Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    I bent a piece of 18 gage to make the lower flange, then put a crease in it by bending it in one direction, moving and flipping the piece over and bending it again. with it clamped in the brake I hammered down on it to get the bead rounded. IMG_0307.JPG IMG_0308.JPG IMG_0309.JPG
  2. tb33anda3rd
    tb33anda3rd
    I bent the edge along the jamb, then used the shrinker to pull the panel around the corner. to get the taper I used a barrel nosed heavy hammer to stretch the upper part of the patch. IMG_0310.JPG IMG_0311.JPG
    cactus1, dwollam, ct1932ford and 9 others like this.
  3. tb33anda3rd
    tb33anda3rd
    I fitted, then welded it in and ground the welds flush. IMG_0312.JPG IMG_0313.JPG IMG_0314.JPG
    cactus1, safetythird, dwollam and 6 others like this.
  4. tb33anda3rd
    tb33anda3rd
    splattered a little black primer on, then a coat of ford engine paint. right before the paint dried [slightly tacky] I rubbed the paint with my hand to get rid of some shine, and show some black through. blends ok? IMG_0315.JPG
  5. TFoch
    TFoch
    It takes a Chevy Guy to fix all the wood in a Ford! Great job!
    cactus1, Stogy, loudbang and 2 others like this.
  6. tb33anda3rd
    tb33anda3rd
    after dinner I did the other cab corner. smaller patch just needed the bead. IMG_0321.JPG IMG_0322.JPG IMG_0323.JPG
  7. tb33anda3rd
    tb33anda3rd
    I am not as happy with this, it will need a little more work. IMG_0324.JPG IMG_0325.JPG
  8. ct1932ford
    ct1932ford
    What did you have for dinner? May of had something to do with the outcome. Looking good tb.
  9. tb33anda3rd
    tb33anda3rd
    pasta with meat sauce......bread.... garden salad.:cool:
    scrap metal 48, Stogy, TFoch and 2 others like this.
  10. Been a neat thread to follow! Thanks for sharing.
    loudbang, tb33anda3rd and greaser like this.
  11. ct1932ford
    ct1932ford
    No dry red wine?:confused: That may be the problem!:oops:
    Stogy, TFoch, loudbang and 1 other person like this.
  12. tb33anda3rd
    tb33anda3rd
    worked on the driver side again. thought I would get around the corner a little more before making the straight piece across the back. IMG_0333.JPG IMG_0334.JPG
    brEad, dwollam, Runnin shine and 4 others like this.
  13. tb33anda3rd
    tb33anda3rd
    while I was at it I tweaked the passenger side......better now. IMG_0335.JPG IMG_0336.JPG
    dwollam, Runnin shine, TFoch and 3 others like this.
  14. tb33anda3rd
    tb33anda3rd
    trimmed up the back panel for the final piece, will start making this tomorrow night. IMG_0337.JPG
  15. TFoch
    TFoch
    Coming right along! Them corners take some time.
  16. tb33anda3rd
    tb33anda3rd
    I ended up mowing the lawn but wanted to keep moving ahead so I used the heat gun to soften the tar that someone put inside the doors. there was also a strip across the back that needed to be removed before I welded it up. IMG_0346.JPG IMG_0347.JPG
    kidcampbell71, Stogy, TFoch and 6 others like this.
  17. IowaMercMan
    IowaMercMan
    Great thread! Thanks for taking the time to post.
    Walt
    Outsiders CC
  18. tb33anda3rd
    tb33anda3rd
    the slacker came by today to see the wood work, pick up the windshield frame and look at the seat situation. he had bought this seat frame and cushions that came out of a coupe. brand new springs, nice upholstery and a solid frame. we have tried to sell it so we could get the proper truck cushions but have been lowballed to the point we are just going to cut them up and make them fit the truck. the bottom of the seat fits ok on the seat riser but needs a 1.5" riser board across the back to get the right angle. the back cushion is going to have to be chopped down. if we plan it right we should be able to use the fabric again. other smaller cushion is a rumble seat cushion. IMG_0348.JPG IMG_0349.JPG
    TFoch, brEad, loudbang and 4 others like this.
  19. tb33anda3rd
    tb33anda3rd
    I bent up the patch panel for the rear of the cab and trimmed it to width. I then clamped it in place and marked for the cut across the top. IMG_0350.JPG IMG_0351.JPG
    Stogy, TFoch, loudbang and 2 others like this.
  20. tb33anda3rd
    tb33anda3rd
    notice the cab flares out as it goes up, so I had to put it back in the brake and bend just above the bead some more to match. IMG_0352.JPG
    cactus1, Stogy, TFoch and 5 others like this.
  21. tb33anda3rd
    tb33anda3rd
    once trimmed I welded it in, ground down the welds, and hammered out most of the waves and dings. IMG_0353.JPG
    Stogy, TFoch, loudbang and 4 others like this.
  22. tb33anda3rd
    tb33anda3rd
    lower back of cab done for now. IMG_0356.JPG more of the black primer and ford engine paint
    cactus1, patmanta, Stogy and 13 others like this.
  23. ct1932ford
    ct1932ford
    Nice!:cool:
    beater40, loudbang and tb33anda3rd like this.
  24. olds vroom
    olds vroom
    Awesome job
  25. tubman
    tubman
    I've been watching this from the beginning. Very impressive work.
  26. tb33anda3rd
    tb33anda3rd
    thanks for all the compliments, likes and comments.
    Just Gary, Stogy and loudbang like this.
  27. scrap metal 48
    scrap metal 48
    Your doing really nice work.. Keep it going....
    tb33anda3rd and loudbang like this.
  28. tb33anda3rd
    tb33anda3rd
    keeping it going.... :). this morning I cut the roof strips. I made them 3/8 thick and after they are installed I will sand the top side down about 3/32" to get the correct height . I used the whole board and I think I may be one or two short. I do think the extra spacing will be ok, I will see after I trim them to fit. IMG_0359.JPG IMG_0360.JPG IMG_0361.JPG IMG_0362.JPG
    patmanta, Stogy, TFoch and 1 other person like this.
  29. tb33anda3rd
    tb33anda3rd
    I then decided to "finish" the upper part of the back, of the cab. I did some more shrinking, hammering, and tweaking, still needs more but it is good for now. I also had to straighten out the rear window opening and weld a few cracks. IMG_0363.JPG IMG_0364.JPG IMG_0365.JPG
  30. tb33anda3rd
    tb33anda3rd
    I then sanded down the rusty spots and hit it with the primer and paint. IMG_0366.JPG
    Stogy, TFoch, kidcampbell71 and 3 others like this.
