Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. topher5150
    topher5150
    My new supervisor says I've been spending to much time on the H.A.M.B. IMG_20200707_150237772.jpeg
    Sent from my moto z4 using The H.A.M.B. mobile app
  2. Lloyd's paint & glass
    Picked up a little 283 for my wife's project, gonna pull it apart and take the block and heads to the machine shop. Plans are a thumpr cam and 3 deuces :D 20200707_205138.jpg
  3. High test 63
    High test 63
    IMG_20200708_152250184_HDR.jpg IMG_20200708_152349632_HDR.jpg got muncie trans in last night to replace busted saginaw.[AT
    TACH=full]4747945[/ATTACH]
    Everything works fine although the shifter is a bit too short... Something to hunt for at canfield swap meet... Also helecoiled the thermostat housing on intake to cure a pesky coolant leak thats been bugging me for a while.
  4. squirrel
    I made a door lock knob. Because one was missing, and repops are stainless instead of aluminum.
    I also made a trunk lid support, but didn't get a picture.
  5. 26hotrod
    26hotrod
    from landis n c
    I drove the coupe to get some gas 2day. It was thumbs up and smiles all the way there and back...……..
  6. mike bowling
    mike bowling
  7. Hamtown Al
    Hamtown Al
    Got my 32 out and drove over to a club member's playhouse to see what he had in his "showroom.";)
    The Desoto project got shuffled out of the back work area it looks like. I think he was off with his wife in his 48 Chrylser convertible.:)
    Twas great to buzz around on errands in the little 32... dang rear tire kept spinning!!:eek::D
    That big Buick sure is torquey!:)
    It still seems special to be driving a car that was in, and used!, in the same family for 75 years before it got to me.
  8. RICH B
    RICH B
    Dusted off my bought in '93 (this is a long term project) A/C; changed the R12 expansion valve to a 134 version and added a cable water valve (so the heat isn't just all or none). Stuck it in place for I hope the last time. Found only a few drips under the trans; hope it is residual and all the leaks are fixed. Switched the park light wire in the headlight plug on Mike's '33 so they are independent of the
    headlights (nice if they noted this in the directions, at least the included the earlier type switch with the kit). Fixed a missing ground on the tach's light along with a loose nut on the fuel gauge; wire gremlins must have been up to the usual no good.
    192 ac (Medium).jpg IMG_20200708_100108 (Medium).jpg IMG_20200708_100141 (Medium).jpg
  9. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    SLICK:cool:
  10. Darin Younce
    Darin Younce
    Dang man that is good work.
    Atwater Mike and chryslerfan55 like this.
  11. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    I am lovin that car! ******* with a big nailhead for power, you have the stuff my dreams are made of:cool:
  12. Darin Younce
    Darin Younce
    No pic sorry , but I dis***embled my 39 ford shifter tower cleaned and lubed and installed new roll pins ( old one were loose) and it operates much better but I gotta do some work on the shift lever lower portion , will weld flat spots to build up then file it down . should help with some of the sloppiness.
  13. MikeG5211
    MikeG5211
    Well... I changed my brand new water pump last night that I put a crack in by over-tightening the side plug with another brand new pump, then went to take the car for a spin this morning only to discover that I somehow put a hole in the Rad last night. So I learned how to weld radiators today with just a basic propane torch... took it for a spin, seems like I did a good job.
  14. LAROKE
    LAROKE
    Third time's the charm. At least that's how it is in my shop.
    lothiandon1940 and MikeG5211 like this.
  15. Hamtown Al
    Hamtown Al
    Yesterday we finally completed a deal we made early in the year on my last 40 pickup cab. He was coming from CA in March to get it and store with relatives in VA. Then you know what happened!! Coronavirus!!:eek:
    Anyway, he finally got here yesterday with his brother-in-law to pickup the cab and other new Ch***is Engineering parts as well as a set of caps, wheels, and tires. I put him in touch with another friend of mine that lives just off I 40 in New Mexico. He bought a 4 banger with 5 speed from me last year and hadn't managed to get it due to a mul***ude of reasons. They worked out a deal where the guy buying the 40 would take the engine, trans, etc back to NM. Car guys helping car guys... ain't it great?!!
    IMG_5730 leaving 07 09 2020.JPG Before loading the engine. I'm hoping the guy was thinking about the great treasure he just purchased!:D
    All loaded up and all tied down... we hope!:eek::D
    Anyway several club members joined us and helped with the loading. I took them to lunch afterward to my first meal with anybody in a restaurant since last March. The food was good but refreshing the old fellowships with pals was priceless.:)
    PS We did take all the loose stuff off the tailgate before they took off!!;):D
  16. lothiandon1940
    lothiandon1940
    Great story, Al. Amazing how just some semblance of normalcy goes a long way to preserving our sanity..........................Don.:)
  17. ERguitar
    ERguitar
    Made yet another patch panel.
    I think this is number 12 with at least that many to go.
  18. topher5150
    topher5150
    Went on an antiquing adventure with mom and the wife. I swear I'm finding more parts at antique shops than anywhere else IMG_20200709_151201787.jpeg
  19. Jalopy Joker
    Jalopy Joker
    went to a couple of local yard sales 20200711_075144.jpg 20200711_072306.jpg 20200711_072312.jpg 20200711_073317.jpg 20200711_073336.jpg 20200711_082301.jpg
  20. squirrel
    I did a little band adjusting. The pedals went a little too far on my inaugural drive into town yesterday. IMG_20200711_125338103.jpeg
    Sent from my Trimline
  21. Took a drive to Tucson(Catalina) this morning, Left here @4am got there @7. Went to pick up a new rear end for the 34, Was complete so took of the torque tube and radius arms and drive shaft off to fit into the van.. Njoyd the car collection this dude had wish I could show photos but not allowed to, Sorry have to respect the wishes of other people.
    The place was packed full of stuff wish I had more time but the heat today was going to be MISERABLE !
    Did get this pair of Lincoln Valve cover tho
  22. 57 Fargo
    57 Fargo
    ***embled the p***enger door of the Fargo today. Also drove the convertible to town twice.
  23. MikeG5211
    MikeG5211
    alanp561 and chryslerfan55 like this.
  24. stillrunners
    stillrunners
    from dallas
    Getting the 392 hemi block ready to ship to a new owner/builder..... 20200510_140757.jpg
    alanp561, chryslerfan55 and Lil32 like this.
  25. Paul
    Paul
    Editor
  26. Sky Six
    Sky Six
    from Arizona
    Took the '57 out for a nice ride this morning around 4:30. Was only 89 degrees and clear. Will hit 115 later today.
    Hamtown Al likes this.
  27. LOU WELLS
    LOU WELLS
    from IDAHO
  28. patrick20
    patrick20
    Filmed part four of my "Will It Run?" video series on my 63 Impala 327 engine. I also dis***emble and clean the original 57 year old alternator. Thank you guys so much for watching, and supporting my channel! Please like, share and subscribe on YouTube!
    alanp561 and j hansen like this.
  29. Paul
    Paul
    Editor
    like this: clutch nut
    j hansen and JNKYARDDOG_1 like this.
