Technical ***July 2020 Banger Meet Thread - Four Is A Good Number***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jul 1, 2020.
  1. winduptoy and Savage Coupe like this.
  2. winduptoy
    winduptoy
  3. V4F
    V4F
    from middle ca.
    how much out of top ?
  4. Binger
    Binger
    from wyoming
    winduptoy likes this.
  5. burl
    burl
    from Minnesota
  6. Jim's head is taller so you need longer studs. I bought a set from him with ARP nuts - guessing they're the same.
  7. burl
    burl
    from Minnesota
    My special machined head is even taller yet.His studs looked like they had provisions for an allen wrench in the center.
  8. MJW
    MJW
    from NJ
    Its being built now by my buddy Harry at Harry's Hot Rods in Dover NJ. I have a really nice F100 column, box and column shift thats going to be mated to a side shift 39 trans that I will probably put together.
    Front end is dropped 33 axle with unsplit A bones. Rear is a 40 rear with the ends of the bells cut off and A bell ends welded on to use a T rear spring.
    I will be doing the juice brake system.
    Its just a pile of parts now but end of September is the goal for a rolling ch***is but that date will most likely slip as I am going to Bonneville.
    Bigcheese327 likes this.
  9. Burl
    Those are ARP studs with hex in center
    IMHO the best money can buy without NASA funding
    J
    winduptoy, Jet96 and Old Dawg like this.
  10. Gary in MN
    Gary in MN
    ARP studs are great , even on the odd ball stuff they will help you get the right ones. I have used them on a couple OHV heads. DSC01290.JPG Gary
    winduptoy, Old Dawg and Jet96 like this.
  11. railcarmover
    railcarmover
    Itty bitty slugs the size of a peach..heavy engine too...the block casting is dicey, cracks like a B block on steroids..got to blow them up like a balloon just to see if they will hold air..
    winduptoy and Old Dawg like this.
  12. burl
    burl
    from Minnesota
    Will need to check them out.One of the final pieces i need before i can beta test our new head design
  13. Burl
    If I can offer a suggestion
    Contact Reds headers to source the ARP studs and nuts
    John
  14. burl
    burl
    from Minnesota
    Yes,
    I understand Victor has stock and best pricing.
    Thanks
  15. Banger’s got 5.5 Snyder’s head and a single 94.
    Stock Ford specs Champion plugs gapped .032”.
    That okay, or should be tweaked?
    Burning non-alcohol.
  16. winduptoy
    winduptoy
  17. Crazydaddyo
    Crazydaddyo
    kb9jlo and Jet96 like this.
  18. Grasias.
    Only my second dum question this month!
  19. railcarmover
    railcarmover
  20. dmdeaton
    dmdeaton
    Can u pull a set of points from a Mallory and run as a single? I need to read up on 2 point distributors. I thought the main reason was for higher rpm. In a banger what’s the purpose?
  21. dmdeaton
    dmdeaton
    I ended up ordering a couple of these and it runs great. Quiet, doesn’t sound like a jackhammer or a bed ******** in a motel.
  22. noboD
    noboD
    MOST dual point distributors fire a few degrees apart to give a longer spark at the plug. You can run with one set of points.
  23. On this thread there are NO dumb questions! Sometimes strange conversations, though! Welcome to the group!
    railcarmover, winduptoy and Jet96 like this.
  24. @OldDawg, thank you sir. We’re all at different levels here, but you’re starting to rub off on me!
    I appreciate all the advice I get. H.A.M.B.’s keeping me rolling.
    Sorry the plague’s curtailed your racing season. Stay well!
    Old Dawg likes this.
  25. railcarmover
    railcarmover
    Got one on the '67 beetle,going on 11 years now.
    Old Dawg and dmdeaton like this.
  26. railcarmover
    railcarmover
    Longer coil soak (the time the coil is 'charging') too..4 cylinder soak time is fine with single point set up..life is easier with single point set up too
    dmdeaton likes this.
  27. railcarmover
    railcarmover
    She's getting her cherry popped today..taking her to the FAST club meeting,bunch of ***hole tire kickers :)
    Old Dawg, dmdeaton and Shutter Speed like this.
  28. Dustyp489
    Dustyp489
  29. Dustyp489
    Dustyp489
    I thought FAST was no more.
