1952-59 Ford Wheel and Tire Sizes - What do you run?
Discussion in 'Off Topic Hot Rods & Customs' started by 53vicky, Jul 6, 2020.
  1. 53vicky
    53vicky
    Hi guys:
    I'm researching tire sizes for my '53. I currently have bias ply 670r 15 tires on my stock wheels that are about 15 years old, and its time for a new set. On my old non-hamb-friendly wheels, which were 15x7 w/ 3.75 backspacing, I ran 215/75r15 tires and had a bad rub on the driver's side rear without any lowering blocks. Now that the car is lowered w/ 2" blocks, and now that I'm looking at radial tires, what should I get to avoid a rub?
    What do you guys run for tires? Would the 215/75r15 tires rub when mounted on the narrower stock 5" wheel?
    Thanks.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    It is the offset of the wheel that is key and the section width of the tire that you need to address. This has been brought up often here and this link can be found on Page 4 of the "Sticky" https://www.racingjunk.com/news/how-to-get-perfect-rear-wheel-and-tire-fitment/ When shopping for radials in almost every case the cheaper the price the less section width they tend to have,a 205/75/15 would probably be a better fit. The 15" steel wheels from a 90's Crown Victoria have a more positive offset this brings the tire further away from the lip of the wheel well. Here are the specs: https://www.carid.com/1994-ford-crown-victoria-factory-steel-wheels/ to convert the 12mm to inches. https://www.metric-conversions.org/length/millimeters-to-inches.htm
    53vicky likes this.
  3. Pheaton193
    Pheaton193
    from Reno, NV
    205/75/15 work well for me. ECD55A71-AAF0-4EC5-AD40-D54D20E76632.jpeg
  4. Thriftmaster
    Thriftmaster
    from Canada
    I run 205/70R/15 111 - Roy's 1953 Mercury HT.JPG
    56longroof, JeffB2 and 53vicky like this.
  5. 53vicky
    53vicky
    What brand of tires are those? I love the wide whites.
  6. Pheaton193
    Pheaton193
    from Reno, NV
    “What brand of tires are those? I love the wide whites.”
    Diamond Back
    Dos Cincos and 53vicky like this.
  7. Black Wagoon
    Black Wagoon
    1/2" Backspacing on Crown Vic???
  8. jax59
    jax59
    from East Bay
  9. Texas57
    Texas57
    Were talking two distinctly different methods of measurement. Backspacing is different from offset. I haven't looked at the charts, I have enough trouble trying to keep my mind from getting too confused, but I suspect a 1/2" measurement you may have seen on the charts is offset, not backspacing. Most use the backspace method.
    guthriesmith likes this.
  10. jimmy six
    jimmy six
    52-56 are real close to the same. I have American Vintage Torque Thrusts,15" x 6" with standard 3.66" back space. clears everything including front discs with no spacers. If you've lowered the rear you will probably have trouble getting 7" wide off. Bumper or body jack on rear frame is a must. I use axle and rear frame jacks. For tires I use 205-75 fronts and 215-75 rear. See Avatar.. Good Luck
    53vicky likes this.
  11. 53vicky
    53vicky
    Thank you for the detailed response! I was thinking about doing this same set up with 205s in front and 215s in the rear. Still have some tread left on the bias plys for now.
