Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. flatout51
    flatout51
    I've soaked paper towels in citric acid solution and pressed it onto surfaces and it worked great! Just make sure to check it for drying out, might have to spray them down or cover with plastic wrap. That would work pretty well for cylider bore. Oh and make sure that paper towels don't have any kind of design on them i used the blue shop towels from the parts store.
    Sent from my SM-G977U using The H.A.M.B. mobile app
    Six Ball, brEad, Tman and 4 others like this.
  2. flatout51
    flatout51
    There's the brakes @Tim was talking about. This was 18 hrs in the acid. Light coat of Gibbs to help with flash rust. SmartSelect_20200609-084939_Instagram.jpeg SmartSelect_20200609-084928_Instagram.jpeg
    Six Ball, brEad, Thor1 and 3 others like this.
  3. drdave
    drdave
    WOW!! I'm sold.....two engines headed to citric acid bath....along with anything else I have laying around that needs a nice clean up. :)
    loudbang, Six Ball, Tim and 1 other person like this.
  4. Tim
    Tim
    from KCMO
    Pulled it this morning and as it looked over cat stuck fans in it to dry. After a few hours I noticed the thermometer in my porch read 100 deg so I stuck it in there.
    pulled the hood shelves and you can see the rust metal, the clean metal and the remaining black paint.
    fluod is very dirt and murky now most likely on account of these very rusty headlights that I dunked to see if maybe they’d be good for parts.
    I’ll stick the hood shelves back in and see if the dark solution will still strip it.
    You can see the line on the trans were the fresh clean surfaces for some flash from siting above the solution to do the bell.
    also everything is nice and lose! Should be easy to take all the way apart 3BD5DB92-4F37-4F06-8B61-8457231B14C2.jpeg C5EA7B4E-77B8-4A9B-BE6B-2B499B1DF47B.jpeg 6326140B-2A06-4E5B-8FC7-D35DE9049C15.jpeg 0F1416D3-45B9-4244-A271-8E1AA070082A.jpeg 9A4D2C5B-14C5-48D4-A6C0-2AA31AAE0C09.jpeg 391EFA35-44A3-4171-9533-21F5A08F1028.jpeg 93A55C92-5967-4B36-B7E8-43E6510E6634.jpeg EC1BF0F1-E69F-4408-80A2-5D6C8342EFA7.jpeg B1C61C75-89CF-4CF4-AA8F-8B36ABABF648.jpeg
  5. flatout51
    flatout51
    drdave, loudbang, Six Ball and 2 others like this.
  6. Tim
    Tim
    from KCMO
    Yeah I’m happy with it. Gonna take some sand paper to one little spot inside and then put some oil over it. Then throw some primer on it til I get to building the trans.
    which now I want to do because the case looks so clean lol
  7. Tim
    Tim
    from KCMO
    Hey @Tman find anything on the heater stuff yet?
    loudbang and Thor1 like this.
  8. Tim
    Tim
    from KCMO
    Dipped the other side of the hood shelves and the crusty head lights.
    I had turned them so the badges would clean up but was surprised that even in this dang near black liquid that no longer puts off any noise or bubbles they cleaned up pretty good. You can see where the water line is on them super obviously.
    I did use a wet rag and wipe them down when pulling them and the rust just sluffed right off.
    im letting the good set of lights soak with some kroil so I can get the bezel screws out and get them apart but this has got me excited to see how they clean up. Can clearly read the stamped numbers and everything. Pretty stoked DD97D9DA-33FD-4B35-A952-0C1D3FA00F22.jpeg 2D0D6E41-29F9-4792-A206-984F87649B97.jpeg 7FA90F67-876B-4390-B36F-1C6A18C11CF9.jpeg 5EC73AA7-CF36-4F4C-8784-21BFBBE6D42B.jpeg 2F1C5B90-25FB-460E-A1CC-D3C68E413259.jpeg DFAE4119-30DA-4C0D-B9A0-6F0C549DF41F.jpeg
    drdave, loudbang, brEad and 3 others like this.
  9. It is in my shop. I have been soo busy I forgot to look
    Runnin shine, loudbang and Tim like this.
  10. loudbang likes this.
  11. Tim
    Tim
    from KCMO
    Cool I’ll read it later :) figured you’d just got busy no worries
    Tman and loudbang like this.
