Technical My AV8 is to low in the front, help me!
Discussion in 'Traditional Hot Rods' started by Pete Poling, Jun 21, 2020.
  1. flyin flattie
    flyin flattie
    from Redmond OR
    Why not add two cut down leads to the top of your pack and put a longer grade 8 bolt in it to make it what ever height you’d like and save some money too.
  2. Pete Poling
    Pete Poling
    Because there is zero arch in my worn out front spring, it’s so flat that I don’t like my shackle angles. I’m not running shocks yet so it all adds up to a interesting ride when hitting the train tracks
  3. hotrodmano
    hotrodmano
    from Norway
    Remove fenders. Problem solved :D
  4. -Brent-
    -Brent-
    So, Pete, whatever did you do for a solution? Re-arch the spring, replace, tire swap? I am curious.
    I like the stance and I love that it has fenders.
