Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. Lloyd's paint & glass
    I use windshield urethane Phil. Run about a 5/16 bead in the sash channel. Sometimes I put the channel on the glass when it's out of the door, sometimes I put the glass in the run channel and slide it to the top, run a piece of tape over the top to hold the glass up, then roll the sash up onto the glass and let it set overnight. But a tube of urethane will easily do all of the doors and it's affordable.
    chryslerfan55, bobss396 and loudbang like this.
  2. PhilA
    PhilA
    I was thinking about that but the proper rubber U-section is available for it, so I'm going to do that. Before then though I need to find the front glass channel; without that the glass cannot go up and down and stay in line and not break again.
    Phil
  3. Lloyd's paint & glass
    Here's what I use man. Guy here in northern Ky has it. Great price. Screenshot_20200713-215019_Samsung Internet.jpg
    chryslerfan55, loudbang and PhilA like this.
  4. Lloyd's paint & glass
    Great for hot rods and customs, probably not suitable if you're trying to do a factory restoration.
  5. PhilA
    PhilA
    Question being, will it accept 1/4" glass?
    Edit: Now that the eBay mobile site stopped fighting with my phone, I can see it does.
    Do you normally just fix it in with window urethane?
    I just went out and measured up.
    Glass thickness: 1/4"
    Channel width: 1/2"
    Channel depth: 5/16"
    Gonna hunt about for something suitable.
    Phil
  6. Lloyd's paint & glass
    I've used urethane, and I've used 1/8" rivets.
  7. PhilA
    PhilA
    Found the stuff
    On my shopping list. I think it's correct, shall double check but it looks right.
    Phil
  8. Lloyd's paint & glass
    I've got a few of those pieces out in the shop. Not sure if they're long enough to be useful. I usually buy them in the long sticks in Louisville, either at the kyana swap meet or the NSRA nationals vendor section. Not this year :rolleyes:
  9. PhilA
    PhilA
    Probably not, I need the full runner section from top to bottom. I'll grab this and try fit it. I need to figure out what's wrong with the rear channel too. It's buckled in the middle.
  10. vtwhead
    vtwhead
    Phil, a little heat on that window putty should soften it up so it will come out easier.
    Woogeroo, loudbang and PhilA like this.
  11. PhilA
    PhilA
    A little too much smells really bad, too!
    Phil
  12. PhilA
    PhilA
    Fire and wire wheels later, it's now painted. Straightened it out too, where one edge had become bent down because the window channel is gone.
    Any progress is good progress.
    Phil
  13. PhilA
    PhilA
    Nothing really happened today because it was too hot.
    So, have a Chief as consolation. There's a nice insert that's not all crazed on that there bidding site right now, $219.
    I am quite happy to pull him out, store him safely with the rest of the bits from the car and put a reproduction one in for less than half that price.
    Would be nice to have him not look like Clint in G, B & U.
    Phil
  14. PhilA
    PhilA
    I built this little doohickey to put on the back of the temperature gauge. Forgot I had the parts to make it on the shelf.
    This will keep the voltage stable (or rather what it does is gives a ceiling maximum the voltage is allowed to go up to, adjustable) so the temperature gauge won't over-read when the engine is running.
    (Would also work to run 6V gauges on a 12V converted vehicle, it's a versatile doohickey).
    Phil
    Woogeroo, bchctybob, brEad and 4 others like this.
  15. PhilA
    PhilA
    Installed board.
    Ran up to temperature.
    Adjusted gauge.
    That's better.
    Phil
  16. loudbang
    GENIUS, great build stuff yourself. :)
  17. flynbrian48
    flynbrian48
    I admire your attention to all the fiddley little things that go into restoring an old car. I sometimes don't have patience for that stuff. Carry on.
    bchctybob, loudbang and PhilA like this.
  18. PhilA
    PhilA
    Patience like taking the gauges apart, adjusting the alignment of the clockwork, testing and reassembly?
    Found why the temperature gauge was getting stuck. Undone it worked fine, tightened into the bucket twisted it slightly, so I tweaked the alignment of the armature and now it moves freely.
    Phil
    Woogeroo, brEad, loudbang and 2 others like this.
  19. PhilA
    PhilA
    There we go. Doesn't get stuck in the middle now.
    Phil
    Woogeroo, bchctybob, brEad and 3 others like this.
  20. PhilA
    PhilA
    Reassembled it all.
    Idle idle idle
    Normal running temperature.
    Bang on the money. Now I'm hot, the car makes the garage like a furnace and stinky even with the big fan running. But, it's all back together and it works. Hopefully that's the last time for a while I have to do that.
    Phil
    Woogeroo, bchctybob, Lepus and 9 others like this.
  21. 72Mountaineer
    72Mountaineer
    from WV
  22. PhilA
    PhilA
    They're naturally on the high side. For that money you can get yourself a sweet Sunday driver that's neat and presentable, drives nicely and needs no work.
    They need to knock about 3k off that because it's tatty and everything outside needs redoing- don't buy it to sell it on. Drop $5000 in paint, another $2000 in chrome and if it runs it's worth what they ask... even as a 2-door. Bodyplan doesn't make much difference to the price. Looks like it's an automatic (picture is a bit fuzzy) so that they've put it manual suggests they haven't driven it...
    If you can knock them down a bit it is a basis for a sweet custom though.
  23. 37hotrod
    37hotrod
    Not to mention, there are at least 5 other cars in that building. This is probably the worst of the bunch, or they would be keeping it.
  24. PhilA
    PhilA
    Yeah. Mine as a 4-door, running, driving, steering, stopping with a 6/10 interior and 7/10 exterior set me back $5300, bear that in mind.
  25. 72Mountaineer
    72Mountaineer
    from WV
    I talked to the seller, he bought it to restore for his Pap, but Pap perished in the meantime. It is supposedly a California car, bought in Sonoma and shipped back east. Engine is not working, supposedly hole in a piston, so******* is untested. Price seemed high to me, engine/tranny would probably end up 350/350 for simplicity, which could easily add 3K. Owner does this, buys/sells "vintage" iron, prices on most are higher end.
  26. PhilA
    PhilA
    Doesn't run, untested.. it steers and possibly stops. Holed piston on one of these 8's is highly unlikely, destructive death on these is usually over-speed conrod failure with parts making a bid for freedom through the oil pan or block wall.
    If it isn't holed and turns over but has*****py compression on several pots, it may just be stuck valves. Even with 4 pots with zero compression these engines will still fire up. Sounds like he didn't try.
    That is an $8k car at best, and that is if the rockers, door bottoms, trunk floor and up around the A pillars is still solid.
    I bet you he disagrees.
  27. PhilA
    PhilA
    Everything on hold for a little while.
  28. PhilA
    PhilA
    No sooner do I say pause, and a few things fall into place. So, a few things occurred.
    I finagled the screen defrost to lower heater pipe back into place.
    I made a lower heater return pipe.
    Fire was used in a constructive manner.
    A dual pipe clamp is in the making.
    More to come.
    Phil
  29. PhilA
    PhilA
    Completed that bracket and used it to clamp the pipes to the chassis where they go through it, prevents them from rattling.
  30. PhilA
    PhilA
    More fire, more metal.
    Created another bracket. Fairly simple affair but the long metal pipe had no support other than being attached at either end to the radiator and the heater lower pipe.
    This gives it a little more support about 2/3 the way along its length. Bolted in through one of the old battery tray bolt holes.
    Filled the cooling system back up and started the engine. Everything got nice and warm, the defrost and under seat heater; the valve functions as expected.
    One more thing off the list.
    Phil
