Projects 1949 Buick Sedanette Mild Custom Build
Discussion in 'Traditional Customs' started by rockable, Mar 16, 2019.
  1. igorsgonemadd
    igorsgonemadd
    Looking good man can’t wait to see more progress!!!
    Thor1 likes this.
  2. rockable
    rockable
    These little curved extensions on the front fenders have a lap joint with spot welds....a place for rust. I tore a page out of Robert McCartney's playbook and **** welded them on. It looks better in person than in the pictures.
    Also, I re***embled everything to make sure it all fits before I do any more work. I'm almost done with the dirty work, Thank God!
    chryslerfan55, brEad, Gotgas and 8 others like this.
  3. igorsgonemadd
    igorsgonemadd
    What did you do with the gas filler door there?
    Stogy and Thor1 like this.
  4. vtwhead
    vtwhead
    ^^^^^^^curious also about that gas door.
    Thor1 likes this.
  5. rockable
    rockable
    That is a Hagan's fuel door. If I had a do over, I would just male my own, I think. It needs to have a larger perimeter, so you can hammer the welds flat after you've welded. It is a push to unlatch/push to latch magnetic latch like they use on cabinets. It also has a fuel cap that has the flap in it so it doesn't have to be removed when filling with gas.
    https://www.haganauto.com/product_p/fd45ovq.htm
    Stogy, chryslerfan55 and Thor1 like this.
  6. Sweet & Low
    Sweet & Low
    Dude !! you kicked it's ****. And you did it right. I bet you felt real good taking a step back to appreciate your own quality of work. looking forward to more pics.
    chryslerfan55, rockable and Thor1 like this.
  7. rockable
    rockable
    Contrary to my not posting to this thread lately, I have been busy. In order to accomodate the two suspension relief boxes I fabricated underneath the rear seat, I had to di***emble and modify the rear seat bottoms. That part,is done and I need to go visit my upholsterer before I re***emble them.
    This is what 70 year old foam rubber looks lime right before it turns to dust.
    The pictures after that are the modified seat frame.
    0714201200.jpg 0720201458.jpg 0720201500.jpg 0715200859.jpg 0715201419.jpg 0715200859a.jpg
    JalopyJimbo, brEad, Stogy and 4 others like this.
  8. rockable
    rockable
    Also, I have been bolting components together to make sure everything fits. Also modifying the steering column and steering wheel. Mounting stuff on a BB Buick is not easy due to the way the oil pump is bolted to the lower front of the engine. Ive also made kick panels to hide the AC lines and the SPW wiper drive. 0725201022a.jpg 0725201023.jpg 0725201024.jpg 0725201024a.jpg 0725201021_HDR.jpg 0725201022.jpg 0725201021a_HDR.jpg
  9. Colin HD
    Colin HD
    Somehow missed this build thread! FOOL.
    Great skills, car is looking fantastic.
    loudbang and rockable like this.
  10. rockable
    rockable
    Finding gl*** for these Sedanette is pretty hard. Call Bob at Bob's Cl***ic Auto Gl*** in OR. Bob has it, as well as gl*** for Nash, Hudson and other hard to fit models.
  11. Fat47
    Fat47
  12. rockable
    rockable
    Every once in a while I think to myself, "Have I bitten off more than I can chew? We will see. I keep thinking of 2 words as I look at this, cluster fu**!
    123pugsy, brEad, Stogy and 3 others like this.
  13. Hang'emHigh
    Hang'emHigh
    Showed this pic to an upholsterer friend, he laughed(with you) and agreed with your thoughts!
    loudbang and Thor1 like this.
  14. rockable
    rockable
    We will see if I can make chicken salad out of this chicken doo in the next couple of days. ;)
  15. lemondana
    lemondana
    from Lincoln NE
    Can't you use foam construction something like you did in your 41 Plymouth? That seat turned out very nice!
    Stogy, loudbang and Thor1 like this.
  16. rockable
    rockable
    I could but these sit so well that I thought ibwould try my hand at rebuilding them. I have a plan. Stay tuned.:)
  17. lemondana
    lemondana
    from Lincoln NE
    I'll be watching. It's looking great!
    Thor1 and loudbang like this.
  18. Lines
    Lines
    from Germany
    Very nice build. Its comming together.
  19. rockable
    rockable
    0730200758.jpg 0728201341a.jpg 0725201137_HDR.jpg 0730200757.jpg 0725201446_HDR.jpg 0730200817.jpg 0725201416_HDR.jpg I ran out of hog rings, so I decided to finish up my steering column. I dis***embled the trunk signal and rewired it. Had my machinist make me a spacer to fit a bearing I bought and turn down a puece of borgeson shaft which I weldes to the hollow shaft. He then turned down the o.d. and voila, I have a nice looking steering shaft. I ordered a horn contact kit from Limeworks to finish it off.
  20. BJR
    BJR
    Looking good!
    loudbang, Thor1 and rockable like this.
  21. rockable
    rockable
    I never liked where the factory or dealers installed the backup lights on this car but I liked the lights, so I moved them to a better place, IMO.
  22. rockable
    rockable
    I LOVE the art deco style of this car, especially the dash, instruments and steering wheel. However, the steering wheel is 18" in diameter and is just too big. A friend gave me an early Camaro wheel that is oval shaped. It is about 16" across and about 15" up and down. So, after,determining,that it would accomodate my horn ring, I cut the centers out of both wheels and welded the Buick center into the Camaro wheel. My buddy Richard will do the reconstruction of the plastic and the wheel will be painted body color.
    JalopyJimbo, BJR, Hnstray and 10 others like this.
  23. 392
    392
    Impressive build.
  24. Fat47
    Fat47
    I'm parking my 49 on the other side of the show. Couldn't take the comparison.
    Hnstray, loudbang, lemondana and 2 others like this.
  25. rockable
    rockable
    Lol! It's not done yet! Yours looks great, too! Get it on the road!
  26. rockable
    rockable
    Boy, when you can find a good machinist who doesn't mind doing small jobs, its a Godsend. My headlight switch was shot and a new one came with my wiring kit. I was thankful when it fit the die cast frame that the original switch mounted in but the stem on the knob was different from the original. The new one was triangular and the original just had one flat on it, plus it was too long. I wanted to keep the original knob but the stem was integral to the knob. My new machinist buddy suggested that he could probably emulate the the new stem by 0805201521.jpg 0805201520_HDR.jpg 0805201522.jpg cutting the old one off and making this one triangular, while turning a new tip on it. Shazam! It fits the new switch like a glove. He also made me a knob for my power wipers that emulates the original knob. We're definitley working hard to keep the look that Harley Earl wanted.
    brEad, OzMerc39, Stogy and 6 others like this.
  27. loudbang
    For our USA members :) Not the guys down under.
    OzMerc39, Stogy, DIYGUY and 8 others like this.
  28. BJR
    BJR
    When you changed the ring on the steering wheel did you keep some of the old ring and weld to the smaller ring, or did you weld the spokes to the new smaller ring? Hope that makes sense.
    Stogy, Thor1, Hnstray and 1 other person like this.
  29. rockable
    rockable
  30. rockable
    rockable
    I cut away all of the old ring, cut the spokes down to the right diameter and the welded to the new spokes. Grinding that plastic away is a NASTY JOB! Do it out doors and wear a respirator!
