Hot Rods Any machinists that could make a fitting?
Discussion in 'The Hokey Ass Message Board' started by loveoftiki, Jul 24, 2020.
  1. TRENDZ
    TRENDZ
    Not so. O ring boss is not nps. -4 o ring boss is 7/16 -20.
    Parker does not make any nps boss fittings. At least not in their industrial catalog.
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
    Dave....I’m not kidding I’ve been to several Parker stores...they look at me like I’m speaking Chinese. They have they’re thread pitch templates on the desk..if it’s not on that, they want nothing to do with it. I guess I’ll try again on Monday
  3. Joe H
    Joe H
  4. loveoftiki
    loveoftiki
    from Livonia,Mi
  5. rusty valley
    rusty valley
    thinking some more, i would start with an old high head bolt. that would give a place for a wrench, and the high head would allow room for tapping a hole for the 1/8 pipe elbow. cut 27 straight threads up to the head allowing for the jam nut. i can do that. need to get out the book and check major/minor sizes, i think a 1/2' bolt to start, drill 1/8" thru the center
  6. rusty valley
    rusty valley
    like this, thats a 1/2" high head old time bolt, minor size is .410, so it would clean up to around .400, which is i think major size you need, havnt got the book out yet. and the 1/8 ****** is there to show there is room for 1/8 threads for the elbow. this will work? IMG_0717.JPG
  7. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yes I believe it would I could jam Nut and o ring on the case and what you be great if if the bolt head side was cut for 1/8 -27 NPS and I could bolt that stock 90 on there with that O ring and seal against that head. I have a coupe of those fittings Than I could screw the metal line into that stock 90 fitting
  8. loveoftiki
    loveoftiki
    from Livonia,Mi
    Like this
    Boneyard51 likes this.
  9. continentaljohn
    continentaljohn
    Can you draw what in needed blueprint kinda with length and sizes needed thanks. If one is going to machine this part why not just put a 1/8 taper male on the one end for the trans and a 1/8 female for your 90 degree adapter.
    The reason I say this earlier you quoted that lots of c4 transmissions are messed up when folks jam a straight thread into the hole why not use a taper end
  10. continentaljohn
    continentaljohn
    How long do you need it and what size hole thru. As you see the one end is machined for a 1/8 taper .415 and you can run a die over it. I also machined a lead-in to help align the die. image.jpg
    rusty valley likes this.
  11. toxic waste
    toxic waste
    from Iowa
  12. patsurf
    patsurf
    c.j.--you have turned (no pun on 'turned')into the machinist 'trouble truck' on a cruise-THE go- to guy!! another beauty--so: shifter,...then trans ...prob a engine- trans adapter next!!
    continentaljohn likes this.
  13. rusty valley
    rusty valley
    i cant do npts female threads, no tap, too small to bore
  14. moparboy440
    moparboy440
    from Finland
  15. Boneyard51
    Boneyard51
    If you are going the machining route, don’t use a bolt, start with a piece of hex steel, that way you will have plenty of room to drill and tap. Or round material and mill some flats on it.
    Bones
  16. derbydad276
    derbydad276
    did you try Metro Bolt & Fastener ?
    19339 glenmore redford ... beech and grand river ...(313) 538-4800
    when I worked there 15 years ago we had a ton of br***
  17. doyoulikesleds
    doyoulikesleds
    AUTCOOLERLINES1.JPG Ok I dont get it why the fancy adapter are you that atached to the hard line that is there that you cannot bend a new one to reach either the straight or 90 that is avalible
  18. Charlietruck62
    Charlietruck62
    x2
  19. ekimneirbo
    ekimneirbo
    https://www.mcmaster.com/straight-thread-pipe-fittings/type~connector/shape~straight/
    Personally I would just use a connector that screws into the transmission and drill the other end of the fitting to accept a copper tube and solder it in. Then drill the fitting you have so the tube fits into it and solder it too. Then trial fit it with an o ring and see how much you need to rotate your fitting to get the correct orientation. Remove it and warm the solder and rotate it. Then you only have the one O ring to deal with. Since you are adding length/leverage, might want to support it so it doesn't rotate loose.
  20. Dick Stevens
    Dick Stevens
    I think you have that backwards, the case is NSP and they get messed up when someone tries to put NPT fitting in the case!
  21. Ebbsspeed
    Ebbsspeed
    Ace Hardware.
    Put the stock fitting into the transmission, then screw in whatever length pipe ****** you need, then the coupling, then the 90 degree inverted flare. Less than $4 for the fittings. It's Jamaican engineering, but it will get you where you need to go.
  22. dave lewis
    dave lewis
    from Nampa ID
    Loveoftiki...
    If you tell me what line you want to run ( inverted flare hard line , -5 push lock hose , just a barb to clamp some auto parts store rubber flex trans line , or whatever flavor of aeroquip type line you like ) ...
    I will be happy to round up the proper adapters for you monday..
    No machining , welding , or tapping the trans case required...
    Easy to ship via u.s. post office..
    Feel free to give me a call...
    831-262-7294..
    Dave
    Sent from my SM-G973U using The H.A.M.B. mobile app
  23. dave lewis
    dave lewis
    from Nampa ID
    I just went back and looked closely at the pics..