  12. Tim
    Tim
    from KCMO
    Took the 46’ out and dropped the hood shelf’s and some sheet to my buddy Ryan to patch up some holes. Almost every single hole for the hood latch’s were slotted or torn in some manor. I marked enough of the good ones to use as a land mark and he’ll fill the others in solid.
    then I’ll use a latch to Mark where each hole needs to be and re drill them. DFE92FDE-915F-4B44-A51D-3CB4C748AE00.jpeg i think this weekend I’m going to cut the screws that hold the trim ring/ band tight to the bucket on my good head lights so I can take them apart and toss them in a new bucket of acid. Hoping after that some vice grips will let me twist out the remnant screw parts after the fact.
    Hopefully the only this they’ll need is a dent in the ****on of one knocked out and some new studs put in. Which after soaking the others makes it pretty obvious how I’ll go about that.
    drdave, Thor1, Runnin shine and 3 others like this.
  13. Tim
    Tim
    from KCMO
    Alright got the tub cleaned out CDDCAB06-06FB-4F48-B6C0-FEE25B862DBB.jpeg yeesh! That’s gross.
    F0257682-2AFB-4731-B111-A7DE80FB2515.jpeg Cut the screw on the bezels and got both buckets apart. The damage I’m seeing looks better than I had expected. Sprayed them off with the hose and stuck them in a 5 gallon bucket with a toss or two of acid flakes. Left it outside guess we’ll see what they look like tonight!
    choose the bucket this time because I can submerge the entire bucket in one shot instead of having to flip them around. I probably should have waited till I had gathered up more random **** to toss in there to make good use of the mixture but I’m sure I’ll come across something the next few days
    Stogy, drdave, brEad and 2 others like this.
  14. Tim
    Tim
    from KCMO
    Five hours in, I can see a lot of free floating scuzz but it’s clear over all C9805F2C-FCDE-4CB1-BFAA-849789C9B3E1.jpeg
    Stogy, loudbang, Thor1 and 2 others like this.
  15. Tim
    Tim
    from KCMO
    83FFE7CA-AE81-4D8E-9687-BC3FAFAE73A6.jpeg 24 hour sneak peek. I think these are really going to come out nice
    brEad, drdave, loudbang and 4 others like this.
  16. Tim
    Tim
    from KCMO
    Rubbed quite a bit of rust, grime and paint off when I pulled them out of the bucket not to bad... 9C47D3A4-4C12-46AF-87E6-617171E189B9.jpeg 45D80AAF-42EA-4C21-AD67-2D63A9D99404.jpeg
    loudbang, Thor1 and Stogy like this.
  17. Tim
    Tim
    from KCMO
    Then I hit them with the garden hose, some dawn and water and a towel and got even more off! 0BCECB2C-54E5-4327-8436-56723518B10C.jpeg 1245B451-453E-4188-B53D-913680C30FFB.jpeg DF3A371E-191C-4A43-9FEB-C4742318E854.jpeg 951CC33C-C809-411D-9364-F37606300036.jpeg
    kadillackid, brEad, Six Ball and 4 others like this.
  18. Tim
    Tim
    from KCMO
    So 24 hours in the soak and maybe 20 minutes wiping them down, hosing them off and drying them. I can actually see marks inside the buckets that show how they were made.
    you can also see a ton of places where these were plated at one time. The inside the bucket is where I see it the most. Don’t know if it was chrome but it was.. something. 9142CA4F-8CCF-4230-BCA2-47DB96682249.jpeg 5BA1DA85-CF07-4710-97AE-127A8D39E960.jpeg D2872BD9-D0FA-448F-B7F6-9CF334363E66.jpeg B925EE02-96BD-4110-B9A9-261C520020CF.jpeg 0486CF51-8937-40D1-A36D-8BB4BA6B180F.jpeg DD4E6A38-0B4E-4873-AA8D-084A889A4D62.jpeg 59C522AE-6855-4CF3-BDA3-57FC76DF2753.jpeg So the damage that needs repaired comes down to one bucket having a ding in the top and the bottom pushed up. I believe a shed fell on this car in last years big tornado. So it’s likely those both happened at the same time.
    the mount clearly has been broken and ****ed with before and handy enough it’s the one that needs a new stuff anyways so I don’t ave to feel bad cutting a good part up to get it swapped. Both trim/‘retaining rings have rust threw from water collecting at the bottom id guess. The metal still feels thick it’s just the high/low spots of the pit that are popping threw not the entire thing getting thin.
