Technical Quiet it down a little.
Discussion in 'Traditional Hot Rods' started by MikeG5211, Jul 6, 2020.
  1. MikeG5211
    MikeG5211
    Trying to figure out the most cost effective way of turning the volume down on the car a bit
    Right now it's just open headers. I'm looking at a couple of different things and I'm not sure what the most effective option is.
    Got these Auger style inserts, that I'm leaning towards
    https://www.speedwaymotors.com/Auger-Style-Muffler-Pair-3-1-2-Inch-O-D-,382830.html
    Or whatever you wanna call these
    https://www.amazon.com/SCHOENFELD-D...hoenfeld+Insert+Muffler&qid=1594077048&sr=8-2
    and possibly add a kick out
    Is there any other cheap options that don't change the look too drastically that I haven't stumbled upon yet? Thanks
    Edit- Just found this style also
    https://www.amazon.com/Spec-D-Tunin...f=psdc_15726991_t2_B00CP8K6OK#customerReviews
    dana barlow likes this.
  2. Mike Colemire
    Mike Colemire
    Augers done nothing on my A.
    MikeG5211 likes this.
  3. blowby
    blowby
    from Nicasio Ca
    Cheap options?
    I stuffed a couple of Harley mufflers in my pipes. Go to any Harley shop, they will have a bin of 500 take offs, pay you to take 'em. Mine got so quiet I had to ram a rod down and break the center disc out. Just right..
  4. dana barlow
    dana barlow
    from Miami Fla.
    If your handy at all,making your own is the way to go,you even get to try other designs for only your time. Tip,long pipes don't make as much sound. Short do.
  5. What size are your pipes?
    the second pic is a pretty standard motorcycle baffle. You can get them in different lengths and they do help
    kick outs will help also
    where are your headers dumping ?
    pushing them behind the p***enger compartment does wonders.
  6. Mimilan
    Mimilan
    If you don't care about HP loss, the spiral type are quieter.
    We tried some on a flow bench for our race-car [we needed 690 cfm x 2 for our engine]
    Our pipes were 5" diameter side pipes [for a Corvette]
    The spiral type were just over 540 cfm.
    Eventually we made V shaped baffles to create 2 x wave type flow [and cancel each other out]
    We got down to 95db [FIA limit]
    Make some bolt on extensions for your Headers and use "supertrapp" mufflers [the noise can be tuned]
    This is common on Sprintcars
  7. MikeG5211
    MikeG5211
    They are 3 3/8 ID 3 1/2 OD
    Tim likes this.
  8. slayer
    slayer
    The Speedway augers are loud, but not quite open header loud. Me and Dad built side pipes using 2 1/2" header mufflers (gl***pack) and collector extentions. Much quieter, but still loud and aggressive sounding.
    AHotRod and MikeG5211 like this.
  9. 38Chevy454
    38Chevy454
    Just my opinion, but those supertrapp style sound like ****. The baffle type probably what I would use. You might need to make the holes deeper to the center of tube to get more sound reduction.
    Sent from dumb operator on a smart phone
    AHotRod likes this.
  10. sloppy jalopies
    sloppy jalopies
    I was told that running a crossover pipe between the two sides will really help... have not tried it...
    Just Gary likes this.
  11. MikeG5211
    MikeG5211
    Any thoughts on this kind? possibly with holes drilled in the pipe and surrounded with fibergl***.
    I was thinking with the auger style I can pack some fibergl*** in-between the sections, that would surely do something right? dunno what kind of back pressure that would cause though. Anyone ever try either?
    Edit - just gonna grab the ones in the pic here and experiment with them, what could go wrong for 30 bucks?
  12. squirrel
    I'd spend the $30 on some pipes to get the outlet a lot further back on the car. I'd also put some mufflers on it. But maybe I'm getting old.
    ottoman, Tim, AHotRod and 12 others like this.
  13. gene-koning
    gene-koning
    I'm with squirrel. I'm getting old too. I think maybe I should be protecting what hearing I have left. You think about these things as you get old, asking people to repeat things all the time is tiring. Gene
  14. jimmy six
    jimmy six
    I put an auger in front of the 70 series Flow Master on my 5.0 pickup and it really helped the drone.
