Technical Blasted or Dipped Bodies BARE STEEL... Then what???
Discussion in 'Traditional Hot Rods' started by The37Kid, Jul 9, 2020.
  1. The37Kid
    The37Kid
    Just saw a nice blasted body in a HAMB thread and wondered about the cleaned to bare steel protection. What have you used to cover all the behind the panels brackets and nooks & crannies so they don't start to rust?
  2. Gofannon
    Gofannon
  3. Just Gary
    Just Gary
    Epoxy primer.
    mgtstumpy, gnichols, dan31 and 5 others like this.
  4. The37Kid
    The37Kid
    Gibbs is good on an outer surface, but once behind things getting it off for primer to stick is a problem, I would think. Bob
  5. jailhousebob
    jailhousebob
    from Illinois
    Blasted metal starts to rust immediately.I like to get it in primer right away.Here's my 32 5/w body after being soda blasted.It got a coat of self etching primer ( no pic of that) and then a coat of ppg black epoxy primer ( the quarter panel pic.) Not the dp primer,this is a high build epoxy that sands like lacquer primer but don't shrink, great stuff !
  6. theHIGHLANDER
    theHIGHLANDER
    Lots of POR haters out there, but for the initial protection in the areas you'll never touch again it's a viable solution. Let it ooze through seams and lob it all in behind those brackets and such. Then forget it, FOREVER. The rest, give it a light coat of epoxy just to protect things as you work. Not like it's gonna live in the driveway for a year or 2, right? Did you already do this or is it in the game plan? If there's welding and the like I like to do all that before stripping. Clean as needed where to do the work then have it dipped or blasted. Gives the welds and new metal the same treatment, same prep, cleans hidden areas too that are not logical to try and prep from behind so let the stripping process do it. I'm kinda lazy like that...:rolleyes:
    gnichols, Blues4U and stillrunners like this.
  7. kabinenroller
    kabinenroller
    I have had numerous vehicles chemically stripped, in my opinion it is the best way to start a rebuild. I always have the car stripped then bring it back to my shop for metal work, fabrication and mock up. (Basically ***emble the whole car) I then send the car back to the strippers to have everything e coated, this ensures that all the surfaces including the area’s that are inaccessible are protected from future corrosion.
    This does ad to the cost of the project but I prefer this method.
    Here is my Comet after e coat.
    Jim
    774D36A7-807C-4E63-A885-16F133D73D6B.jpeg 815F6C8C-5338-4820-9BE4-2C28B689D728.jpeg
    Lil'Alb, UGOTBIT, mgtstumpy and 5 others like this.
  8. -Brent-
    -Brent-
    I cannot imagine Gibbs on a blasted surface. It's too rough. On a metal finished surface it's really great and easy to apply.
    I epoxied my old T roadster after blasting. It's still good after a decade.
  9. Runnin shine
    Runnin shine
    After I use mol***es to its masterful ability.
    I’ve used por which is great
    And when I’ve ran out I’ve subs***uted with this from The orange box store
    I’ve had my 32 parts laying around the garage for over four years with no new rust showing up. Every time the wife or kids bring snow or rain in there I freak out but nothings happened. When the garage sweats from a temp swing or high humidity I cringe but still notta.
  10. The37Kid
    The37Kid
    I just saw a body in a thread and wondered how all that never seen stuff gets coated. Some stuff is 80 years old or older so ever if left bare I guess it would be OK to some people, but not to me. Bob
  11. koolbeans
    koolbeans
    Cold phosphate, then PPG DP90.....then top coats....bullet proof.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    2OLD2FAST and Just Gary like this.
  12. -Brent-
    -Brent-
    My coupe body was blasted and worked on and then shelved with nothing done to it. For 10 years it sat aside with no sealer or protectant. We live in a dry climate and it was inside, so overalls it was good.
    After all that time there was very little oxidation. It really depends on where the body is.
    The37Kid likes this.
  13. The37Kid
    The37Kid
    Same here I've got stuff that was blasted years ago still looks good. Ever meet someone that has hands the ooze rust forming sweat, hand prints over everything they touch?
    Bob
  14. -Brent-
    -Brent-
    I have seen it. My coupe had some sweat drops, haha.
    I have a raw decklid panel that has a couple finger spots.
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    According to tbe Gibbs website and video, pri.er and paint over Gibbs is not a problem
    I've done it on a few parts and have not had a problem with paint.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  16. blazedogs
    blazedogs
    Been discussed before Dipping Have had this done on a few old Cushman motor scooters. If there is ( any ) dipping chemical left in the seams it will lift the paint. Yup it,s happened to me & I thought I was being very thorough with cleaning & blowing out the seams. Just my opinion.. gene
    Lloyd's paint & glass likes this.