    I put it together and the part that has the holes doesn’t seem to touch anything so I might jist fill it with some all metal/ J.B. weld from the back side and sand it even. Call it a day.
    anyhow they are clean and ready to be messed with
  19. Stogy
    Stogy
    I guess it guarantees the rust is gonzo right down into the seams for welding or otherwise but us poor sods with rust belt metal constantly face this challenging reality...its nice to have a kinder gentler acid mix as well that delivers the magic bullet...
    loudbang, Tim and Thor1 like this.
  20. Six Ball
    Six Ball
    from Nevada
    I just ordered 10 lbs of citric acid.
    Stogy, flatout51, loudbang and 2 others like this.
  21. progress!
    loudbang, Thor1 and Tim like this.
  22. Tim
    Tim
    from KCMO
    Awesome :) doesn’t take much! Have fun
    loudbang, Thor1 and Dakota hunter like this.
  23. Runnin shine
    Runnin shine
    Thor1 and brEad like this.
  24. Tim
    Tim
    from KCMO
    Man it was hot today! I stayed my *** inside but I did get some running boards from @Austin kays when he grabbed some parts for @porkn******
    pretty sure they are 30’ Chevy. They are about an inch or so to long, the front is under an inch to wide and the back in maybe 1.75 to wide. Thinking I’ll look at the “looking for” adds before I cut them shorter, narrow them and take the taper out of them. Seems like maybe chevys might be harder to come across so I don’t want to jump the gun and cut them up
    also started working on getting the old tires off the wheels I got a little bit ago for the spare tires. Cut the valve stems off and got them empty and got one bead busted. I think I’m going to take a jig saw to the rubber and make it easier to get off the wheel. They are dry rotted enough that I jumped on the side wall and it crackled both physically and audibly shouldn’t take to much to get them off once they start C80B0024-6C3E-46C2-AF52-F7B6D04D4261.jpeg EA29833C-E656-42DA-A733-966B07BB3B4E.jpeg
    drdave, Six Ball, Stogy and 4 others like this.
  25. Tim
    Tim
    from KCMO
    Still can’t believe a sbc is this close. Sat the gasket next to the head and it’s so ridiculously close. A sbc header u-build-it should be perfect... 1439DC15-1BC2-42A8-83AD-777122F0E869.jpeg
    drdave, brEad, Six Ball and 3 others like this.
  26. Six Ball
    Six Ball
    from Nevada
    I'm still working on my header, the Fenton Black Widow. The 153 ports are taller than the small block but I can make it work. I think any small block tube header could be made to work.
    Thor1, Tim and loudbang like this.
  27. Just scrounge up a swapmeet set to practice on.
    Thor1, Six Ball and loudbang like this.
  28. Six Ball
    Six Ball
    from Nevada
    I have decided to use one of the Chevy 4 cylinder header flanges available on eBay and weld the Fenton sbc header to it. I'll do the port matching/transition going through the flange. Pictures soon I hope.
    Thor1, Runnin shine, brEad and 3 others like this.
  29. Tim
    Tim
    from KCMO
    My flanges and pipes should be here in a few days. I’ll have to see what they actually look like in person but I think they should work with pretty minimal work/ welding
    Thor1, loudbang, Tman and 1 other person like this.
  30. Tim
    Tim
    from KCMO
    Little mock up. Looks like outside of minor flange modifications I just need to shorten one of the center primaries vertically and trim the ends.
    I need the center primary’s to stack on top of each other instead of side by side as they intended because I have to have them both dump down immediately to clear the intake manifold. You might be able to see some blue tape on those two. That’s where I think they need cut.
    0A42FA3E-FF1D-45F7-BF55-4723B35DC4ED.jpeg 9348F359-EAF8-4AB2-A8F5-BAC4D9C6CEBC.jpeg 3A6B19DE-2477-4E3C-99C6-96AEB7848586.jpeg
    Thor1, drdave, patmanta and 6 others like this.
