Technical Early Ford,Chevy,Packard. Junk or Not?
Discussion in 'The Hokey Ass Message Board' started by RP42, Jul 20, 2020.
  1. RP42
    RP42
    I did find a photo of 1 of these. They said early 20's Dodge Brothers Pump/ pulley ***embly. Pretty cool though
  2. RP42
    RP42
    The three pieces may just be a part of an old tool mixed in with car parts and not even automotive
  3. v8flat44
    v8flat44
    Man, i'm get'n junk drunk......some neato stuf there.......hick up....
  4. Boneyard51
    Boneyard51
    I would be interested in the twenty inch five hole wheel, if you are close to Oklahoma!
    Bones
  5. RP42
    RP42
    Yeah there's several those there. I have two different ones pictured in the photos the one that's turned upside down has a mounting bracket that it's mounted on. Seems like there's one or two more laying around. What did these go on? Thanks, Ron
    Boneyard51 likes this.
  6. Boneyard51
    Boneyard51
    They went on early ton and a half Ford trucks. Some where in the fifties, I think, Ford went to six hole Budd wheels. Those are five hole Budd wheels.
    The Budd wheels have the tapered holes and nuts.
    The other ten hole wheel, pictured, is usually ***ociated with GM and is hub piloted and has straight holes. Chevy ton and a half trucks used all the holes on the back wheels but only five on the front wheels.
    Bones
    Bones
  7. rusty valley
    rusty valley
    the three pieces wired together i believe are a spark and throttle lever set.
    62rebel likes this.
  8. RP42
    RP42
    Ok thanks. I'll have to do some research on that one
  9. Yeah, lots of random pieces.
  10. Squablow
    Squablow
    Looks like fun stuff to sift through even if a lot of it is too far gone, glad someone is there to grab whatever is still worth saving. Every year more stuff like this is lost, and less is available. Best to save what you can, while you can.
  11. RP42
    RP42
    Yeah, I had a blast. I still have a bunch more buildings and areas to look. Thanks for the replies
  12. RP42
    RP42
    I went inside one of the buildings and as soon as I got through the door I took a few pictures and then I got called in to work so I had to leave. Can't wait to see what all is in that building
  13. RP42
    RP42
    It looked like a GM number was 590822
  14. RP42
    RP42
    I should have took a picture of the front of the radiator. It looked to be in really good shape.
  15. RP42
    RP42
  16. RP42
    RP42
    I think the harrison radiator is for a 31 chevy
  17. RP42
    RP42
    A few more photos from the other day.
  18. RP42
    RP42
    Few more
