Hot Rods The No Frame Model A Modified
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Sep 22, 2017.
  1. Nostrebor
    Nostrebor
    You do not disappoint.
    One of my guilty pleasures is taking a mixture of OEM parts and utilizing them in a way never intended. This brings that to a level that I am not qualified to do, but really enjoy watching anyway. Thanks for sharing this work with us!
    dlw1932, Stogy, Thor1 and 1 other person like this.
  2. 1-SHOT
    1-SHOT
    from Denton
    I am surprised you used a key way on your stub axles and not splined
    Stogy and Thor1 like this.
  3. rottenleonard
    rottenleonard
    If this fails that will probably be the next try:D
    Stogy, brEad, Nostrebor and 1 other person like this.
  4. Pretty cool so far. Been playing catch up online and glad I finally saw this.
    Thor1 likes this.
  5. rottenleonard
    rottenleonard
    Seemed to much like summer to cut the car up, so i back burnered the rear end in favor of some other upgrades. When the engine warmed up it was not idle down and seemed to have a vacuum leak, I suspected that the manifold wasn't real flat and the aluminum gasket was leaking.
    So I pulled manifolds and machined them flat ending with a little fine-tuning on some sandpaper
    The other major problem was the homemade throttle cables, they just didn't work smooth enough to shift the non sincro trans effectively.
    I had a box of 1/4 rod ends, picked up some stainless round stock and went at a new design. I like the mechanical look it took on. 20200616_155843.jpg
    The choke will be ran off the column lever, I can't remember if it controlled the timing or throttle on the Model A originally.
    20200721_104512.jpg 20200721_161402.jpg 20200721_161402.jpg 20200721_154036.jpg 20200721_154050.jpg
  6. 1-SHOT
    1-SHOT
    from Denton
    Spark on the left Throttle on the right is the way they were originally built A & T were the same.
    I like the throttle and choke controls there look period perfect. Frank
    Stogy, Thor1 and Runnin shine like this.
  7. drtrcrV-8
    drtrcrV-8
    VERY NICE WORK!!! Thanks for the update!
  8. Stogy and Thor1 like this.
  9. rottenleonard
    rottenleonard
    I should probably know that.....but i don't 15954330847765590894757635522473.jpg
  10. guitarguy
    guitarguy
    No Worries, a quick search yielded this:
  11. rottenleonard
    rottenleonard
    So what does the 38 or 44 refer to?
    Thor1 and Stogy like this.
  12. Dick Stevens
    Dick Stevens
    Maybe that is 38 mm or 44 mm throttle bore?
    pitman, Thor1 and Stogy like this.
  13. Ebbsspeed
    Ebbsspeed
    Yep, **** has it right.
  14. 38's I reckon. I'm sure 44's have a four bolt flange to the manifold.
  15. 97
    97
    The 38 and 44 are just the metric equivalents of the imperial measurements. So 38.1mm is approximately 1 1/2 inches and 44 ( 44.4) is 13/4.
    SU measures the carbs as 1" plus a number of eighths. So a H4 or HS4 or HD 4 etc is a 1 1/2 inch carb and a 6 is 13/4, and a HS8 etc is a 2" carb.
    So the listing shown says HIF4 which is an inch and a half carb.
    They moved to metric measurement later in the piece so some carbs are listed as HIF 38 etc.
  16. drtrcrV-8
    drtrcrV-8
    Rotten Leonard : Out of curiosity, have you ever weighed this car? With all the lightweight things you've done in the fabrication, I'd be very surprised if it weighed much over 1300lbs empty & with 5gals of gas in the tank...
    Thor1 likes this.
  17. rottenleonard
    rottenleonard
    Yeah with bathroom scales right at 1400lbs with 10 gallons of fuel. The IRS should help loose some weight, and i have an aluminum bellhousing for it too. They say you can cut 40lbs out of the flywheel. I'm going to try to keep widdling it down and see if I can get it under 1000lbs.
    Someone should donate one of those aluminum model A blocks......
    20200601_161242.jpg 20200601_161240.jpg 20200601_162455.jpg 20200601_162457.jpg 20200601_163028.jpg
    patmanta, gnichols, Stogy and 5 others like this.
  18. El Hueso
    El Hueso
    Wow!
    Stogy likes this.
  19. AHotRod
    AHotRod
    How cool is that, 1400# .... love it brother
  20. brEad
    brEad
    Great weight distribution, too!
    gnichols, Stogy and Thor1 like this.
  21. drtrcrV-8
    drtrcrV-8
    Although there is so much good information on the HAMB, so many of us seem to be stuck inside the "box"... Then Rotten Leonard comes along & TOTALLY DESTROYS the "box" into a shredder & then starts from "scratch" to perform "Magic"!! Then he puts it on display for the rest of us to drool over(& learn from BIG TIME!!!) THANKS FOR SHOWING US NEW IDEAS & WAYS OF APPROACHING A PROJECT!!! (To say nothing of "Blowing our minds"!!)
    pitman, hfh, Stogy and 3 others like this.
  22. drtrcrV-8
    drtrcrV-8
  23. drtrcrV-8
    drtrcrV-8
    BTTT : Sorry to keep "buggin" you, but your work is an inspiration to the rest of us!!
    Runnin shine, Thor1 and Stogy like this.
  24. Stogy
    Stogy
    No diet required...well maybe a little...:D
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I just discovered this thread and find it very interesting, particularly the recent SU discussion.
    I am in the process of doing a champ car replica using two SUs on my five liter inline six. I know little about these carbs. Not to muck up your thread by hijacking it to ask questions about these (HS6?) carbs I will be starting my own thread seeking help with these carbs, about which I know little. Your carb linkages are really elegant looking.
    Stogy, Thor1 and chryslerfan55 like this.
  26. Plenty on the web about SUs and a couple of must have books; the Haynes SU book and one called Tuning SUs for power (or something like that)
  27. AccurateMike
    AccurateMike
    Those are not 6's. HS6's and above have 4 bolt flanges to the manifold. You have HS2's or 4's. Measure the manifold side. HS2 is 1 1/4", HS4 1 1/2". An HS2 will flow 90cfm., HS4 142cfm., HS6 (1 3/4") 210cfm. Mike
    Stogy and chryslerfan55 like this.
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I know the carbs pictured are not HS6s, Those are not the carbs I will be using. The carbs I am using are 1 3/4" on the manifold side, but alas, I cannot see any numbers on them so I am sort of at a loss as to where to turn for specs. The ones shown are HS3s (AUD 35R) 1.375" and the ones mounted up on the car measure 1.70" and have 4-bolt mounting flanges. Other than that I'm stumped. Then have a goofy mfgrs insignia, no numbers.
    I'll take better photos and start a separate thread.
  29. drtrcrV-8
    drtrcrV-8
    97
    In 40 plus years of carburettor work I have yet to see a HS3! ,2,4,6,and the one I would recommend for you HS8 or HD8, for twin carbs HS6 or even HS8s for triples , or one carb per intake port then I would say 6 HS4s.
    Stogy, kidcampbell71 and Thor1 like this.