  17. kabinenroller
    kabinenroller
    I have heard this before but as I mentioned in my previous post I have had numerous body’s dipped and have never had an issue with paint lifting. I believe that the e coat process helps prevent the issue, but also every body (or parts) I have had dipped has been painted by the same person. He prefers the item be stripped chemically instead of blasted, I know he has some special concoction that he uses on the metal before he applies the epoxy primer. He does high end restoration work and his paint never fails. I feel that fabrication and welding on clean metal yields better results than working with dirty metal.
    These are just my personal opinions.
  18. The37Kid and -Brent- like this.
  19. Richard Head
    Richard Head
    I used to prefer to do my metalwork on bare sandblasted metal. I thought it was a waste of epoxy primer to coat a freshly blasted body, then strip half of it off in the metalwork phase and then what is left has to be sanded to put more epoxy on top of it. I figured it was easier to just sand any spots that started to rust during the metalwork phase, then epoxy after the work is done.
    A couple of months ago, a guy brought me a body that another guy started the metalwork, then got cancer and coated the whole sandblasted body inside and out with ospho. I have now changed my tune about having to work around epoxy. I would take sanding epoxy any day over having to neutralize all of that phosphoric acid. So far, I've probably got 20-30 hours of brushing and scrubbing and 2 quarts of ospho to get all of that **** off of the car.
    Dave
  20. the flatlander
    the flatlander
    My son & I have a "sandblasting" business here. We strip whole cars , bodies, frames, whatever. We do work for the Petty Garage & Detroit Speed. Usually they take the bodies bare metal & epoxy prime them in their shop. When we do prime bare metal parts we use PPG 375 or 377 epoxy. The guy here is right, getting to tight places is tough. We blast with 80 grit Garnet. We blast inside so can reuse it a few times. The hardest part is cleaning out the material left in the body . Blowing it out & vacuuming works best. If we have a tight place we either flood it with primer after spraying it with a substance similar to Ospho (which u can paint over), or if customer wants using POR which I don't like. Superman couldn't get it off. Usually on trailers, truck frames, etc., we use Rustoleum rusty metal primer (over bare metal) & topcoat with Rustoleum paint, usually s. g. black. We do have customers that want their parts powder coated, that's when parts have to be 100% cleaned. I started the co. BLASTMAN (see us on facebook) in 1984, so we have lots of practice. Our process does not warp metal ! , like many sandblasters do. good luck. contact me if I can answer a question, thx Alan
  21. A Boner
    A Boner
    Unless you live in the desert, what ever you decide to do, you better do it quick! Rust never sleeps.
    ct1932ford likes this.
  22. CudaChick1968
    CudaChick1968
    I think we know some of the same people. :D
    Screenshot_2020-09-02-10-49-50-1.png Screenshot_2020-09-02-10-48-36-1.png Screenshot_2020-09-02-10-49-58-1.png
    dan31 and lothiandon1940 like this.
  23. goldmountain
    goldmountain
    It is so nice here where the air is dry.
  24. noboD
    noboD
    Years ago I worked with a guy that drank a few beers several days a week. He stank of cheap beer the next day. BUT every piece of bare steel he touched those days wound up with his rusty fingerprints on them.
  25. RichtersRodz
    RichtersRodz
    I've had a nightmare time with my bare 400 SBC. I spent $1200 on the shortblock work, and had to store it in a rental building when I moved. I go to empty the building months later, and it looked like it had just come out of a creek!! I was almost in tears! I took it back to the shop for a fresh hone and dunk again, and now sitting in the garage, it's slowly starting to flash rust again. I just keep trying to coat it with oil until I can get it built..
  26. HOTRODPRIMER
    HOTRODPRIMER
    I have always used metal prep followed with etching primer. HRP
  27. noboD
    noboD
    Gibbs and a garbage bag.
  28. mgtstumpy
    mgtstumpy
    I've had all my bodies sand blasted by someone that knows what they're doing. Once done I've always blown the debris out and epoxy etch primed everything. My current 46 Olds body has been sitting for years without issue, only slight surface rust is coming through on 1K primed parts. If not sealed parts could / will flash rust within a short space of time.
  29. Dino 64
    Dino 64
    from Virginia
    Blasted and epoxy primer.
    I’ve used Gibbs and it works great. I wipe it with prep-all and paint with no issues 480F6849-D64A-44BC-B3CA-28AF4885D524.jpeg
    mgtstumpy and Just Gary like this.
