    Normally a Deuce frame ch***is doesn't sit so low that you would have an issue with the Pitman arm facing down if the ch***is is done right. You want the drag link to run parallel with the wish bones when you are done and I am going to ***ume that is the issue or interference with the bone is an issue unless it is one of those rat rod abortions where the frame is two inches off the ground.
    Hnstray likes this.
  5. sdroadster
    sdroadster
    Chris craft like this, the pitman must point up to get the front wheels to steer correctly. It takes Ford parts, and uses a Ford pitman arm and steering wheel. P.M me if your interested. I live in California, so consider the shipping costs.... chris craft steering 003.JPG chris craft steering 007.JPG
  6. chip Romano
    chip Romano
    Yes. I love a challenge. Especially while driving
    bchctybob and Barrelnose pickup like this.
  7. chip Romano
    chip Romano
    Thanks. I will see if I can find one
  8. chip Romano
    chip Romano
    No it’s not “a rat rod abortion where the frame is two inches off the ground”, although I believe if that’s what someone wants to do it’s their car and their money. My issue is the angle of the drag link because of the length of the pitman arm and I would rather not have what controls the steering be the lowest part of the car
    VANDENPLAS, bchctybob, X-cpe and 2 others like this.
  9. X38
    X38
    Pictures?
  10. Mr48chev
    Cool, that is an issue that needs to be addressed. I just see so many RR abortions around here that when a guy asks about something out of the norm that is the first thing that comes to mind. I went out and looked at a non Ford box I have today thinking a guy could do some t******* on the casting and flip the box over but it won't work. It will work to make a right hand drive but not flipped over for left hand drive.
    I would take a lot of cutting and grinding on the housing to remove the brackets but the Falcon/Mustang little rear wheel drive early/mid 60's Ford boxes got used on a lot of rods with a bracket that ran the sector shaft out under the frame rail with the pitman arm facing up it should work the way you want. A lot of cutting, grinding and fitting and welding the flange on like we do with Ford F 1 boxes ala Vern Tardel. https://www.jalopyjournal.com/forum/threads/mustang-steering-boxes.1107423/ Those show them going under the rail but no reason you can't modify one to go though the rail and I think a rod trinket shop or two have those straight pitman arms.
    You need to use a tad bit of imagineering here though. mustang steering 1.jpg
    hemihotrod66 and bchctybob like this.
  11. alchemy
    alchemy
    Yes, if you aren't scared of doing a little welding on the box to mod the mount, a Mustang might be the better solution. There's lots of them, parts are available cheaper than for F-1, and they are a recirculating ball design, which will give smoother steering than the F-1 can.
    sidevalve8ba and bchctybob like this.
  12. sunbeam
    sunbeam
  13. F-head
    F-head
    You can use a 32/4 steering box with 35/6 internals and it will work with the pittman arm pointing up
    I had that setup in my old 28 roadster
    Worked Fine
    Not roller sector though
    bchctybob likes this.
  14. Casual 6
    Casual 6
    from Great NW
    VANDENPLAS likes this.
  15. Hnstray
    Hnstray
    from Quincy, IL
    It is a nice piece, but only solves one part of the problem. Correct geometry of the linkage in relation to suspension components is the primary determinant of successfully transplanting a steering box or R&P.
    Ray
  16. bchctybob
    bchctybob
    Welcome Chip. There's three great solutions to your problem in just sixteen posts.
    You will find that most everyone on here is willing to be helpful with information and sometimes even with the parts you may need, BUT, as you've already seen the really knowledgeable folks on here are reluctant to help someone build something that incorporates poor engineering or is just plain unsafe. Of course there are varying levels of O.C.D. from member to member. Lol. The fact that you are concerned about what is vulnerable under the car seems to show you are in the frame of mind that fits in well here.
    Good luck with your project. Post pix, everyone loves pictures.
  17. Blues4U
    Blues4U
    from So Cal
    Not correct. You want the junction of the pitman arm and drag link to be inline with the pivot point of the wishbone, not parallel. Parallel will result in bump steer.
    To the OP, what you are describing what you want is shown in the bottom pic, and that will result in bump steer. Probably not the best solution to your problem. As others have said, why don't you post pics of what you have and let some of the more knowledgeable builders around here give you some ideas to help?
    pprather, X38, Ned Ludd and 2 others like this.
  18. chip Romano
    chip Romano
    [emoji3]Imagineering Is key. Looking for pre ‘53
  19. chip Romano
    chip Romano
    I have the box out of it at the moment to see what If I can do anything with this box
  20. Pictures of your setup would help a ton
  21. Ned Ludd
    Ned Ludd
    Boryca, Hnstray and gimpyshotrods like this.
  22. butch27
    butch27
  23. butch27
    butch27
    What years of Chris Craft ??
  24. sdroadster
    sdroadster
    This is an old Street Rod Magazine drawing published during the Pete and Jake era. Since bump steer is a function of suspension travel, it seems logical that we would limit the travel to kill the potential bump steer. No car that I know of has 4 inches of ride. Install a suspension snubber, and design your drag link how ever you like. My Phaeton in build now has 1 1/2 inches of ride, and a parallel drag link. I been building cars a long time. Don't over think it. more tub 001.JPG
    Tman and bchctybob like this.
  25. Blues4U
    Blues4U
    from So Cal
    That car has the stock unsplit wishbone, the geometry & bump steer being discussed doesn't apply to that application.
    gimpyshotrods likes this.
  26. chip Romano
    chip Romano
  27. chip Romano
    chip Romano
    Thanks. There are several ideas I am looking further into from some members. I will post pictures as soon as I have the box back in it so everyone can see the issue I am dealing with. Yes, my first concern is always making any mods safe. Love the forum and how helpful everyone is
    Blues4U likes this.
  28. chip Romano
    chip Romano
    Great!! That answered a lot of questions. This was a project that had been started when I got it. The info I was going by was that drag link should be parallel with wishbone which I was trying to achieve. Thanks for this info. It will be very helpful.
    gimpyshotrods and Blues4U like this.
  29. chip Romano
    chip Romano
    [​IMG][​IMG]
  30. FritzJr
    FritzJr
    If you decide to keep your existing arrangement with the pitman arm facing down, you can still improve the situation. Your photo shows the steering arm with the tie rod end above it. Merely turning the arm over so that the tie rod end is below will help. You can also reshape the steering arm to have it bend down to follow the shape of the axle. This will allow you to get the drag link lower to help the geometry.
