Technical Would you be afraid
Discussion in 'The Hokey Ass Message Board' started by Darin Younce, Jul 27, 2020.
  1. Darin Younce
    Darin Younce
    to use this ? Dis***embled torque tube and this what I found. Was about half way between center bearing and trans end. Think I should weld it up? 20200727_203203.jpg 20200727_203155.jpg
  2. oldolds
    oldolds
    I would look for another one. Welding would probably bend it.
    lothiandon1940 likes this.
  3. rockable
    rockable
    Welding will most ***uredly bend it. I doubt you could make it straight afterwards, either.
    Atwater Mike and lothiandon1940 like this.
  4. Darin Younce
    Darin Younce
    Yep, been looking, no luck so far.
  5. What's the car? Probably last forever if it's not a hot rod with slicks on it
    Pist-n-Broke and The37Kid like this.
  6. The37Kid
    The37Kid
    What is the diameter? Looks like a tie rod that should be s****ped. Bob
  7. southcross2631
    southcross2631
    Make a jig and clamp it down. Weld it up. If you can't find a replacement then that's what you have to work with.
  8. Darin Younce
    Darin Younce
    39 ford pickup .
  9. Darin Younce
    Darin Younce
    It is thr drive shaft out of 39 ford torque tube. Not sure of diameter.
  10. Darin Younce
    Darin Younce
    kinda thinking that , would you tig or mig this, I can do either.
  11. warhorseracing
    warhorseracing
    from cameron wv
    TIG would control the heat better. Stock Flathead? Even a mild build it should never break.
    kidcampbell71 likes this.
  12. Darin Younce
    Darin Younce
    Yes, it is stock, have possibly 2 flatheads in the works and one will prob end up in this truck, one is at machine shop , waiting on initial report the see what they find as far as cracks , another I might purchase, guessing either one will prob be 120 hp at most so they are mild .
    warhorseracing likes this.
  13. Darin Younce
    Darin Younce
    an alternative would be convert to open drive but in meantine I will pit out a want add just to see what I might find.
  14. The37Kid
    The37Kid
    Ideal deal would be to swap it for a good one with some that is going to cut one for a short wheelbase car. Bob
    mgtstumpy likes this.
  15. gene-koning
    gene-koning
    The bad news is its probably out of balance with that much material missing. The worst news is if you weld it, it will probable still be out of balance, and also no longer straight.
    Maybe it can be welded up, turned true, and then straightened and balanced.
    I think maybe its time to convert to an open driveshaft. Gene
  16. Hotrodmyk
    Hotrodmyk
  17. Darin Younce
    Darin Younce
    That is a purty good idea, have a buddy that might have one , gonna check tomorrow
  18. Darin Younce
    Darin Younce
    Yeah, I was thinking, this thing has to be somewhat out of balance but the truck seemed to be pretty smooth in my opinion.
  19. Clean it up
    Place it in a lathe
    Weld it
    Clean up with lathe
    Check with a dial indicator
    Hit with a hammer until it’s true again
  20. Darin Younce
    Darin Younce
    Well, I have a plan. I will reach out to a couple folks tomorrow that are fairly close by, might get lucky. In the mean time I will go ahead with my banjo rebuild and if all else fails, I will stick it back in truck and take it easy, ( easy to do with a -85 hp engine ) till I get ready to stick a different engine in truck which could be in next couple of months, will keep looking for a good shaft and if no luck by then I will convert to open drive.
    VANDENPLAS likes this.
  21. Darin Younce
    Darin Younce
    A fellow hamber has contacted me , says he might have a shaft. Dang you folks are purty cool.
    5window, Chavezk21, Nostrebor and 7 others like this.
  22. Pete1
    Pete1
    from Wa.
    That shaft is made from an SAE 6000 series steel and should NOT be welded in high stress applications.
    As a last resort if you can't find a good used one, you could have a new one made.
    Cosmo49 and alanp561 like this.
  23. Truck64
    Truck64
    from Ioway
    How did it get diffuculated like that?
    gimpyshotrods likes this.
  24. lippy
    lippy
    from Ks
  25. Darin Younce
    Darin Younce
    Good to know , thanks
  26. Darin Younce
    Darin Younce
    Good question, noticed ther was a slight bit of rust right beside where the center bearing sits , very minimal compared to this , noticed too side of tube was a bit rusty , didn't pay a lot of attention, but perhaps water was getting in tube about where cab and bed sit , or perhaps condensation, gathering there, it is a mystery, truck has no rot rust anywhere . Edit , the location of this in the tube is right at where the radius rods bolt on and also about where the tube diameter changes. there was some grease on the bottom of the tube so my theory is moisture, be it condensation or water intrusion was held in this particular area because the thick grease sorta dammed the bottom of torque tube holding water . I will say that the rusted area is bone dry as was the whole shaft other than old grease , no moisture at all, this damage is purty old , could have been like this 40 years ago or more
    Truck64 likes this.
  27. adam401
    adam401
    Id put it back together and run it and never think about it again.
  28. oldolds
    oldolds
    When you fine a replacement, take a grinder to that one. I would like to see how far into it the rust has penetrated. I would think most will be surprised how deep the rust is.
  29. Darin Younce
    Darin Younce
    Ha, I say this a lot but I was thinking the same thing , inquiring minds gotta know right?
  30. No one is going to agree with me. I don't care really. I would cut it out and sleeve it. That is how they used to shorten them.
    Cosmo49, King ford, mohead1 and 6 others like this.
