All the door port holes windows are there. The two plexigl*** side front windows are original and are there. The flat center window is not, it was replaced by the previous owner with jalosey windows. The curbside window next to the door is missing, it is flat gl*** and it goes in a channel that slides. The channel needs to be replaced as well as that piece of gl***. The front of the trailer over the windows has two evenly spaced dents as if someone tried to get it into some kind of over head storage and realized that it didn't fit after it was too late. The curbside rear has a s****e that's about ten feet long visible in the picture. The streetside is ok, but some of the rub rails are crunched, as is the lower skirt all around in various places. There is no door handle on the curbside, but there is on the streetside and it is operating fine but there is no key. Inside is gutted and my dad stored a bunch of stuff in there and all that will be cleaned out by the time of sale. I have no pictures of the inside, but picture it as gutted with that black "tar paper " that Spartan put on there. It is difficult to get pictures of the streetside because there is a hedge close up against it, like a foot or two away. Here are the pictures. It is in the same condition as when I bought it. Here is everything that you need to know about Spartan Trailers. https://tincantourists.com/wiki/spartan/ Sent from my SM-N960U using The H.A.M.B. mobile app
Ok. Thanks. I did not know about that section. I will make the necessary changes. Sent from my SM-N960U using The H.A.M.B. mobile app