    Out of the case , hard 90 degree turn , into a 5 /16 hard line..
    Please confirm...
    Dave
  24. 57JoeFoMoPar
    57JoeFoMoPar
    Bro, don't overthink this. Go to the local Home Depot or Ace, and put this together out of plumbing fittings. I know, it sounds haggard using stuff typically meant for water and household stuff on the car. Trust me on this one, I did on the last C4 I had in my 63 Fairlane and I drove that car 500 miles a week without issue. I even still have it on my Torqueflight. A basic 1/8" NPT ******, to a 1/8" NPT female to female right angle fitting, and then a 1/8" NPT to 5/16" hose with barbed end. Attach a pice of rubber line ( fuel injection hose works perfect), and you're good to go.
    That identical setup has been bulletproof for me for over 15 years, and is still going strong.
  25. metlmunchr
    metlmunchr
    The size is said to be 1/8 NPS and also 1/4 NPS at various places within the thread. This needs to be clarified as both sizes were used depending on the specific version of the C4 trans.
    Functionally, this is just a ******* size o ring boss fitting. ******* because standard ORB fittings have UNF threads where this one has NPS threads.
    From reading thru all the replies, it seem there's some misunderstanding a**** some folks as to how these fittings seal. Here's a link to a pic of the tool used to cut an ORB port.
    https://www.lanyala.com/scientific-cutting-tools-port-tool-ms16142-reamer-1-2-20-unf
    The small diameter cuts the hole to size for tapping. The slightly larger diameter cuts a counter bore and a chamfer at the entrance to the tapped hole. The largest diameter cuts a spot face so the jam nut on the male fitting has a flat face to tighten against.
    The o ring goes into the counterbored part of the hole and the seal is between the surface of the groove in the male thread and the inner diameter of the counterbore.
    For an effective seal, the diameter and surface finish of the groove in the male thread is critical. An o ring will not seal if installed on a thread. Also, an o ring will not seal by squashing it between two flat surfaces. To form a seal, it has to be captured between two smooth surfaces such that the pressurized fluid can't make the o ring move out of position, and preloaded such that the fluid can't p*** the ID or OD of the ring.
    For someone to make the adapter the OP wants, they will need to have the current fitting in hand. As mentioned, the groove dimensions are critical. The axial location of the groove is also critical in that too much thread outboard of the groove could cause the fitting to bottom out before the o ring is seated in the counterbore. And finally, the jam nut is needed for checking the fit on the thread. A nut with a pipe thread isn't something you can just pick up at any fastener house, and although the thread may be cut to book tolerances, checking the fit with the nut verifies the two pieces will work together. There are no standards for oddball stuff like this, so the only sure way to get good parts is to have what you want to copy readily at hand.
    If I was making the part, I'd use a piece of free machining round stock like 1144 as it will thread and groove with nice slick finishes as well as having high strength. Cut the thread and groove, and that end is done. On the opposite end, just drill and tap for a regular tapered pipe thread. A male pipe x inverted flare ell is a $4 part so there's no need to go to the trouble of making an ORB type port just so the original ell can be used. Obviously a hole gets drilled thru the stock as well, but that's a minor detail.
  26. metlmunchr
    metlmunchr
    According to some of the mustang forums, screwing a tapered male pipe thread into the existing hole has a good chance of cracking the case by the time the fitting is tight enough to seal.
    Just a wild guess, but this odd fitting may be the result of Ford running into problems cracking cases on the ***embly line. With a bit of fixturing, existing cases could be modified from tapered to straight pipe threads and the counterbore for the o ring added in 5 minutes or less. With the volumes of parts the car makers buy, the mating fitting wouldn't have cost them any more than a standard ORB fitting.
    Once the fix was known to work, there was no need to change from the NPS fitting to a standard ORB fitting. That would've created another separate part number, and in the late 60s it cost car makers about $7500 per year to maintain a single part number in the parts system even if they didn't sell a single unit of that number.
  27. I was just thinking of a piece of stock 1"-2" long like he needs, threading one end for straight thread and the other for pipe.
  28. Ericnova72
    Ericnova72
    from Michigan
    It's not an odd-ball fitting...and Ford wasn't the only one using them....nearly all domestic aluminum case automatic transmissions from the early 1960's up into the 1990's or later use NPS fittings with either a hard fiber sealing washer or a copper crush washer. A rubber O-ring is not correct.
    Uneducated guys have just been screwing them up for years shoving common NPT fittings in them because they didn't know there was a difference. I've welded up more than half a dozen cases over the years from guys mistakenly putting NPT-to-AN adapters in so they can run braided hose on their hotrod/racecar....when they overtighten the NPT fitting trying to stop a slight leak it splits the line boss in the aluminum case like a log splitter cracking a log
    Mostly PowerGlide's and TH-400's, since those are the most popular for race use, but I've fixed a SBF C-6 and TH-350's too.
  29. southcross2631
    southcross2631
    I still have that stick shift bellhousing. No cooler lines needed.
    RICH B likes this.
  30. TRENDZ
    TRENDZ
    This is the type of answer needed.
    Sometimes people don’t know how much they don’t know.
