Technical see who has a sharp eye
Discussion in 'The Hokey Ass Message Board' started by Darin Younce, Jul 15, 2020.
  1. Darin Younce
    Darin Younce
  2. Peter Nowak
    Peter Nowak
    Ahh.
    There are no muffler bearings or a shore line visible in that pic, as is required is any riddle.
  3. Darin Younce
    Darin Younce
    OK folks , got a winner and one really close. Yes the synchro has moved too far forward , the balls should not be visible. I fixed it by putting a hose clamp around the hub and sliding the sleeve back over the balls. Everything in trans went together nice and correct , the problem is in the shift tower, lots of wear in various place, noticed when shifting in third the shifter could be moved a smidgen more that needed allowing forks to push the sleeve a tad too far, by then they can move on like you see in pic which will result in being stuck in third.
  4. Darin Younce
    Darin Younce
    Nope
  5. 56don
    56don
    Man I hate it when that happens.....so embarr***ing.
    blowby, lothiandon1940 and VANDENPLAS like this.
  6. Darin Younce
    Darin Younce
    Nope , it is correct
  7. Darin Younce
    Darin Younce
    Ha, you be right.
  8. Darin Younce
    Darin Younce
    It is close enough for what needs to be seen, btw 600 wt is what was recommended and is what they ran when new , it is thick as hell . However , you might be right , we will see.
  9. Lloyd's paint & glass
    Nope, I'm still going with your shifter and top plate exploded!!! ;)
  10. Darin Younce
    Darin Younce
    I confess, it was all that 221 ci 85horsepower that did it in.
    Lloyd's paint & glass likes this.
