Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. topher5150
    topher5150
    Quality wise not sure, but this one has a proper arbor, and a ****on to lock the spindle. The other one I had to put a vice grips on the output shaft and use a wrench to swap wheels
    Sent from my moto z4 using The H.A.M.B. mobile app
  2. Zax
    Zax
    Stripped and sanded a set of early 50s Ford car wheels, and then cleaned and painted them. Hard work in the heat. But I started early and was mostly done by 1:30. I'll let then cure overnight and then add clear coat tomorrow.
    My new '53 Customline project is one step closer to cruise-in ready!
  3. WTF really
    WTF really
  4. stillrunners
    stillrunners
    from dallas
    Did an on-line auction....picked up some early Poncho stuff and some early OT English stuff....for re-sale to fund my 1940 project....and usable NOS parts for stock.....
  5. squirrel
    finally got the top on my T. It's not quite finished, but a lot closer.
  6. High test 63
    High test 63
    IMG_20200704_142810264.jpg got the linkage and shifter set up on my "new" Muncie. Gonna put in a new rear seal and get it into the T roadster
  7. Seon
    Seon
    Searched for missing part for the '58 so decided to do shop house cleaning. Surprising what one could fine after 20yrs of pigeon holing parts :eek:.
  8. LOU WELLS
    LOU WELLS
    from IDAHO
    I Parked On The Lawn And Celebrated Our Holiday...It Took All Day... 106366060_2676239776033620_7595926910597017986_o.jpg
  9. Got the p***enger door bottom patched/welded and ground, welded in the bottom door patch also..
    Poured on the light weight polyester auto body filler (Fancy name for Bondo) sanded and primed the outer door. Time to finish the inside next..
    Then pulled the intake off the engine that is going to be used..
    And what a SURPRISE
    Cleanest used engine I have ever seen...
  10. jimmy six
    jimmy six
    That will get u a ticket in my neighborhood and it’s not a co-op or hoa.
    chryslerfan55 and Lil32 like this.
  11. RICH B
    RICH B
    Bound and glued some carpet to cover the silver stuff on my '47. Made some brackets for my friend to mount his cowl lights down low and under the fender lip. Hoping they look better than the typical amber motorcycle lights. Now we need to switch out the headlight switch to an early style so park lights are not on with the headlights. Always something. IMG_20200629_160807.jpeg IMG_20200629_161034.jpeg
    Sent from my Nexus 5X using The H.A.M.B. mobile app
  12. alanp561
    alanp561
    YARD SALE:):):):D:D:D:D:D
    chryslerfan55 and WTF really like this.
  13. alanp561
    alanp561
    [QUOTE="JNKYARDDOG_1, post: 13653383, member: 324894"
    And what a SURPRISE
    Cleanest used engine I have ever seen...[/QUOTE]
  14. alanp561
    alanp561
    ^^^^^ Meant to say NICE
  15. patrick20
    patrick20
    Today, I started dis***embling my seized 327 on my 63 Impala restoration. Thank you guys for watching! Please like, share and subscribe on YouTube!
    chryslerfan55, ct1932ford and LAROKE like this.
  16. Blues4U
    Blues4U
    from So Cal
    Delco Remy replacement ignition system parts are/were common.
    Truckdoctor Andy and patrick20 like this.
  17. Blues4U
    Blues4U
    from So Cal
    Friday I gave the 47 a fresh coat of wax, it came out nice (though I noticed I'm starting to get some bubbling on the roof, I think is probably from some rust that wasn't properly dealt with before the PO had it sprayed).
    Then later that evening we took it out to a non-sanctioned cruise night for burgers, fries and Cokes.
  18. Blues4U
    Blues4U
    from So Cal
    aturday morning I took the 30 pickup out and joined a July 4th parade in a local town. There were a few nice cars there. These were shot in the parking lot after the parade.
    20200704_102157.jpg 20200704_102204.jpg 20200704_102215.jpg 20200704_102301.jpg 20200704_102630.jpg 20200704_102653.jpg
  19. squirrel
    I spent all day making a garnish molding for a T coupe. Instead of buying two new repops for a buck and a half.
    One is original, the other is new.
  20. Blues4U
    Blues4U
    from So Cal
    Great job Jim, from that pic I can't tell which is which. Of course, I'm not a knowledgable T guy, so there's that. But it looks like maybe the one closest in the photo has a roughened textured surface from age, so I would guess that's the original. Am I right?
    chryslerfan55, Lil32 and alanp561 like this.
  21. squirrel
  22. WTF really
    WTF really
  23. brokedownbiker
    brokedownbiker
    Spent most of the day fighting rusty and stripped body mounting bolts on my parts car. Almost ready to lift it off the ch***is. It is going under my 50 Fleetline project.
    Lil32 and 210superair like this.
  24. 210superair
    210superair
    from Michigan
    My damn key froze up in the column, so I tore down the steering column and popped it out, repaired. Ready to cruise to the drive-in with a buddy and the wives Thursday for malts and coneys....
  25. junkyardjeff
    junkyardjeff
    Cleaned out the shed,roof leaked and ruined most of the parts that were in there. 101_0029.JPG
    chryslerfan55, ct1932ford and Lil32 like this.
  26. 31hotrodguy
    31hotrodguy
    Pulled the 57 out from around back and bribed the little people to wash it for date night at the Mexican restaurant down the road! [emoji1303] Adjustments.JPG
  27. 1971BB427
    1971BB427
    from Oregon
    I've got a few hundred miles on my project car now, so today I climbed under it and did my usual nut and bolt tightening check. And a good thing I did! I found one nut and bolt on each spindle steering arm that had backed off almost 1/4"!! Yikes!
    I removed the bolts, and replaced them with new bolts, and locking nuts. Then while replacing them I also put Loc***e on the threads, just to double down on keeping them all tight.
  28. 4speed411
    4speed411
    Finally came up with a license plate light, finned body is a parking brake cover for a quad, fitted with a clear 3/4" trailer marker light inserted in the bottom. IMG_20200707_185726.jpg IMG_20200707_185726.jpg
    Tim, alanp561, chryslerfan55 and 4 others like this.
  29. Blues4U
    Blues4U
    from So Cal
    That reminds me, the key switch in my 47 was getting real sticky last time I drove it. I was going to apply some WD-40 to see if that would free it up. Thanks for the reminder....
    chryslerfan55 and catdad49 like this.
  30. squirrel
    I got an old ahoogah horn working in my T. It's so cute!
