Projects The Warbaby sport coupe build
Discussion in 'Traditional Hot Rods' started by Joe Rosales, Feb 17, 2018.
  1. Joe Rosales
    Joe Rosales
    Just noticed that!
    Stogy likes this.
  2. Joe Rosales
    Joe Rosales
    Thank you Bob
    kidcampbell71 and The37Kid like this.
  3. dirty old man
    dirty old man
    Not only do I think they look OK, I'm running them on my roadster, and have been for a number of years.
    kidcampbell71 likes this.
  4. Joe Rosales
    Joe Rosales
    Thank you, originally I was going to use the light bar . Figured it would block the view of the awesome 34 grille.
  5. WOW !!!! This thread is sooo... addictive !!! I started on page one and thought this is kind interesting.... By the last page, I felt re-educated on the art of the possible.
    Great work .... Eagerly awaiting the next instalment. Don't leave anything out.
    OzMerc
  6. Runnin shine
    Runnin shine
    I agree with Bob. Although a cl***ic cool headlight mount, and hell no don’t block that grill, they don’t seem right for the Warbaby. I think something more cast off and or fabricated is required. It may be the awesome old black paint that won’t let me see these working. Maybe if they get polished and you give the body a shiny period flashy paint color.
    The skills and taste you’ve shown thus far tell me you’d be coasting if you didn’t continue the trend with a possible new interpretation of an old standard. Good luck we’re counting on you.
    Coincidentally I was recently wondering has anyone ever extensively modified rumble seat hinges to be headlight mounts?
    Or are they to small in scale? I can see cutting out some of the screw hole section to have two separate oval mounts to the frame.
  7. sloppy jalopies
    sloppy jalopies
    Hmmmmm.... that is an idea... seems it would mount the lights very low, cool.
    i think i have 4 or 5 pair to mess with... got to get to it.
    brEad, The37Kid and Runnin shine like this.
  8. Joe Rosales
    Joe Rosales
    For now I think I will put a hold on the headlight mounts and start on my gas tank. I am using a repop 32 tank rather than inside the trunk. I just like they way the rear mounted tank looks. After some measurements we discovered that the tank needs to be shortened by 2 inches. I cut the tank and will weld a new sheet of metal back in to fit the A body. Stay tuned!
    4892327B-564B-4641-BFCF-92C5DCB35EA4.jpeg 8850AEB1-FFD8-436E-937D-4B27F90023D4.jpeg
  9. sloppy jalopies
    sloppy jalopies
    there is a hight problem with an A body on '32 frames, grab your tape measure, I had to remove the heavy rear crossrail and some of the lowerpanel...
    the '32 body was designed to have the 4"-5" of tank above the frame... the A was not... DSCN5398.JPG
  10. The37Kid
    The37Kid
    ^^^^^^^^^ Could you hang that '32 tank UNDER the frame rail? Bob
    Runnin shine likes this.
  11. Joe Rosales
    Joe Rosales
    You could , but it is originally mounted on top of rails.
  12. Joe Rosales
    Joe Rosales
    I took a section on the body out so I could keep the rear subrailing , it was pretty extensive. By doing that the lower decklid panel was also shortened.
  13. sloppy jalopies
    sloppy jalopies
    IMO, tank under frame would probably look ok from the rear,
    but from the side it may have that dog taking a dump look...
    one adam 12- call photoshop, to let us all see if it is an option...
    computer skill guys to the front ! … thank you.
    for the guys that haven't gotten this far yet, barn fresh California 1932 - 5 window's rear of body is 1.5" forward of the reveal in the tank...
    chryslerfan55 and Joe Rosales like this.
  14. sloppy jalopies
    sloppy jalopies
    If close you can slide the tank's mounting flange under the top rail and then bolt up through it and the frame rail...
    buys about 1/4"-3/8" … buddy did that on an A frame with '32 rear horns welded on...
    can go take pix if needed.
  15. 66fora69er
    66fora69er
    Looks Great Joe
  16. Joe Rosales
    Joe Rosales
    Thank you
  17. Joe Rosales
    Joe Rosales
  18. Joe Rosales
    Joe Rosales
    Update photos of the 32 tank going in. Some more cutting and grinding did the trick, now to make a new back panel.
    C95153DE-56F2-4F60-A373-B41E4B57554C.jpeg CEECF3E4-B6E4-4EDA-B08C-7AD8C17A5881.jpeg 02F8687E-1827-46B2-8078-B014C33F39ED.jpeg
    catdad49, Outback, tr_rodder and 8 others like this.
  19. rcavaliers
    rcavaliers
    from downey
  20. sloppy jalopies
    sloppy jalopies
    Yes on the V8 and mounts going together... mikie likes it !
    i cut the ends off of a folded under gravel shield,
    reversed them and clamped them on as rear frame covers... left room for a speader bar to protect the tank... tank sides 1.JPG tank sides 2.JPG
  21. Joe Rosales
    Joe Rosales
    Rear covers look great, I’m thinking of using them as well.
  22. Joe Rosales
    Joe Rosales
  23. Travis latour
    Travis latour
    from Putnam CT
    Great work as always!
  24. Joe Rosales
    Joe Rosales
  25. Joe Rosales
    Joe Rosales
    Thanks Travis!
  26. Joe Rosales
    Joe Rosales
    Here’s a few pictures of the 32 tank that is being modified to fit the crafty b gas cap. Once the cap is all welded and metal finished we can continue with the back panel of the tank. We made a pattern and cut out a piece of sheet metal to fit around the new cap. Got a first time lesson on metal shaping from Chris, and I think it’s going to turn out great! More to come.
    C10A3079-B83F-4A24-9103-05D5474CC9CA.jpeg EF36C2BB-0F7D-445D-94BE-3E15729B8EF8.jpeg BE6A1540-39BB-40F5-919A-7BC5578B863E.jpeg AD192754-38DA-4421-AD24-2005FAAF6796.jpeg 8DE176AD-4E10-4C90-8CC7-430745179142.jpeg
  27. glorydime
    glorydime
    from Austin, TX
  28. Joe Rosales
    Joe Rosales
    Thank you
  29. Joe Rosales
    Joe Rosales
    A few more progress pictures of the 32 tank gas cap.
    Some more grinding and filing needed.
  30. Joe Rosales
    Joe Rosales
    Gas cap pretty much turned out the way I thought it would..awesome!
    70B5B364-50A4-438C-B017-B7183F63FEF9.jpeg 4C7B55F2-13B2-49AD-83A8-42B5E3B1B49F.jpeg
