Technical Welding upside down-ish
Discussion in 'The Hokey Ass Message Board' started by topher5150, Jul 8, 2020.
  1. topher5150
    topher5150
    So I'm working on welding the top half to the bottom half of my car together. The trouble I'm running in to is that the welds aren't staying in place. I'm thinking that if I make some small welds and kind of sew it together that might work, but I'd like to get your opinion first
    Sent from my moto z4 using The H.A.M.B. mobile app
  2. alchemy
    alchemy
    I can't TIG upside down worth a ****. And MIGing upside down is hard too. Practice makes perfect.
    What system are you trying?
    topher5150 likes this.
  3. topher5150
    topher5150
  4. Bandit Billy
    Bandit Billy
    WOOPs stands for Welding Out Of Position and is the usual result in my garage when I attempt it.
  5. topher5150
    topher5150
    I was trying from the inside, but there is a lot in the way and kind of tight
  6. alanp561
    alanp561
    Show me what you're working on. Is it sheet metal, heavier gauge, what? Whatever it is, it sounds like you're running too cold or not moving fast enough.
  7. topher5150
    topher5150
    It's sheet metal, a lil on the heavier side 18-20 g.
  8. flatford39
    flatford39
    It might help if you cleaned the surface up a bit. Also what is holding it together why you weld???
    j-jock, Dino 64, low down A and 10 others like this.
  9. DDDenny
    I recall having the same issue once but don't recall how I rectified it, may have had the wrong wire speed setting or a bad ground.
    By the way, you haven't lived until you have had a hot weld BB land in your ear:eek:.
    The sound and smell of sizzling ear hair is hard to forget!
    I have since made a pact with myself not to weld upside down anymore.
    badgascoupe, Thor1, 41rodderz and 3 others like this.
  10. mohead1
    mohead1
    Well first of all, you have zero prep done...need nice clean metal to make it right...not rusted over stuff...
    Sent from my SM-G960U using Tapatalk
    j-jock, clem, Dino 64 and 13 others like this.
  11. J. A. Miller
    J. A. Miller
    from Central NY
    One word - rotisserie.
  12. Marty Strode
    Marty Strode
    When wire welding overhead, it always requires a little more wire speed. And always, the better the weld area is prepared, the better the outcome.
  13. john worden
    john worden
    from iowa
    Yes your prep is poor.
    Making the effort to position yourself in a comfortable position will help too.
    Mark Hinds, X38, alanp561 and 3 others like this.
  14. woodiewagon46
    woodiewagon46
    from New York
    It's all about practice and practice some more. When I took my certification, it requires a 1" test piece in overhead and a 1" test piece in vertical. I probably practiced for 120 hours in overhead alone. Of course the certification is only stick welding, TIG and MIG are a heck of a lot easier. It all comes down to practice! As mentioned your metal is very rusty and I'm sure most of your problem.
    alanp561 and VANDENPLAS like this.
  15. squirrel
    Also, pretend you're in welding school, and learn and practice on something besides the car...like some s**** metal, clamped in the upside down position. Then when you've developed the technique, move on to the real thing.
  16. I second the faster speed. I've been welding for 30 years and tried it all! Little faster on the wire speed helps when overhead welding
    Bbdakota and alanp561 like this.
  17. ClarkH
    ClarkH
    I'm no expert, but as has been said, you want bare metal where you're welding, and bare metal where you're making the ground connection. Also, those gaps in the unwelded portions are too wide, but presumably you have a plan for that.
  18. Darin Younce
    Darin Younce
    gotta clean, need snug fit clamped well , might wanna run short beads in several areas, Iow skip around to prevent warping and try higher wire speed as suggested, perhaps some of that upper part can be welded from inside. Welding out of position is already difficult so don't increase that difficulty by welding rough and unclean material.
    alanp561 likes this.
  19. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    First stop is prep. No sense welding dirty rusty metal, 2nd, if youre outdoors and theres any sort of breeze its taking away your shielding gas, either get out of the breeze or crank up the gas
    alanp561, williebill and VANDENPLAS like this.
  20. seb fontana
    seb fontana
    from ct
    Big gaps = big trouble, not clean = trouble, trying to run a bead = trouble..
    Look on U tube for welding help. Extreme amounts of info.!!
  21. jetnow1
    jetnow1
    from CT
    Clean your metal on both sides, get the rust off. Be sure to do this on your ground as well, put ground as close to weld as possible. What size wire are you using, and is it name brand or chinese wire?
  22. Boneyard51
    Boneyard51
    Welding up-side-down is also the hardest for me, also. But like said, clean the metal and close the gap. I find that short bursts of weld work for me. If I hang in there , it will fall out! But my brother-in-law, an expert welder, always said I weld too hot! Lol
    Bones
    VANDENPLAS likes this.
  23. Way back when I was learning to weld it was called Overhead and if you couldn't run a good bead there you wern't going to get a job welding. That was Stick Welding, I don't even know if Mig was invented yet. And Yes, get things cleaned.
  24. goldmountain
    goldmountain
  25. BamaMav
    BamaMav
    from Berry, AL
    I used to be able to stick weld overhead, but the last time I tried it was as many boogers as it was weld. That's what being out of practice will do for you. Tried a little with my flux core mig, did fair, but actually did better with a 6010 rod. Got enough weld on it it won't come loose for a while, even if it was ugly....that's what grinders are for!
  26. Another thing to pay attention to. What are plugged into? See your welder where it says "20 amp circuit"? Do you have one? Anything less and your machine will not work right. Are you using an extension cord? If you are you lose even more oomph. Lots of factors. Prep the metal and go from there.
    Boneyard51 and topher5150 like this.
  27. topher5150
    topher5150
    A lot of good info thanks again for the help.
    And to recap
    -I was grinding on that damn thing all morning and it only seemed to spread it around
    -yes I know I have some horrendous gaps.
    - I've been keeping to small spots to prevent warping
    - I got the wire from a local welding supply store .023
  28. Marty Strode
    Marty Strode
    For the wider gaps, if possible, I would use an aluminum, br***, or copper backup strip on the back side, while welding. Anyway you do it, it's not a simple job.
  29. Maybe I'm not looking at that photo right but it seems to me that if you were inside the trunk space you could weld 80% of that seam in top position.
  30. maybe you need a few days then , huh?
    Should take about 30 mins. And Should be done before the fitting took place. but it needs de rusted, at least knock the loose stuff off
    Pist-n-Broke and alanp561 like this.
