Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Improvised a tubing bender to make a bend I couldn’t make with the benders I have.
    1/4-20 carriage bolt and the spacer from a GM caliper slider bolt, some scrap wood, and C clamps.
  2. jimmy six
    jimmy six
    Excellent work and idea, Thanks
  3. David Gersic
    David Gersic
    from DeKalb, IL
    The other blocks of scrap wood in the background were used to clamp the loop part in place, and another was used to keep the line straight while bending. Kinda hokey, but it worked.
    Elcohaulic likes this.
  4. jimmy six
    jimmy six
    Think I finally found and fixed my trans leak. Last fix was a copper crush washer on the pan to dip stick tube fill where I thought was the leak. I now was even looking at the top of the tube for over flowing since the lower part of the tube was wet. Still persisted. I had the car up 8" and ran it until warm and saw nothing. 1 hour later red drips in the white washing machine pan I keep under it. Hard to see but I spotted a fitting for the the transmission cooler line halfway up the side of the trans with a slight amount of red oil on it. Checked for tight with a tubing wrench....tight but I guess not enough. Very hard to get to but with the tubing wrench and a 6" snipe I was able to tighten it about 1/8th turn in 2 attempts. Ran the engine and in gear for another 10 minutes no leaks in 1 hour and none this morning.....Geez been chasing this for at least a year always went to the fill tube fitting......Forest for the trees... I'm glad I never gave up.
  5. Lloyd's paint & glass
    Lots lol, por on the floor of the 39, and cutting glass for a 37 Pontiac. The rest is off topic cars. 20200629_171244.jpg 20200629_171414.jpg
  6. Picked up this heap today, gonna fix it for my girls (2 and 5 years old). Hope to have it done before they grow out of it. 20200629_203015.jpg
  7. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Can see that you have already put it to work, hauling spare tran's and such :)
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
    7A8B8040-3C7D-4BAD-BFB5-A014D9CA42E9.jpeg 839E16DD-28BE-4C93-8B96-13237E12A6CA.jpeg F8096D71-03CD-442D-8737-C93282C7EEEE.jpeg F58B7A8E-EBD4-4FE0-95BB-E8CA9A787A99.jpeg Well finished up my shifter install...man Ford didn’t play when it came to shift levers..that was some hard steel...had to use the cut off tool to hack the first part off and the big electric angle grinder with the big wheel to hack the rest off..all on my back..would have much nicer on a lift...but it’s done and the shifter seems to hit all the gears..lost is down to a few things and it will be break in time...
  9. stillrunners
    stillrunners
    from dallas
    Why why why.....so they like our engines ! Had just looked over this put back motor last month - maybe early to make sure it was staying dry. And damn if yesterday I looked and saw some evil leaves that weren't there before. A closer look and yeah the little rat bastard got hopefully a taste of antifreeze. Anyway cleaning became job one. 20200630_172154.jpg 20200630_184109.jpg 20200630_190658.jpg
  10. topher5150
    topher5150
    Picked up this alt bracket for my 351off a 351.... Is there something that bolts directly to the head??? IMG_20200630_210259902.jpeg
    Sent from my moto z4 using The H.A.M.B. mobile app
    chryslerfan55, ct1932ford and Lil32 like this.
  11. stillrunners
    stillrunners
    from dallas
    Had one
    trannie leaks....dang have had those......
  12. Mike Miller
    Mike Miller
    Worked on the front suspension, cleaning up the upper control arms and replacing the bushings.
  13. 41rodderz
    41rodderz
    from Oregon
    Mmmm... cut down a tree. Why? In the way.:p Seriously was in the way , now i can build a 12x16 shed to get all my larger parts out from under my feet ( fenders , hood and grills, bumpers , intakes and valve covers etc) and add on a 8x8 for the garden shed. When that happens I can use all my equipment and keep it in one place. The big fight will be with myself to not fill up the empty spaces.
    chryslerfan55, stillrunners and Lil32 like this.
  14. Caprice89
    Caprice89
    More space results in more stuff is my experience.
    Sent from my online shouting device
  15. David Gersic
    David Gersic
    from DeKalb, IL
    Test drive. Brakes work. Need to adjust the pedal height, though.
  16. squirrel
    Worked on the interior of the T. It's getting there. The seat was already done, so I'm leaving it alone for now. I still have to make top bows and do the headliner and door panels. IMG_20200701_154631015.jpeg
    Sent from my Trimline
  17. WTF really
    WTF really
    Got started cleaning the big block and some parts for it today 20200701_172029.jpg 20200701_172044.jpg
  18. topher5150
    topher5150
  19. 1971BB427
    1971BB427
    from Oregon
    After much waffling, I finally gave up on the cool '52 Pontiac steering wheel I restored for my '39 Chevy project. The 18" wheel was just monstrous, and minor corrections as I drove turned into major swings of the wheel!
    So I gave in and ordered a 3 spoke wheel in 15" to replace it. Got a satin black center, and chrome cap for contrast. Not as cool looking, but drives much better!
  20. lo c dan
    lo c dan
    Made a load (engine) leveler. Never store bought anything that doesn't need altered. This allows me to pull wider blocks, assembled intake blower systems without dismantling everything, longer chain of course. .Primitive I know. I'm sure everyone has one I'm late making mine. . IMG_0392.jpg
  21. warbird1
    warbird1
    Finished the seat belt installation in the front of my '40 two-many door, installed the replacement speedometer that showed up at noon, and worked on the air deflector for the top of the grille. It might be drive able again by Saturday...
    Hamtown Al and stillrunners like this.
  22. WTF really
    WTF really
    Pulled the pan today. Hell yeah she's a 4 bolt and clean as hell. 20200702_132353.jpg 20200702_132410.jpg
  23. Yes a alumonum bracket with two bolt holes and one larger threaded hole.
  24. Back in November at a estate auction I bought a Desoto that had a 50 ford pannell truck grafted on to it. Truly desoto 001.JPG a Hideous affair. I paid $50. It was in a bad place and with the winter weather and over a 100 miles away. I just never got to haul it home. however I stripped some parts from it. Among the parts I took the rear (Barn Doors) today I sold that pair of doors for a $100. A old buisness man once told me that as long as you can sell at a profit you wont go broke.
  25. LeatherLunger
    LeatherLunger
    Caught the youngest making out with the family ‘37 while contemplating “to do’s” in the garage.
  26. topher5150
    topher5150
    Did some unkustomizing oh the ol 47. Everything was filled in with lead IMG_20200703_153856126.jpeg
  27. pkhammer
    pkhammer
    Got the motor mounts welded in, installed the 3rd member, bolted in the motor and trans and then set the body on the frame. 102_4105.JPG 102_4107.JPG 102_4108.JPG
  28. ERguitar
    ERguitar
    I have a pair of those porter cable grinders that I can't seem to kill. Aren't they about the same as black and decker?
    chryslerfan55 and stillrunners like this.
  29. ^^Porter Cable MUCH better, sed the woodworker.^^
  30. First stop at the Town Hall for biscuits, strawberries, donuts and a pie.
    Then the greenhouse for MORE flowers. Traveling with yer Sweetie can be fun! D68CA964-6146-44CF-9833-2EC8B34322B1.jpeg
    Somebody’s been busy! EVERY road in my daily radius is brand new blacktop, just over the past month, and my BNGR’s lovin it!
    Tim, chryslerfan55, catdad49 and 3 others like this.