  15. Mr48chev
    I am old and I'd be figuring out a plug for the headers and run pipes in and under the car and back past the rear axle with your choice of mufflers.
    Don't Laugh as my 23 T was the grand daddy of all suspect T buckets. Had a buddy who did custom van interiors using a lot of **** carpet who had the hottest looking wife in Texas in 1974 who gave me some left over carpet.
    Anyhoo with the 5.00 Dallas swap meet (in the bank parking lot) "obsolete" megaphone headers and a couple of muffler shop bends I stuck a pair of Purple Hornie mufflers on it. Looks like **** now but it really sounded good then.
    Maybe a pair of gl*** pack blanks the right diameter and some turn outs would make a sweet sounding setup and not look anywhere near as bad as mine did. Thinking back, for what I paid for those, the paint to paint them and the bends I could have had a muffler shop put real exhaust on it then.
  16. Mimilan
    Mimilan
    Yep, but they would certainly sound beautiful music after you lose your hearing.
    MikeG5211, 2OLD2FAST and Just Gary like this.
  17. hotrodjack33
    hotrodjack33
    Ran these Sandersons for 12 years with down-pipes to Thrushes. In all those years I only un-capped the headers twice...made it sound like a demo-derby car...hated it. 32p.jpg
  18. rusty rocket
    rusty rocket
    Old school for me. I rolled up a length of chicken wire and stuffed it down the pipe. C2EA6764-9605-4D03-912F-0165465C864B.jpeg B2D36331-1CB3-46E1-ACBC-3F192F1611BE.jpeg Hey it works.
  19. Blues4U
    Blues4U
    from So Cal
    I'm running the auger style baffles in the lakes headers of my A, and they worked excellent for me, the volume dropped just about 10db (measured with a decibel meter), which is just about perfect, quiet enough to not cause problems with the neighbors or draw unwanted attention under acceleration (and no ear damage for the occupants), but loud enough to satisfy the desire to hear the engine. No discernible loss of performance at all, & the sound is great.
    Driver50x and dirty old man like this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Dropped it 10 db , from ? To ?
  21. error404
    error404
    from CA
  22. Blues4U
    Blues4U
    from So Cal
    It dropped it from ~110db measured about 1' from the opening of the turnout, down to about 100db, at idle. Inside the cab it dropped from around 95db to about 85db, at idle. Under acceleration it's louder, but that's where the biggest drop in volume occurs, but I didn't attempt to measure that. I used to come back from a 45 minute drive with my ears ringing, no more.
    2OLD2FAST likes this.
  23. Blues4U
    Blues4U
    from So Cal
    These threads are always worthless without some video/audio.
    wheeldog57, 2OLD2FAST and MikeG5211 like this.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    OSHA says anything sustained at over 70 db will damage your hearing.
    Blues4U likes this.
  25. squirrel
    It's too late for most of us....
    (but we can save what's left)
  26. southcross2631
    southcross2631
    I had Auger inserts on my Street rod Morris minor it had fenderwell headers with 3 inch pipe turning out in front of the rear tire. It had a 5.0 Ford and sounded just like a small block Cobra with side pipes.
    you could carry on a conversation with the windows down at 65 mph on the highway. 2013-08-28 14.25.16.jpg
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    By God I'm tryin'
  28. southcross2631
    southcross2631
    I have a 2 1/2 inch set that are brand new .
    I will sell them cheap. They are already inexpensive from Speedway. They have been on my shelf for over 3 years
  29. MikeG5211
    MikeG5211
    Well I'm not a complete fool, I have worn a earplug at least in my left ear the few times ive been out.
    Ill let ya know how these silencers work out. Have a feeling ill end up modifying the **** out of them if they don't work too well from the get go.
  30. Lloyd's paint & glass
    Mike I've ran these on a couple of my Model A's, bit pricey, but they work great. You'd probably have to do a little modification to bring them up closer to the body, like a pie cut, but you could paint them or wrap them. The mufflers are effective, they extend the outlet towards the rear of the car, and they have the turnout. 20200708_230517.jpg
