1952-59 Ford replacing tail light sockets on a 55/56 fairlane
Discussion in 'Off Topic Hot Rods & Customs' started by 55newbie, Jul 15, 2020.
  1. 55newbie
    55newbie
    from Ohio
    I need to replace the bulb sockets on my Fairlane, some corrosion but mainly the wires are really brittle. I see them listed on Ebay, but I can't get mine out of the tail light housing. Any suggestions are appreciated.
  2. Dos Cincos
    Dos Cincos
    They just pop in there (no twisting). Should just pull straight out
  3. Paul2748
    Paul2748
    Try pushing them out backwards if possible. Should just pull straight out, but often they do not because of corrosion
  4. bobss396
    bobss396
    On my '59, I drilled the light buckets out for GM style sockets. These clip in securely and provide good grounds. The OG Ford ones were small in diameter.
    Rockabillykat666 likes this.
  5. 55newbie
    55newbie
    from Ohio
    I tried pulling them, no go. They will spin freely in the housing so I know they are not rusted in. May just have to cut them off and drill them out
    JeffB2 likes this.
  6. bobss396
    bobss396
    Mine fell apart when I took them out, badly corroded. I opted for the GM newer style since I doubted I could put the OG style back into mine.
