Hot Rods hopped up Dodge Chrysler Plymouth Desoto Mopar flathead 6's Lets see 'em
Discussion in 'The Hokey Ass Message Board' started by 6inarow, Jul 10, 2020.
  1. 6inarow
    6inarow
    Post up what you have and tell us about them!! Pics get you bonus points
  2. j hansen
    j hansen
    Dodge 1948, 230cui ,Offenhauser manifold with -41 Oldsmobile carbs, and split exhaust.
    I did not build this,just bougth it:) Skärmavbild 2020-07-11 kl. 08.15.39.png Skärmavbild 2020-07-11 kl. 08.16.35.png
  3. MMM1693
    MMM1693
    I hope this thread grows. I have a 53 218 I want to do a mild hop up on.
    6inarow likes this.
  4. rusty rocket
    rusty rocket
    C9A5B62B-E7DE-48A7-A398-A481A485B366.jpeg I have a 1959 dodge 230 in my single seater. It 100% stock though. It moves my little 1500 pound car down the road just fine. I don’t have plans to hop it up just get the oil leaks fixed.
  5. 6inarow
    6inarow
    @rusty rocket I would like to see your little car sometime. we you at the rod run this weekend?
  6. oldwood
    oldwood
    from arkansas
    Pics have been posted before. Mating a '58 Plymouth over drive to my 230. Decked and shaved and balanced. Dodge never offered an OD in '57-'59 in p***enger cars.
      299.2 KB
    6inarow likes this.
  7. rusty rocket
    rusty rocket
    No rod run for us, have not had the cars out much this summer, been busy with projects around the home front.(Hmmmm I think I have heard someone else use that excuse)hahaha!
    6inarow likes this.
  8. hkestes
    hkestes
    hfh, EVL401, SlotsAfun and 7 others like this.
  9. 6inarow
    6inarow
    Lets keep this going. Nice job @hkestes
  10. B Ramsey
    B Ramsey
    I have a 265 out of an old dump truck. collecting parts for the rebuild, Block is currently at machine shop. it had 2 different pistons in it and had a hard life. Stock rebuild for now, will squeeze it into '41 dodge 1/2 ton 4x4 military.
    6inarow likes this.
  11. 6inarow
    6inarow
  12. rusty rocket
    rusty rocket
    Only if I can find a Sponsor to give me parts for free.
    6inarow likes this.
  13. JOHN H EDGE
    JOHN H EDGE
    86449263-DF7F-4A27-8051-700EAF9520DE.jpeg 02092BB7-5C8B-4821-872B-D47C89978086.jpeg Bad boy Flathead
    hfh, '28phonebooth, EVL401 and 7 others like this.
  14. MO54Frank
    MO54Frank
    My friend Hubert built this Chrysler 251 a few years ago. Since this video he added a dual carb manifold and dual exhaust header. He is an old time MOPAR inline 6 guru. He’s forgotten more about these engines than most of us will ever learn.
    Years ago he had a 37 Desoto coupe that was a real contender at the Newport Hill Climb.
    EVL401, S1B, ratfink56 and 3 others like this.
  15. wardwd
    wardwd
    from NY
    Very nice!
    I am interested in seeing detailed photos of hopped up flathead six installations; the new EDGY phase 2 heads do not accept the MoPar throttle bellcrank post.
    I am trying to determine how to connect the throttle linkage on the firewall, near the steering column, to the dual-carb AOK intake's Carter B&Bs.
    The Carbs are connected by a linkage included by George Asche, but how to connect that to the car is a puzzle.
    Also, if I want to install a hotter cam in my engine, which is stock and has been run about 3300 miles, how essential is it to install new lifters? Thanks for any advice or posted photos!
  16. Tom, do you follow Tony and the Montana Dodge Boys on Facebook?
  17. Flat Six Fix
    Flat Six Fix
    Ran a hopped up 228 in my 55 Fargo for years.
    In fairness the engine was tired, all cyls leaked but she had good oil pressure and did not burn oil.
    She was a dog though, sorry most are dogs unless were talking well built 230s or 265s.
    I have a nice 265 still on my floor and also have a dual carb setup and dual exhaust manifolds.
    This spring I swapped in a stock LA 318 with 904. Night and day power difference, its not even close. I have a friend with a warmed up 251 and T5, and although its a nice cruiser its way less power than a my 318.
    Here's pics of my dual carb flathead 6. And my 265 engine.
    Beepx22 likes this.
  18. JOHN H EDGE
    JOHN H EDGE
    19BCFF8B-2EC1-4BD5-A16B-6E23BB1E737E.jpeg I’ve read a lot of concerns that the edgy head doesn’t have a provision for the belcrank throttle linkage. I used the stock pedal linkage and adapted a lokar gas pedal cable (shorten ) and made a few brackets
    EVL401 likes this.
  19. HSF
    HSF
    from Lodi CA
    All I have so far... Screenshot_20210123-204827_Gallery.jpg Screenshot_20210212-073029_Gallery.jpg
  20. HSF
    HSF
    from Lodi CA
    Going Screenshot_20210123-104539_Gallery.jpg in this turd....
  21. wardwd
    wardwd
    from NY
    Hi John
    Did you drill and tap the missing holes for the ignition lead tubes and the oil filter attach?
    I received my head Sunday and am unsure how to proceed. I will be calling Tony.
    Ward
  22. wardwd
    wardwd
    from NY
    Hi John
    Ward
  23. JOHN H EDGE
    JOHN H EDGE
    No I didn’t use the factory plug wire holder but I did drill and tap the head to attach a brace to attach the throttle cable and
    Remote spin on oil filter. Hope this helps
  24. Semmerling
    Semmerling
