Projects 1934 Ford Pickup Build U.S. Mail
Discussion in 'Traditional Hot Rods' started by Ratspit, Jul 11, 2020.
  1. Jeff34
    Jeff34
    That wasn’t rat rod, that was survivor. My &0.02
    nunattax likes this.
  2. Ratspit
    Ratspit
    Straightening out the roof was the first order of business on the cab. Sorry I didn't take any before pictures but it had all the typical dents. cab roof finish 2.jpg cab finished roof 1.jpg imagejpeg_0(72).jpg
  3. Ratspit
    Ratspit
    Then it was on to repairing the doors. The drivers door was by far the worst. The outer skin on it needed a lot of straightening. Hinges were bent. The p***enger door was much straighter but still had some thin spots that required patching. imagejpeg_0(82).jpg imagejpeg_0(78).jpg imagejpeg_0(77).jpg imagejpeg_0(76).jpg imagejpeg_0(75).jpg imagejpeg_0(74).jpg imagejpeg_0(71).jpg imagejpeg_0(70).jpg door inner cutout 2.jpg
  4. Aaron D.
    Aaron D.
    Wow, I can tell already this is going to be a super nice truck when you're done.
  5. Ratspit
    Ratspit
    Cab corners and back panel were good. Just needed to fix a little bit on the front lower panels on the cab. cab sheetmetal done.jpg
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. Your mock-up is just KICK***!
  8. Ratspit
    Ratspit
    With the cab metalwork complete (at least for now), it was time to get the perimeter frame up on the table and start work on the ch***is. I decided to set the truck up with 2 degrees of rake and 5 inches of ground clearance.
    nunattax, tb33anda3rd, brEad and 6 others like this.
  9. sloppy jalopies
    sloppy jalopies
    mikie likes it !
    great Sheetmetal work, love the sectioned frame rails to give the truck the channeled look keeping a full floor.
    .. GO spit GO !
  10. Ratspit
    Ratspit
    The rear axle was the first order of business. Locating it was just a matter of pulling a few measurements from the front horns.
    my truck chassis 1.jpg my truck chassis 3.jpg my truck chassis rear view.jpg
  11. Ratspit
    Ratspit
    Thanks Sloppy J. I can't take any of the credit for the awesome metalwork. I have the guys at QRSR helping me.
  12. Ratspit
    Ratspit
    With the Winters QC in place we welded in the motor mounts and set the flathead and T5 in place. my truck chassis 7.jpg my truck chassis with motor.jpg my truck chassis with motor 2.jpg
  13. Ratspit
    Ratspit
    With the engine and rear end located it was time to tie everything together.
  14. AHotRod
    AHotRod
    I love the style and stance your going for, well done.
  15. Looking good Pete....
    Wonder who will get theres done first, You or me :)
  16. Ratspit
    Ratspit
    Thanks Bruce. You've got a pretty good head start on me.
  17. Ratspit
    Ratspit
    Normally the front end would be next but because I want to run a suicide front end we decided to get the cab into position first, see what everything looked like, and then position the grill and axle. Channeling the cab was the first step and we decided to remove the firewall, section it, and mount it to the frame. It turned out that 2" could be removed from the area above the original forward cab mounts. The other 4 inches had to be sectioned out of the middle of the firewall.
    imagejpeg_0(67).jpg imagejpeg_0(68).jpg firewall foot pre cut.jpg firewall section detail 1.jpg firewall section.jpg
    brEad, Fitnessguy, rc57 and 6 others like this.
  18. Ratspit
    Ratspit
    With the firewall roughly in place the floor was cut out of the cab following the shape of the frame rails and mounted to the ch***is.
  19. sloppy jalopies
    sloppy jalopies
    If a guy is going to channel the body, model A bumper bracket to body "spacers" work great when separated as front body to frame mounts... vvvvvvxxxx.jpg
  20. Ratspit
    Ratspit
    Sloppy, Great tip. Thank you.
  21. Roothawg
    Roothawg
    Great attention to detail. Others should take note.
  22. Ratspit
    Ratspit
    Channeling the cab created its share of details to be addressed. Starting with rear panel. The panel was first notched to get the cab on the ch***is, then the lower bead detail had to be moved up 2" to meet the original floor pan. imagejpeg_0(22).jpg cab channel detail rear corner.jpg cab rear panel template 2.jpg 20200603_114930_resized.jpg
    Tat2Neil, brEad, Fitnessguy and 9 others like this.
  23. Ratspit
    Ratspit
    More cab channel details. This time tying the floor and cab back together.
    cab channel detail .jpg cab channel detail floor 2.jpg cab channel sills 1.jpg cab channel sills 2.jpg cab channel sills 3.jpg
    Tat2Neil, brEad, Shadow Creek and 7 others like this.
  24. Lil'Alb
    Lil'Alb
    from brier, wa
    I believe I saw that cab on CL a couple years ago and drooled on the keyboard over it. Glad it went to a good home and is getting an awesome rebirth as a hot rod!
  25. Ratspit
    Ratspit
    Moving to the front again it was time to tackle the firewall transition.
    cab channel lower firewall transition 1.jpg firewall transition paper model 1.jpg 20200629_121053_resized.jpg 20200629_121157_resized.jpg cab channel firewall finish detail.jpg
    Toms Dogs, Tat2Neil, brEad and 11 others like this.
  26. 51box
    51box
    from MA
    Nice work that firewall came out great, keep the detailed pics coming
  27. nunattax
    nunattax
  28. n847
    n847
  29. Ratspit
    Ratspit
    Up to the front of the truck, we decided it was time to channel the grill 3" and section it another 3". The original grill was in very nice shape. It needed a little work on the bottom lip but otherwise had faired quite well over the years.
    original grill.jpg imagejpeg_0(61).jpg imagejpeg_0(62).jpg grill on table shortened 2.jpg grill on table shortened.jpg grill bottom done.jpg grill on truck 3:4.jpg grill sectioned full frontal.jpg
    Toms Dogs, tb33anda3rd, brEad and 8 others like this.
  30. Fortunateson
    Fortunateson
    Very nice work indeed! But considering what you are doing to the truck I suggest that the relevance of a US mail truck is long gone and the thread's ***le be amended...
