Technical Never too old to learn something!
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 17, 2020.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I have been fighting with a carburetor problem with my old sedan, nothing major but it started hesitating and I just lived with it for a while but a few weeks ago the time was right and I bought a rebuild kit and installed it.
    I fired the car up and drove around the block and although there was a improvement it still had a miss or what ever you call it, I have never professed to be a carburetor man but I felt sure I did everything correctly.
    This morning I drove the car over over to my pal Earl's garage and took him for a ride and his initial thought was the accelerator pump, that's when I told him I installed a new one with the kit.
    It was hotter than a 4 balled tom cat out in the sun and he instructed me to pull in the open bay, it didn't take him more than a five minutes to diagnose and correct the problem.
    The one thing I din't replace was a 50 cent piece of vacuum hose, I didn't inspect it when I reinstalled it but there was a split in the hose, we live and learn. HRP
    phelan9251, Tim, j-jock and 20 others like this.
  2. indyjps
    indyjps
    Well, you know the carb is fresh now.
    Deuces, ladyhrp, 3W JOHN and 2 others like this.
  3. Slopok
    Slopok
    That sucks!;)
    Deuces, ladyhrp, 3W JOHN and 3 others like this.
  4. AVater
    AVater
    ^^not anymore!
    woodsnwater, Deuces, ladyhrp and 3 others like this.
  5. goldmountain
    goldmountain
    j-jock, Deuces, ladyhrp and 3 others like this.
  6. It was probably an inch long.
  7. 67drake
    67drake
    from Muscoda WI
    I like when it’s a cheap and easy fix!
  8. Jalopy Joker
    Jalopy Joker
    yep, have discovered that problem more than once - hose can look perfectly fine to the casual eyeball - but, just a more hands on look will give you that revelation that not everything is made to last forever -
  9. OLDSMAN
    OLDSMAN
    No matter what the fix was, it’s always nice to have your stuff running. Something as small as a crack in a vacuum line can be hard to find sometimes.
  10. WB69
    WB69
    from Kansas
    Very common cause of a lot of carb problems. Sometimes the littlest problems go unnoticed.
    Deuces, ladyhrp and HOTRODPRIMER like this.
  11. coupe man
    coupe man
    Bought a nova that the owner couldn't get it running right.Poked around it a little and noticed that the metal vacuum line was just floping around.Took off the aircleaner and the hose from the intake to the vacuum line was broke off.Replaced it and it ran great.
    Hank37, Deuces, ladyhrp and 3 others like this.
  12. bobss396
    bobss396
    I always change the hoses when I do my gas filter. I just bought 3' of made in the US gas hose, it came to under $3.
  13. HOTRODPRIMER
    HOTRODPRIMER
    Metaphor my friend. HRP
  14. bchctybob
    bchctybob
    I’ll be checking my hoses carefully this morning, I just changed the carb and manifold on my little beast and today is startup day.
  15. HOTRODPRIMER
    HOTRODPRIMER
    It wouldn't hurt. HRP
  16. 3W JOHN
    3W JOHN
    Danny, I think a lot of carburetor problems can be traced back to vacuum hoses.
  17. HOTRODPRIMER
    HOTRODPRIMER
    John, In my case yeah! HRP
    Deuces, ladyhrp and 3W JOHN like this.
  18. bobss396
    bobss396
    Places like NAPA have it right out on the floor, real convenient and you cut off what you need. Pay by the foot, never hurts to have extra around.
  19. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir, the hoses are something easily overlooked and so simple to change and a bad fuel line can cost you your hot rod or custom.
    I remember it happening to Randy (Deuce Roadster) HRP
    Deuces and ladyhrp like this.
  20. 3W JOHN
    3W JOHN
    It makes me sick when I see what happened to randys roadster.
  21. HOTRODPRIMER
    HOTRODPRIMER
    You and me both brother. HRP
    Deuces likes this.
  22. Deuces
    Deuces
    HOTRODPRIMER likes this.
  23. hotrodjack33
    hotrodjack33
    While you're checking the hoses, check the vacuum advance as well, give the hose a good suck and make sure the advance plate actually moves. On a couple occasions, I rebuilt the carb on an ill running engine to no avail...only to finally figure out it was the vacuum advance all along.
  24. You can find a lot with a windex bottle and a little soap and water, squirt it around while the engine is running and see where the bubbles are.
  25. That is awful!
    I have had an engine fire, and can empathise with him. In my case, it was a stuck float in a Holley, and it was a good thing I had a fire extinguisher.
    These things always happened to me late at night, on a lonely highway, where I knew I was on my own. There was no damage, in my case, and all I had to do was cut and shorten some rubber hoses that fried. I don't know why it happened, that was 26 years ago, and I still have the same carb on the truck and it never happened again.
  26. If you are referring to the diaphragm in the actuator can, I have also had that experience.
    Bob
    hotrodjack33 and HOTRODPRIMER like this.
  27. HRP, don't you find that when something goes wrong, that is an obvious, simple, and easy fix, that there is always a witness that is going to remember, and blurt it out at a time that is most embarrassing for you?
    Another one that has happened too many times to me, because in my profession, I went to a lot of strange places, was that when I was lost and finally asked for assistance, I could count on the fact that the place I was searching for was down two buildings and across the street. The worst time for this to happen, is when my wife is in the car.
    Bob
  28. Mike VV
    Mike VV
    from SoCal
    LONG story with my Grandmother's car, many years ago that I won't bore you all with...but even the dealers F##K that one up.
    Luckily...I found it.
    Mike
  29. HOTRODPRIMER
    HOTRODPRIMER
    Randy's engine fire started at a stop light in bumper to bumper traffic, he had one of those small halon fire extinguisher in the car but it wasn't enough to do the job, a gentleman came to his aide with a big ABC fire extinguisher from a nearby business it made a huge mess but saved the car from being totally destroyed. HRP
    j-jock likes this.
  30. hotrodjack33
    hotrodjack33
    I've had 2 different vac. advance issues. First was a 289 points distributor in my 39 Ford Pickup. The advance plate for some reason, just froze up (while I was driving it) and wouldn't move anymore. The other time I was coming back from the Syracuse Nats in my old '32 and it started running a little rough (302 Ford). When I got off the highway, it was running like shit. It ended up being a small rust spot and a pinhole on the underside of the vacuum canister...where you couldn't see it. That one took a while to figure out:(
    j-jock likes this.
