Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    is this considered ambiance or character?:)
    brEad, dwollam, cactus1 and 7 others like this.
  2. Slopok
    Slopok
    Henry would be awfully proud of you!
  3. Stogy
    Stogy
    Ambience with Respect to Hard Earned Soul...
    Turn Key, Drive and let the Stones bounce off the inner fenders without a worry in the world...
    TFoch, loudbang and tb33anda3rd like this.
  4. Runnin shine
    Runnin shine
    Stogy, nunattax and tb33anda3rd like this.
  5. tb33anda3rd
    tb33anda3rd
    Charlie and I worked on it together, masks and social distancing in effect. we pop riveted the pan under the seat in. and screwed the seat riser back in. IMG_0484.JPG IMG_0486.JPG
  6. tb33anda3rd
    tb33anda3rd
    we then bolted the side boards and glued the two ribs in. we used br*** screws and br*** machine bolts that I had. IMG_0487.JPG IMG_0488.JPG IMG_0489.JPG
  7. tb33anda3rd
    tb33anda3rd
    we then glued and screwed the ribs in. I started from the middle and worked my way out in pairs. each board was moistened with a damp rag, glued, clamped, predrilled then screwed down using a br*** screw. IMG_0490.JPG
  8. tb33anda3rd
    tb33anda3rd
  9. tb33anda3rd
    tb33anda3rd
    once they were all in I used the belt sander to sand the boards down even and match them to the sheet metal. I then sanded them smooth with the DA. i cleaned up the glue and sanded a few edges. the slacker vacuumed up the dust. IMG_0492.JPG IMG_0493.JPG IMG_0495.JPG
  10. tb33anda3rd
    tb33anda3rd
    arched red oak glued and screwed together is really strong. how strong? 190 pounds...... IMG_0499.JPG
  11. tb33anda3rd
    tb33anda3rd
  12. TFoch
    TFoch
    We appreciate you taking the time to do***ent this. It's been interesting watching the truck come back to life!
  13. This is awesome!
  14. ct1932ford
    ct1932ford
  15. Mat Thrasher
    Mat Thrasher
    I absolutely love this build. You are true craftsman working with steel and wood.
    Keep up the great work.
  16. loudbang
    Now the NEXT guy to find this somewhere in the distant future and it trying to replace the top wood is going to go crazy trying to match your work. :rolleyes:
  17. flynbrian48
    flynbrian48
    Every time I come to the HAMB I find a thread that amazes me. First, because I hadn't seen it before, and second, because the work being done is so outstanding. Your use of the tree that fell on the truck to rebuild it is great, on so many levels. Thanks!
  18. tb33anda3rd
    tb33anda3rd
    thanks for the comments acknowledgement it really helps to keep the motivation up. I really appreciate it.
    @ct1932ford those are Coullots my work skirt is in the wash.
  19. olds vroom
    olds vroom
    Not to mention the two characters doing the work. Lol
  20. tb33anda3rd
    tb33anda3rd
    I put a second coat on the wood this morning . The Slacker showed up with some stuff after lunch. a new set of door checks and material for the top and door panels.
    the door checks were originally held with a rivet, but the new kit came with cotter pins, Charlie said he will change them in the future. we had to heat the D-nuts that held the rubber bumper to the back of the post and grind off the bottom of the rivet. once the threads were chased Charlie put them together. IMG_0511.JPG IMG_0512.JPG IMG_0513.JPG IMG_0514.JPG IMG_0515.JPG
  21. tb33anda3rd
    tb33anda3rd
    top material. we will put the vinyl over the wood first with the good side down. Charlie thought a lighter color will keep the interior brighter. IMG_0516.JPG
    kidcampbell71, brEad, Stogy and 2 others like this.
  22. tb33anda3rd
    tb33anda3rd
    we had to heat, WD and use the impact driver to get the top of the doors apart but we were able to save all 6 screws. I took what was left of the door channels out. they were held in with a hook at the top and bottom that were riveted to the channel. the channel had just enough stretch to get them hooked. there is only one bottom hook remaining. the slacker sand blasted the door tops and I will prime them with epoxy primer. IMG_0517.JPG IMG_0518.JPG IMG_0519.JPG IMG_0520.JPG
  23. tb33anda3rd
    tb33anda3rd
    Charlie dropped off his steering wheel for me to prime. he fixed a bunch of cracks with JB weld.
    on my way home from work I stopped at a gl*** shop that went out of business. a friend of mine was cleaning it up for the owners and gave me a few pieces of new gl*** for this project. there also was a windshield already cut for some early car that was never picked up. IMG_0526.JPG IMG_0527.JPG
  24. tb33anda3rd
    tb33anda3rd
    now that the third coat was dry I put the wood behind the seat in. IMG_0528.JPG ...the Rolls is watching over this project.;)
    :cool:
    kidcampbell71, 32SEDAN, brEad and 7 others like this.
  25. tb33anda3rd
    tb33anda3rd
    stretched out the vinyl and cut a piece bigger than the "opening". I started in the middle of the back, then the middle of the front, pulling it tight as I went. I did a few inches then did the same with the sides. I started in the middle and pulled it tight. I worked my way around top, pulling it tight till my fingers ached. I used a combo of staples and tack nails. I used the tacks across the back that were long enough to go through the slats and into the header. IMG_0530.JPG IMG_0531.JPG
    loudbang, Runnin shine, Stogy and 3 others like this.
  26. tb33anda3rd
    tb33anda3rd
    once that was done I trimmed the material and using contact cement I glued the edges down. IMG_0532.JPG
    loudbang, Runnin shine, Stogy and 4 others like this.
  27. tb33anda3rd
    tb33anda3rd
  28. tb33anda3rd
    tb33anda3rd
    and we still have enough material left over for the doors and kick panels:)
    Just Gary, cactus1, loudbang and 8 others like this.
  29. nunattax
    nunattax
    not too late for some discrete insulation under the seat behind it and in the doors.outof sight, out of mind.
  30. tb33anda3rd
    tb33anda3rd
    Chris, I am sure Charlie will do something before he puts it all together. I am pushing to get the top on so we can get the cab to his house and up on the frame.
    Stogy, TFoch, loudbang and 1 other person like this.
