"the desert express.1951 ford coe pick up"
Discussion in 'The Antiquated' started by iwanaflattie, Feb 21, 2012.
  1. iwanaflattie
    iwanaflattie
    The purple is hooked to the ignition I believe...I gotta dig my notes..
  2. Bandit Billy
    Bandit Billy
    Purple is kind of the universal GM color for the wire that runs from the ignition, through the neutral safety switch and on to the starter solenoid to energize it. I plumb all my cars alike so I always know where that wire is headed. I have a friend that is color blind, man I hate working on his cars. :cool:
  3. iwanaflattie
    iwanaflattie
    If I go with the 3 post starter...can I just "add" the smaller red and black to the red "battery" wire going to the fourth post?
    They are connected anyways right?
    Outback likes this.
  4. Phil P
    Phil P
    If I'm not mistaken the other small terminal by p***es the resister wire for the ignition so it is only hot when the starter is energized to give the coil 12 volts on start up.
    Phil
  5. Bandit Billy
    Bandit Billy
    Not knowing where everything is headed I'd be shooting blind. On a 4 post GM starter the two small posts are labeled R and S. I cant tell from the pictures the labeling on the solenoid. The purple wire (ignition switch) should go to the S post. The R post is used on early GM vehicles to supply voltage to the coil during cranking I believe.
  6. iwanaflattie
    iwanaflattie
    This is the wiring I followed per speedway instructions
  7. Bandit Billy
    Bandit Billy
    I had a LT-1 vette that used 12 volts to start supplied from that R terminal, then 8-9 volts after starting to run the early GM transistorized ignition. Someone left that wire off during starter replacement once upon a time and made that corvette the hardest starting car I have ever owned until I figured it out.
  8. iwanaflattie
    iwanaflattie
    And this
    Except I don't have an 80 amp alt..just a regular alt
  9. Bandit Billy
    Bandit Billy
    I have seen a lot of wiring diagrams that run the one wire output on the alt to the starter like the above. I prefer to run it through a kill switch but that is just me. On your photo, where are the red and black leads on the other small solenoid post headed? Are they the + coil leads? Why 2 of them and why is one black?
  10. Phil P
    Phil P
    They are only connected when the starter solenoid is energized to start the engine.
    Phil
  11. iwanaflattie
    iwanaflattie
    So I just peeled the "black" wire you just asked about, It is the soleniod wire (red) with a "fusible link"(black) it goes to the "Battery" side of the ignition switch
    the RED wire is attached to the BIG RED BATTERY cable ,I honestly dont remember why I connected it like that it didnt come with the kit...it can be cut off..
    Thats easier to understand,the way I had it with the smaller wire coming out of the POSITIVE side of the battery Cable,,the solenoid was energizing the solenoid and coil at all times..
    if you guys havent read the entire thread. I am running HEI ..
    tthanks for all the help
  12. Bandit Billy
    Bandit Billy
    That explains why it is black and on + post. Always scares me to see black wires on positively charged posts. Makes me think of fire extinguishers and sirens.
    I could go scan your post but it's late, what are you running for a distributor and coil? Where is that fusible link headed?
  13. iwanaflattie
    iwanaflattie
    The fusible link heads to the battery terminal on the ignition switch...the ignition switch has the purple wire u see on the starter post that energizes the starter to spin...
    The ignition switch also has the coil wire that supplies 12v for starting and running...
    I believe I can hook the battery and solenoid wire together and leave the purple(S) Switch wire on the other terminal... I will try tomorrow
  14. iwanaflattie
    iwanaflattie
    It was a ****ing mess..
    But in the end I swapped solenoids and everything is good to go
    tb33anda3rd likes this.
  15. tb33anda3rd
    tb33anda3rd
    is it running good?
  16. iwanaflattie
    iwanaflattie
    To me it's running rough...like a vibration it didn't have before...
    I checked all spark plugs wires and the firing order everything looks good..
    It could be a bad spark plug...
    I hope
  17. tb33anda3rd
    tb33anda3rd
  18. iwanaflattie
    iwanaflattie
    Wow it's only been 4 months...
    I figured the running rough part/noise,it was a loose flywheel...
    The bolts got loose with time and made that noise...it ran great after I fixed it..
    I stored it at a friend's garage for a few months but I'm losing that space...
    I'm getting it out of there on Friday morning,then I'll go to NV DMV to get it inspected,then I'll trailer it to California for a few months...I'm in the process of buying my first house at the end of the year... hopefully having my own space,will lead to many more projects coming out of it.. IMG_20200627_091823.jpg b12d79b0ff6f452181e46c5147b50c16.jpg received_300013287818430.jpeg 20200330_123058.jpg 20190929_131433.jpg IMG_20200704_093659.jpg 78163749_2551289124984857_452884557398540288_n.jpg
  19. iwanaflattie
    iwanaflattie
    Lost my space in the garage so I took the day off and rented an U-Haul trailer.I could only rent it for 6 hrs...picked it up at 7:30am, started loading at 8am,finished at 8:45am..it barely fit,thank goodness it runs/drives.
    Took it to DMV inspector,got the paper at 9:30...drove 100 miles,drove it off the trailer,turned around and started driving back to return the trailer at 2:00 pm.....
    Hope to get tags and plates next month.
    It was 100 degrees when I loaded it,111 when I unloaded it...
    Burned my wrist and arm with the exhaust pipe...
    Worth it.
  20. brEad
    brEad
    I LOVE your truck! So original. Great proportions.
  21. iwanaflattie
    iwanaflattie
    Thank you sir
  22. moparboy440
    moparboy440
    from Finland
    Perfect stance! Very cool truck :)
  23. RamJet1
    RamJet1
    Awesome truck! Glad all of that went smoothly.
    So, did I see that there's a Chevy version in the works after you get settled, based on those pictures?
  24. iwanaflattie
    iwanaflattie
    thank you
    yes a home made GMC coe...
    brEad and tb33anda3rd like this.
  25. hotrod1948
    hotrod1948
    from Milton, WI
    Great truck. Still want it when your done owning it! (I hope). It hits all the ****ons! That GMC coe is going to be awesome as well!
  26. iwanaflattie
    iwanaflattie
    thank you..its been running well so i forgot i wanted to sell it real bad,,,ill keep u in mind,if i do wana sell it,i gotta get some projects running before i go back to the gmc,,it only needs abunch of sheet metal fab,,,,i aint scared,,
    brEad likes this.
  27. iwanaflattie
    iwanaflattie
  28. iwanaflattie
    iwanaflattie
    My rust brings all the hambers to the yard IMG_20200712_093555.jpg IMG_20200712_093549.jpg
    Okie Pete, Cool32, b-bop and 4 others like this.
  29. brEad
    brEad
    I like your taste in projects!
  30. iwanaflattie
    iwanaflattie
    It's not taste..it's what I can afford
    b-bop and brEad like this.
