Saving old decals Planet Jr.
Discussion in 'The Antiquated' started by plym_46, Jun 27, 2020.
  1. plym_46
    plym_46
    from central NY
    Working on my grandfather's Planet It walk behind garden tractor. The paint is showing it age but is holding up well. I went over the gas tank with a warn out scuff pad and ATF. The ends have trade mark decals that are dirty but complete. I want to save them so I just cleaned the with a bit of gl*** cleaner. They brightened up quit a bit but don't want to push my luck. So my goal is to clean, maybe moisturize and then protect.
    The body of the machine also has trademarked labels and a maintenance and lubricating charts.
    I plan on doing the ATF and scuffpad then coating with Boiled linseed oil. Can anybody suggest anything different for the decals or the whole thing if I am headed down the wrong path? Any other planet Jr. Fans? Will put up some pics tomorrow.
  2. 67L36Driver
    67L36Driver
    Look in Hobby Lobby in the charcoal sketch department.
    Krylon made a spray fix to preserve a charcoal or pencil drawing. Leave a satin coat.
    Also Krylon cristal clear. Leaves a more shiny finish.
    Try it on some other object before committing your prized piece.
    I worked as a technical illustrator ‘66 & ‘67. We used the above to preserve layout lines.
    I spray fixed my SS card back then and it’s like a piece of plastic yet.
    quick85 and 1morecarIpromise! like this.
