Hot Rods 471 with (2) 2-barrel Carbs
Discussion in 'The Hokey Ass Message Board' started by JimVG, Jul 11, 2020.
  1. Jmountainjr
    Jmountainjr
  2. JimVG
    JimVG
    Thanks, Jim! I think that I could design it and have it CNC milled. I did find that exact type of adapter in your referenced post in the H.A.M.B. Cl***ifieds and have PM’d him.
  3. JimVG
    JimVG
    The above referenced item was sold. Ok, if I can’t find one I will build one. Now all I need is a firm decision on carburetors!.
  4. JimVG
    JimVG
    I am thinking about running (3) Rochester 2G’s. I have read that 500 CFM rating is actually 435 CFM. Doing the math: 435/1.414 = 308x3 = 923 CFM total. That should be about right for my build. I can fab a carb adapter if necessary. Any other thoughts on running/tuning this combination would be greatly appreciated.
  5. Mat Thrasher
    Mat Thrasher
    I would think you'll need to get built and see what needs tuned. From my experience, getting to idle is the biggest hurdle. I had to lap my ****erflies to the bodies to keep them from ****ing air with the blower pulling on them. Once that was handled it acted like it did N/A. I don't have any special carbs with the thicker blades.
    Are you going to run it progressive or straight linkage?
    JimVG likes this.
  6. Flatrod17
    Flatrod17
    I think putting 3 2cg's on a 4-71 will be a challenge. Also your math may say it needs that much cfm, but are you really going to run it at full throttle all the time? I think two 2300's will be plenty of performance!
    JimVG and egads like this.
  7. JOHN H EDGE
    JOHN H EDGE
    This little Oldsmobile motor runs and winds like a small block Chevy on two carbs. Runs like a champ and has made some long hauls going to shows 8BA7F716-7B36-4B61-BD90-B5E28F98926B.jpeg
  8. gsjohnny
    gsjohnny
    JimVG likes this.
  9. Baron
    Baron
    Single Holley 750 CFM on my 1962 327(331 cu in) but it's all hidden under the hood. My 327 3 28 20 left side.jpg
  10. Baron
    Baron
    Here's a 4 deuce set up on a local 3W. Note the early v-belt drive also. Very cool. 20151017_115345 (2).jpg TYROD 3W MOTOR-1.jpg
    Jet96, GlassThamesDoug, 51box and 2 others like this.
  11. Rocky
    Rocky
    Classified Editor
    My buddy, Stu [R.I.P.] used to run a 327 with a 4-71 and two modern Holley 2 barrels on it. Said he liked it a lot better than the 2 Holley 4 barrels he ran on it first. I rode in the car [31 chevy 5 window] several times and it was smooth with no hesitations or jerks.
    GlassThamesDoug, JimVG and Baron like this.
  12. If you want to run a pair of Holley 500 (ish) 2 bbls on a 471 you run them back to back. makes them resemble a single 4. Holley made a 600 CFM annular discharge 2 bbl that was really popular with the short track crowd in the '70s and '80s. No reason to look the number up as it falls under good luck finding one. I have only seen one since returning to the US in '92.
    I would probably consider running a single 4 or a pair. to get what I was after personally. Its about performance right?
