Technical Tool question
Discussion in 'The Hokey Ass Message Board' started by WTF really, Jun 30, 2020.
  1. WTF really
    WTF really
    Does anyone know what this is used for? Wooden handel the only marking I seen is stamped RIMAC Made In The USA 20200630_085512.jpg 20200630_085527.jpg 20200630_085534.jpg
  2. squirrel
    We usually like to see a close up, in focus, photo of the business end of a tool, not the handle end :)
  3. kb cookout
    kb cookout
    Looks like a seat head rest removing tool
    later kb
    squirrel likes this.
  4. alchemy
    alchemy
    I doubt you'll find it in the '63 manual. It's obviously older than that, with the wood handle. Check the '53 manual.
    Hnstray and WTF really like this.
  5. warhorseracing
    warhorseracing
    from cameron wv
    Is it S shaped? Need to also see a side shot.
  6. Terrible80
    Terrible80
  7. WTF really
    WTF really
  8. WTF really
    WTF really
    I believe it would be to weak for that.
  9. rusty valley
    rusty valley
    its for pushing ink pens further down into the defroster slot on the dash until you cant see them. outa sight-outa mind
    catdad49, X-cpe, RMR&C and 7 others like this.
  10. 6sally6
    6sally6
    Bent screw driver?
    Hog ring remover (everybody knows that!)
    6sally6
    No clue
  11. ct1932ford
    ct1932ford
    Flipping French fries one at a time!
    RMR&C, 41 GMC K-18, Hnstray and 2 others like this.
  12. Fancy dip stick handle?
    WTF really, Aeroman and rusty valley like this.
  13. lake_harley
    lake_harley
    Nose picker, for the ones that are really deep.
    Lynn
    RMR&C likes this.
  14. 302GMC
    302GMC
    from Idaho
    On a lighter side, I submit it was a valve related tool at one time.
    WTF really likes this.
  15. Mr48chev
    Rimac made an ***ortment of automotive tools and that may be a handle for one or may be a special purpose tool to do one specific task. There is a 1974 catalog on Ebay but I think that probably predates that catalog by a number of years.
    WTF really and Flathead Dave like this.
  16. Fortunateson
    Fortunateson
    Although the hook at the end is missing it appears to be a tool for removing hemroids!
    WTF really and alanp561 like this.
  17. ol-nobull
    ol-nobull
    Hi. as it is a flat bar instead of square stock and if that bend is factory done it could be used somewhat as a body s**** used to push down in the area between outer quarter panel and inner wheel well to push out dents. Same for deck lids. Definitely looks like some kind of LEVER. Although most I have seen or made were wider and usually made from a spring leaf. That's my best guess. Jimmie
    pitman likes this.
  18. Flathead Dave
    Flathead Dave
    from So. Cal.
    The handle is an ordinary handle used for files and what ever else that can be fit into it. Don't know what the shaft is used for.
  19. 56don
    56don
  20. squirrel
    this sounds most likely. Here's another one, to compare
  21. fourspd2quad
    fourspd2quad
    Vintage Harbor Fright pry bar?
  22. 41 GMC K-18
    41 GMC K-18
    My dad's tool box, in our wrecking yard, was a joke, even though he was the business owner, his roll away and his top box were pure junk, with pure junk tools that he had bought at swap meets, since he really didn't have to work on customers cars, he would from time to time have to twist a wrench to get a part off of a wrecked car in the yard.
    No one ever asked to borrow anything from his tool box for a good reason !
    More often than not, when he would put tools back in a drawer that was already a mish mash of stuff that didn't fit, he made a tool very similar to the one pictured here, he would use it to stir the tools around with the drawer closed, to get the offending socket or what ever to lay flat so that he could get the drawer back open.
    It worked.
    It was a great source of laughter and entertainment for the rest of the employees to watch the " Magic (OKIE ENGINEERED) , drawer unclogging tool " at work. My Grandfather is the one in checkered pants and my dad is standing next to him with the discolored spot on his sleeve.
  23. pops the rivets off denim shorts......
  24. pitman
    pitman
    Narrow "dolly" end edger or
    flat-bar w/end as lever-fulcrum.
    Supporting from backside
  25. saltflats
    saltflats
    from Missouri
    Used to release the clip on a tool box drawer slides?
