Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. nunattax
    nunattax
    the top is looking excellent
    TFoch, loudbang and tb33anda3rd like this.
  2. tb33anda3rd
    tb33anda3rd
    used spray glue to glue the padding down. I did not have a piece big enough in one direction, so I had to seam it. I decided to do, one piece in the middle and piece each side symmetrically in case the seams showed, it would look even. IMG_0545.JPG IMG_0546.JPG IMG_0547.JPG
  3. tb33anda3rd
    tb33anda3rd
    I put the vinyl out in the sun to warm up and while I was waiting I primed Charle's steering wheel and the rain gutters. IMG_0549.JPG IMG_0548.JPG
  4. tb33anda3rd
    tb33anda3rd
    after lunch I laid the material on the top and started to tack it down. I put two tacks on either end of each slot. I started in the middle of each side, pulling it tight. I did the front and back first then the sides. I made pencil marks to aid in finding the slots. IMG_0550.JPG
  5. tb33anda3rd
    tb33anda3rd
    once it was all tacked I trimmed close to the tacks with a razor knife. IMG_0554.JPG
  6. tb33anda3rd
    tb33anda3rd
    I had to run the fabric in this direction because it was the only way it fit.
    the next step was to install the "wire-on" to hide the tacks. I tacked this in between the two tacks I already used to hole the top material down. IMG_0558.JPG
    cactus1, brEad, kidcampbell71 and 7 others like this.
  7. The37Kid
    The37Kid
    Wonder if the rain gutters will fill quicker with the change in the top material direction?
    Bob
    Tman, loudbang and Stogy like this.
  8. tb33anda3rd
    tb33anda3rd
    I ran the big bead side of the "wire-on" towards the front of the truck this way any driving weather is sealed out better.
    on the ends that get tucked under the rain gutter I pulled the threads out and peeled back the material so I could cut off the inner structure. this will make it thin enough to go behind the gutter without making it stand out. it also finishes off the end of the "wire-on". the "wire-on" gets closed over the nails and then hammered shut with a rubber mallet. IMG_0560.JPG
  9. tb33anda3rd
    tb33anda3rd
    hmmm? I was worried about how it would look. I was dead against using it but Charlie thought it would be ok, and I have to agree.
  10. tb33anda3rd
    tb33anda3rd
    great instructions on how to install the rain gutter. I decided not to put the trim strip in the gutter, I like the look of the nails and screws better. of course they did not drill the holes big enough for the nails they supplied:rolleyes: I did have to drill through the heads of the tacks under the rain gutter to get the nails in. IMG_0565.JPG IMG_0566.JPG IMG_0567.JPG
    32SEDAN, brEad, Shadow Creek and 7 others like this.
  11. tb33anda3rd
    tb33anda3rd
    ready for delivery tomorrow to put it on the frame...stay tuned. IMG_0569.JPG
  12. Stogy
    Stogy
    Dang nice job TB, grain direction...won't see it at 50mph anyway and way better than a 1' dia piece of tree top...:D
    Runnin shine, TFoch, loudbang and 2 others like this.
  13. IowaMercMan
    IowaMercMan
    Great save. Great work! Thanks for sharing the journey with us.
    Walt
    Outsiders CC
  14. petew
    petew
    from Mebane, NC
    Nice job Ted and I am impressed with your skills in both metal and wood work , well done sir.
    Spoke to Charlie tonight and he is pretty excited that it is coming home.
    tb33anda3rd, loudbang and Stogy like this.
  15. nunattax
    nunattax
  16. tb33anda3rd
    tb33anda3rd
    thanks for the compliments and thanks to all who are following!
    Pete, Charlie and i are glad you, Matty and all can follow Charlie's project. Charlie is also amazed how his little truck project is being followed and "liked" by so many people from across the country and around the world.
    getting ready to load the cab now.
  17. FolksWaggin
    FolksWaggin
    Ted, It’s so great to finally see the way the wooden roof frame looks inside, now that it’s finished. It looks as good as I imagined it would.
  18. Runnin shine
    Runnin shine
    I have the feeling of at the end of a great movie. There is a sadness in there I can’t put my finger on.
    Only option is to choose “play from beginning”
    The Slacker is on the cusp of his own Cool Change.
    tb33anda3rd, loudbang and Papas32 like this.
  19. tb33anda3rd
    tb33anda3rd
    I will keep checking in on the slacker and post updates....
    I was thinking the name of the truck could be "the defiance" or "the resilience"
    TFoch, brEad and loudbang like this.
  20. tb33anda3rd
    tb33anda3rd
    loaded up this morning and headed out. 4 other buddies met at Charlie's to get it off the truck and on the ch***is. IMG_0574.JPG
  21. tb33anda3rd
    tb33anda3rd
    if this GMC could talk, if I had photos of all the stuff it hauled, if we wrote down all the stories that revolved around it....add another truck cab... IMG_0584.JPG IMG_0586.JPG
  22. Runnin shine
    Runnin shine
    It’s about 6’ distance between each person lifting the cab. Well right and left anyway.
    My wife told a friend I have the soul of a 75 year old wood worker. Thinking of this thread and those who dig it, I nodded to myself, I’m good with that.
    brEad and tb33anda3rd like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Ted, You have done a excellent job of bringing the smashed cab back, it looks like it had never been in a accident.
    The top looks great also. HRP
  24. tb33anda3rd
    tb33anda3rd
    some shots of the ch***is before we set the cab on. IMG_0589.JPG IMG_0590.JPG IMG_0591.JPG IMG_0592.JPG IMG_0593.JPG
  25. tb33anda3rd
    tb33anda3rd
    32SEDAN, R A Wrench, TFoch and 3 others like this.
  26. ct1932ford
    ct1932ford
    Go Charlie Go!:cool: Nice work TB.
  27. tb33anda3rd
    tb33anda3rd
  28. brEad
    brEad
    Excellent work on the roof. I raised an eyebrow at the vinyl direction, too, initially but I think it looks great!
    loudbang, nunattax and tb33anda3rd like this.
  29. tb33anda3rd
    tb33anda3rd
    I was dead set against it like I said. but once I laid the piece up there it looked fine. I asked the guys if anything stood out about the top and they said no. when I pointed out the fact it was running sideways they said "I wouldn't have thought it was wrong"
    loudbang, Dick Stevens and brEad like this.
  30. tb33anda3rd
    tb33anda3rd
    he had tools out and was working on it before we left.
