Customs Model A front spring replacement question
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Jul 6, 2020.
  1. olds vroom
    olds vroom
    I’m running a stock 31 model A front axle 51-7/8 width . It still has the stock front spring and I’ve just noticed it’s flat no room for travel so obviously I need a new one but when I go to speedway everything is for a 46” or 48” axle does it make a difference if the spring mounting holes line up? Also everything is a 1” drop that I don’t think l want . Any advice is helpful .
    Stogy likes this.
  2. Are the shackles touching the axle?
  3. olds vroom
    olds vroom
    Very very close to touching
  4. HOTRODPRIMER
    HOTRODPRIMER
    If you want to replace the spring with a original style Speedway motors is not going to have what you want.
    Snyder's antique auto carries the original type of spring. HRP
    warhorseracing likes this.
  5. olds vroom
    olds vroom
    What should the measurement be from eye to eye of the spring?
  6. according to the Posies catalog
    Stogy, Paul, wheeldog57 and 1 other person like this.
  7. olds vroom
    olds vroom
    [​IMG]im still not convinced the spring is bad . After doing a search through several model A pics most or all sit the same as mine so maybe I’m over thinking this.
  8. woodiewagon46
    woodiewagon46
    from New York
    What shape do the shackles and bushing look like? They aren't stock Model A shackles or shocks. You can tell from the divot on the top of the axle that the spring was hitting at one time. How do you know that the spring is stock? Model A front springs have 10 leaves and clipped at the corners. I think I see a squared end on the first leaf. Perhaps they installed a different spring. I like the way the cotter pins were installed.
    Stogy likes this.
  9. 30panel
    30panel
    Pins lazy or temporary.
  10. clem
    clem
  11. olds vroom
    olds vroom
    There are 9 leads in my spring,and all the corners of the springs are a square cut . I updated the shackles when I built the car but the spring was what it came with . It wasn’t broken so I reused it. As it rides now there is no contact between the spring and axle . I put tape on the axle and drove around to check . Just not much clearance.
    Stogy likes this.
  12. 100% Matt
    100% Matt
  13. woodiewagon46
    woodiewagon46
    from New York
    If the spring doesn't have "clipped" corners, it's not Model A.
    Stogy likes this.
  14. olds vroom
    olds vroom
    [​IMG][​IMG] best pics I can get.
    Stogy likes this.
  15. warhorseracing
    warhorseracing
    from cameron wv
    Not in reference to your springs but as woodiewagon 46 pointed out.
  16. That spring is toast
    Stogy likes this.
  17. rusty valley
    rusty valley
    agree^^ 3rd leaf worn bad! square cut ends are usually 32-34, but the spring eyes on the main leaf are bigger, 13/16 vs 3/4 if i remember correct
    Stogy likes this.
  18. olds vroom
    olds vroom
    I picked up a new old stock replacement spring from a fellow H.A.M.B. member on Monday . Thanks again Jim.
    Stogy likes this.
