Projects Clark Coupe Build
Discussion in 'Traditional Hot Rods' started by etboy97, Dec 21, 2016.
  1. etboy97
    etboy97
    I am using a Tanks U3 16 gal tank in the trunk. I liked the low cost and practical approach 51box used on his 28 coupe project using a modified Airtex E8269h pump ***embly which is for a late 80's Accord and Prelude. Its low cost and easy to find. 51box has over 3600 miles on his build with this pump set up and he told me it has worked well so I thought I would give it a try. See post 263 of his build thread for his version of the modifications. I took a slightly different approach and tried to reuse even more of the original parts. This is what you start with.
    You will have to straighten the arm and remove and reweld the bracket that holds on the pump motor. The metal tube will need to be bent some and I did have to remove some of the rubber material around the motor to make it a little smaller in diameter to fit though the tank hole. You will also have to modify the top flange making it smaller to match the tank. I also added a vent outlet.
    It now fits the tank perfectly and has the correct depth. Besides the pump ***embly all I needed was one hose clamp and the vent fitting.
    Sent from my Pixel 3a using The H.A.M.B. mobile app
  2. sliceddeuce
    sliceddeuce
  3. brEad
    brEad
    Nice solution, thanks for sharing it with us.
  4. LKR
    LKR
    from Australia
    Great build, really enjoying what you are doing
  5. etboy97
    etboy97
    I found out I will have to wait another month before the shop can take my motor so decided to go ahead and mount the body on the frame for now to give me more space in the garage and some more items to work on.
  6. etboy97
    etboy97
    Just got my exhaust system back from bring ceramic coated black.
  7. etboy97
    etboy97
  8. etboy97
    etboy97
    catdad49, Stogy, mctim64 and 3 others like this.
  9. etboy97
    etboy97
    I thought I was done with the rust repair but chased some pin holes on the trunk lid.
    This should be the last of it.
    Also got the dash blasted and painted.
    catdad49, Stogy, mctim64 and 2 others like this.
  10. CrazyDaddy
    CrazyDaddy
    from Austin TX
    Looks fantastic ! What did you treat the wood with ?
  11. etboy97
    etboy97
    Just some leftover Minwax stain and polyurethane I had.
  12. etboy97
    etboy97
    Slowly but surely I am knocking out the rest of the paint work. I just don't want to store finished paint items that I am not ready to install yet as I don't have the space to safely store them. Only big items left are the doors and grill shell. Just finished spraying the trunk and cowl top. IMG_20200623_124001.jpeg
  13. etboy97
    etboy97
    I have been working on rebuilding my gauge cluster off an on the last two months. I am using a 1951 Plymouth cluster and wanted to update it using mid 80's Camaro volt, temp, oil, and fuel gauges. Fitting the replacement gauges was not to hard but I had been stuck on making new gauge faces. Here is what I started with.
    My artsy daughter recently puchased a Cricut machine which looks like a computer printer but has a knife and cuts fairly intricate designs in paper and vinyl. I figured she could cut me vinyl stickers that I could use as stencils. The early attempts with painting the dial faces using the stencils did not turn out as well as I wanted. I ended up getting the best results by using the vinyl stencils on black anodized aluminum and bead blasting.
    IMG_20200625_115021.jpeg IMG_20200625_122055.jpeg IMG_20200625_122449.jpeg IMG_20200625_144109.jpeg
    Here is what I ended up with.
  14. vtwhead
    vtwhead
    looks like you have the market cornered on 51 Ply instrument clusters:rolleyes::) That turned out really nice, great job.
    catdad49, Stogy and loudbang like this.
  15. etboy97
    etboy97
    You don't know what you don't know. I was working on getting my visor and the header metal that is under the visor installed and figured out that my new wood header was too tall in the front and needed to be tappered down in the front. Fortunately I had not nailed any of the metal in place was able to remove the header with out a lot of work. IMG_20200701_161708.jpeg
  16. loudbang
    Looks REAL GOOD bet nobody will know the difference :)
    Stogy likes this.
  17. etboy97
    etboy97
    I had to cheat a little bit. The voltage gauge should read 8 to 18 but we could not get the Cricut to cleanly cut the small 8s without moving the small inner circles out of place.
    Tim, Stogy and loudbang like this.
  18. MMM1693
    MMM1693
    Very nice work on that gauge cluster!
  19. etboy97
    etboy97
  20. etboy97
    etboy97
    I had to come up with a filler panel for the middle of the dash. I ended up making one from a piece of ribbed aluminum cut out of a old piece of a shower door header.
  21. brEad
    brEad
    Nicely done!
  22. loudbang
    Nobody would have ever guessed what it was from. :)
    Stogy and brady1929 like this.
  23. MMM1693
    MMM1693
    Very well played!
  24. greaser
    greaser
    I like it!
  25. 57tailgater
    57tailgater
    from Georgia
    What type of bead did you blast this with this? We have a Cricut as well and I am always looking for new ideas. Yours turned out really nice and crisp.
    Stogy, catdad49 and loudbang like this.
  26. ccain
    ccain
    That wiring looks fantastic and that cluster is *****in'! Great work!
  27. etboy97
    etboy97
    Here are the gl*** beads I used. I tried the aluminium oxide that was in the blast cabinet first and it ended up leaving a dust under the tape edges that scratched the finish. IMG_20200710_101706.jpeg IMG_20200710_101725.jpeg
    oliver westlund and Stogy like this.
  28. etboy97
    etboy97
    Some more progress this week. Got the trunk lid color sanded and installed.
    I don't plan on doing the interior until I can drive the car for awhile and get any bugs worked out but wanted to at least cover the seat.
    The famous Dodge Caravan middle seat before.
    Same seat with a $15 vintage GM rear seat cover installed.
  29. Hey, that's a great idea. Changes the style altogether. Di you find it at a good price?
  30. etboy97
    etboy97
