  1. Dean Lowe
    Dean Lowe
    I was there. Trust me, the Greeks engine was straight up.
  2. Mike VV
    Mike VV
    from SoCal
    "Engine dump", that's funny..!
    Doesn't take much thought into realizing that the angle of the engine depends solely on the height...of the engine.
    The rear end, driveshaft, and engine mounting height have the sole say in how much angle there is/will be.
    If the engine is mounted high enough that the drive shaft is parallel to the ground, the engine will be pretty high, with the crankshaft, parallel to the ground.
    If the designer wants the engine lower, the engine will have a measurable downward drop in the front. It's all just a straight line from the pinion gear to the front of the crankshaft.
    Not many...IF any Fuel Dragsters had "U-joints".
    Mike
    Just Gary likes this.
  3. Marty Strode
    Marty Strode
    Tom Prufer referred to a steep engine angle as the "Tampa Dump", as I recall.
  4. chevy57dude
    chevy57dude
    Was Big Daddy from Tampa?
    Bowtie Coupe, Just Gary and loudbang like this.
  5. Just Gary
    Just Gary
    Yes. His shop was on Nebraska Ave. :D
    BTW, I'd heard it called "Tampa Dump" as well. Apparently, they'd connect the engine, clutch, and rear axle with wheels & tires, then lower the oilpan/ crank hub onto a wood 2x4 on the floor, then attach that****embly to the frame.
    I bet @Pete Eastwood could teach us the facts on the subject- he restored Ed Pink's "Old Master" dragster, that had a pretty noticeable dump. Pics are in TRJ.
  6. Jimbo17
    Jimbo17
    Big Daddy had an earlier shop I believe in Sefner, Florida which is very close to Tampa.
    They used to test their cars in those days at Twin Cities Drag Strip in Oldsmar, Florida out near Race Track road.
    Jimbo
  7. Fordors
    Fordors
    Nothing odd or funny about referring to “dump”, and it has another counterpart when it comes to dragster or funny car racing, how far “out” is the engine? Not everyone followed the same formula for chassis building and there were different ideas tried all the time.
  8. Super Cool...Never seen before by me...thanks for sharing, made my day!
  9. cruiserjohn76
    cruiserjohn76
  10. cruiserjohn76
    cruiserjohn76
    Norwood, Mass 1/8 mile 1968 New England Dragway South
  12. Jim Nicholl Der Wienerschnitzel...photo by Chan Bush.
  13. cruiserjohn76
    cruiserjohn76
  14. cruiserjohn76
    cruiserjohn76
  15. cruiserjohn76
    cruiserjohn76
  16. rooman
    rooman
    First photo is Dennis “Mr Six” Priddle at Ellington airstrip in the car that he used to make the first six second run outside of North America.
    The second is the “Texas Weasel” of Prentiss Cunningham that was one of Raymond Beadle’s early rides.
  17. Al Segrini winning the Winternationals...my shot.
  18. noboD
    noboD
    That '61 Chevy looks like it says 331 CI on the hood. Good Grief!!
    Bowtie Coupe and loudbang like this.
  19. saltflats
    saltflats
    from Missouri
  20. rooman
    rooman
    A little too new for this thread John- pix should be pre 1965 ( although there is a little leeway for period shots of front motor diggers)
  21. rooman
    rooman
    Gary Southern in the Akins and Hardcastle Kellison Astra- blown early hemi on fuel with direct drive
    Bowtie Coupe and chryslerfan55 like this.
  22. noboD
    noboD
    You are correct.
  23. chevy57dude, loudbang and Offset like this.
  24. Dean Lowe
    Dean Lowe
  25. Gotcha...I remember now, that's why Ingenue got kicked out...although previously she was loved before the rule change.
  26. old flopper
    old flopper
    Looks like a fire burnout that might not have ended well, since it appears buildup in wheel well is now burning. :eek:
  27. Kentuckian
    Kentuckian
  28. 1934coupe
    1934coupe
    No wonder the left front tire still has the sticker on it, it's never used! Seriously though a lot of those X frame cars launch line that and it seems normal. Ask BSL409 on here.
    Pat
